300whp , fully rebuilt and reliable 2004 r53
2004 Mini R53: "Mk I" Mini Cooper S
  • 2004 Mini R53: "Mk I" Mini Cooper S - 300whp , fully rebuilt and reliable 2004 r53 - Used - VIN WMWRE33464td81317 - 222,000 Miles - 4 cyl - Manual - Hatchback - Other - Oakcreek, WI 53154, United States
Community Builder
    $12,000
    • OBO • Trade
  • Location Oakcreek, WI, 53154, USA
  • VIN WMWRE33464td81317
  • Mileage 222,000
  • Engine 4 cyl
  • Transmission Manual
  • Vehicle Type Hatchback
  • Exterior Color Other
Long story short , I WANT a 2010+ mini cooper jcw. I'm willing to trade down ! OR I would sell the car outrite for 12k ONLY I will entertain offers but with a trade if we're are FAR apart I would expect cash on your end but like I said , I am willing to trade down. Mileage also doesn't bother me so long as you can prove maintenance has been performed and the car has NO RUST or decent body damage. I have 2x r53's so I plan to keep which one doesn't get moved.
You CANT build this car for under 30k not including the amount of time invested. I will link the build thread detailing everything ive done to and replaced on the car but I will give you a quick list off the top of my head , all mods ect were purchased and installed by me or with a more experienced helper..
prior to purchasing the car 3yr ago from an owner in California he replaced the eng n trans with a much much lower mile set and brought the car to WI and I immediately purchased it. Since owning, it's always been a garage kept / fair weather car and put away in winter. It's only seen cold road ONCE !
so all replacement parts ect are no more than 3yr old and 10k miles MAX ! I will also link a YouTube video showing the car and a 5-120mph pull.
besides all the mods. The car has NO cel or error lights on other than airbag light because of racing seats. It WILL pass emissions too ! Heres what I can remember ive replaced :
Supercharger , clutch setup ,exeddy tob , all intake and exhaust gaskets , exhaust bushings , cabin air filter , all 4x hubs and speed sensors , all the brakes and high temp dot4 , mls headgasket and arp headbolts , timing guides and tensioner, valvecover gasket, fuelinjector orings , 260lpj fuelpump with filter and tank cleaning ,  paintjob ( battleship grey ) is 2yr old only , fresh coolant as tvs900 was just recently installed , only ever run rotella 5w40, fresh intercooler coolant , p.s system was replaced under recall almost 3yr ago,  tires have under 10k on them , complete ignition is 6months old , front and rear tmap sensors,  new crank sensor ,wiring and harness , knock sensor , cam sensor , slave cylinder, guide tube , rear main seal, master cylinder, all 4x brake lines , has upgraded donut style header flange because of obx 421 headers , entire suspension , coilovers, balljoints , 4x adjustable rear control arms , rear swaybar bushings , new battery in March, new alternator, new ground wires , 1YR old windshield, And probably ALOT more I'm forgetting.  No expense has been spared in this build.
mods are....
ENGINE :
. Tpr2r big valve head.
Ns1 street cam ( will include a catcam 469 for more power )
. Tvs900 supercharger with 55mm pulley and upgraded billet tensioner ( 20psi and 0 belt slip)
. 2% light weight crank
​​​​​​.electric waterpump is on a toggle switch
. Ac delete pulley
. sneedspeed Manifold with additional porting
. Obx 421 catless headers with ported flange and nvida resonated exhaust ( passes emissions)
. 550cc bosche fuel injectors ( have 4x extra ). High-flow fuel pump and new filter. nology hotwires and ngk 1x step colder plugs
. Ported throttlebody and full 3in intake and DDM intake box
. grs liquid cooled intercooler with dual coolant pump and 4.5gal trunk mounted reservoir ( the BEST intercooler made , pumps are 9n a toggle switch )
. Aluminum coolant and clutch fluid reservoirs. M7 aerogel heatshield and custom intake heatshielding
. Mishimoto aluminum radiator and 180' thermostat
. Detroit tuned bypass valve
. Ported and shaved and anti heat ceramic coated intercooler horns
. Upgraded silicone coolant hoses and upgraded vacuum lines
. Upgraded intercooler boots
.facelift ecu with Custom tuning done by adriancl via ONROAD live data
. Oil catch can
. Newer replacement Carbonfiber hydropdipped valvecover
SUSPENSION ,STEERING & BRAKES :
. R56 brembo front brakes
​​​.willwood rear brakes
. rev9 hypersteet2 coilover with caster camber plates
. performance dot4 brake fluid.
