Custom R60 Brembo JCW "GP2X" 6-Piston BBK - Calipers/Rotors Big Brake Upgrade
Brakes
  • Brakes - Custom R60 Brembo JCW "GP2X" 6-Piston BBK - Calipers/Rotors Big Brake Upgrade - New - 2011 to 2016 Mini Cooper Countryman - Cleveland, OH 44146, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    $2,250
    • OBO
  • Location Cleveland, OH, 44146, USA
  • Condition New
  • Compatibility
Make Model Year
Mini Cooper Countryman 2011 - 2016
This is still my favorite Mini chassis/platform (despite not owning one).  And the 3rd or 4th time I've done this for the R60.  Original kit(s) details HERE.  This time the package is only for the front end.  (I refuse to keep putting work into 280mm, non-vented rear end ;-p)
Application:
  • R60 Countryman (’11-‘16) – 5x120 lug, 79mm CB
Front:
  • Calipers: OEM GP2/135i units - REFINISHED - OEM motif: Mold seams shaved, artwork is painted on using catalyzed high-temp urethane.  (Flush,no raised letters)
  • Rotors: 2x Brembo 350 x 25mm - NEW - Dimpled in Brembo 32-row pattern (mirrored/directional)
  • Lines: 2x Custom stainless braided lines - NEW - w/ PVC sheath and 90*swivel end
  • Brackets: Custom worked for the 350mm rotors and R60 spindle
Notes:
  1. Make sure your wheels will clear the front 6-piston units. Dust shields may need trimmed or removed to fit the massive front binders. You can use the GP2 template by matching up the OD’s of the two center bores.
  2. GP2 TEMPLATE
  3. Wear sensor, and fluids are not pictured or provided.
  4. **Ensure that your installer (if you're not a wrench) will install aftermarket parts.**
Related:  F60 custom 6-caliper BBK
Old May 9, 2025 | 01:06 PM
Raymo2u's Avatar
Raymo2u
I wish I could get that kind of money right now...maybe if I can sell my GTI.
GLWS! Hopefully you'll have one for sale around next February! I definitely would take it.
Old May 9, 2025 | 02:00 PM
ARD'sDIY's Avatar
ARD'sDIY
Top stuff right there.
Appreciation level: Through the roof
Old May 9, 2025 | 08:40 PM
veggivet's Avatar
veggivet
I know I could google it, but does anyone know what a set of fronts only would go for new? Thx
Old May 9, 2025 | 09:00 PM
Raymo2u's Avatar
Raymo2u
You'd be paying much more, that's for sure. They are custom fit for the R60 as they never made a set for it. A Set of GP R56 brakes by themselves are more than what's listed here, $2500-3700 depending on where purchased...and the work to get them to fit would be on top of that. You could get some used 135I calipers and refinish them for cheaper but it will still be more than what's listed in the end.
Old May 10, 2025 | 12:53 AM
veggivet's Avatar
veggivet
Thanks for the info, @Raymo2u . Gotcha, so even thought these are custom, they use standard Brembo parts so finding those if needed for repairs wouldn't be a hassle, correct?
Old May 10, 2025 | 06:58 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
This is a great brake option for the bigger R60 platform. The part that’s most custom here is the mounting bracket. Then, add in the time to refinish and rebuild the calipers. Rotors are off the shelf, and Chris can give you the make and model for replacement.
This is a solid kit.
Old May 11, 2025 | 02:07 AM
All4's Avatar
All4
Would love to know the P# for those caliper brackets and what needs to be done to them to make them fit. Also make/model those rotors are originally meant for.
Old May 12, 2025 | 07:53 AM
CG1*'s Avatar
CG1*
This is a SOLD kit. Thanks for the support, folks.
Feel free to DM me if you want to discuss the particulars or plan your attack for your own DIY setup.