. vibra technics upper engine mount  ,lower engine mount and transmission mount
. Front and rear adjustable swaybar end links. Rear upper and lower adjustable control arms
. Vip engine brace
. Polly filled or stock bushings all throughout the vehicle
. Carbonfiber Front and rear strut bars
. Convertible support braces. 16x8 lightweight rims ( 16lb) , 10mm spacers and extended lugs with 205/45 firehawk indy 500 tires with around 10k miles on them. They fill out the widebody flares well.
INTERIOR AND EXTERIOR MODS :
. full bodywork and battleship Grey paintjob done in april
. Fiberglass widebody fender flares
. Coolerworx shifter and facelift shift cables and new transmission shift bracket and weights
. Euro parcel shelf
. Ultra gauge and mount
. Rally lights running off a toggle switch
. Jcw shift light
.  rear seat delete, setup for underneath and they hinge open ( still have rear seats ect )
. Carbonfiber steering wheel
. Carbonfiber look hood vents
. Carbonfiber look side skirt/flares
. Carbonfiber side mirror covers. Carbonfiber rear vents scoops for real cold air intake and brake master cooling
. Carbonfiber C-pillar aero panels
. Carbonfiber leap v3 hoodscoop
. Carbonfiber dash
. Carbonfiber hydropdipped parts that could not be purchased as real Carbonfiber.
. Carbonfiber downtubes
. Carbonfiber vinyl overlay over many other interior parts
. Carbonfiber door handle covers
. Carbonfiber gascap cover
. Carbonfiber adjustable spoiler
. Carbonfiber exterior pillars
. Carbonfiber boot lid trim
. Carbonfiber ebrake handle
. Carbonfiber look chrome delete. aero style bumper lip
. Real custom 3d printed rear bumper vents
. Leap rear Fiberglass diffuser
. Led Unionjack turn signal markers
. Led halo bumper running lights
. Led halo headlights and carbonfiber trims
. Led smoked sidemarkers
. Led smoked foglights
. Led smoked taillights and carbonfiber trims
. Led color changing programable interior lighting.digital boost gauge
. Afr gauge and wired in wideband sensor
. Fully adjustable racing seats on sliders. Custom installed armrest
here's link to the build thread and 2x vids showing the car better. Please ONLY contact me if your are serious about purchasing or trading. If you have questions about anything else please refer to my build thread..  I also mentioned in the video it needed a tune , it's since been done. Afr are spot on , no cel , cars PERFECT  !
stay safe n motor on !!!!!
https://www.northamericanmotoring.co...ject-rice.html
Old Jan 21, 2024 | 08:51 AM
MiniManAdam's Avatar
MiniManAdam
Community Builder
Proce drop to 11k for specific reasons so act quick because I won't be willing to take 11k for long..
Old Jan 25, 2024 | 04:38 PM
lonewolf170's Avatar
lonewolf170
****. 11k? even more tempting.
Old Jan 26, 2024 | 06:15 AM
Marco71190's Avatar
Marco71190
You are taking a really big loss at 11k! Maybe you should consider parting out all the goodies, and sell the car stock-ish.
Old Jan 26, 2024 | 06:18 AM
MiniManAdam
Community Builder
I'm actually keeping it now , I ended up just buying an r58 outrite so now I get to have the best of both worlds..
Old Mar 9, 2024 | 08:04 AM
MiniManAdam
Community Builder
Life has thrown me in a different direction so I will let this car go for 12k$ ONLY !!!!!!
this is for our mini community guys because I'm sick of trying to tell people about the car who are looking to just buy a fast car and know NOTHING about minis. Then think that their 8k offer was acceptable..lol
So come get this sucka !!!!
it HAS been retuned for the tvs900 AND i put on the rear willwood brakes BUT covered them with brembo decals so they matched the front..
I WILL ALSO TRADE FOR A PACEMAN or COUNTRYMAN JCW , I WOULD consider another r59 too !
Old Mar 11, 2024 | 09:33 AM
Marco71190's Avatar
Marco71190
Weeeeell if you eeeeeever consider parting it out, let me know about that TVS...
Old Mar 11, 2024 | 05:24 PM
MiniManAdam
Community Builder
sorry but never gonna break it down unless it blows up or gets smashed up.. its a gem
Old Mar 14, 2024 | 08:27 PM
SEB3510's Avatar
SEB3510
I am interested, $11k. In Houston, fly up to look it over. Have it trailed back. I have three Minis - GP2, 2004 JCW track car, 2019 JCW daily. My track car does not have sufficient HP. let me know.
Old Mar 15, 2024 | 01:28 AM
MiniManAdam
Community Builder
did you watch the vids ? The car pulls hard. Very hard.
I've pulled 4.4sec 0-60mph on street tires on the street with no tire warming or prepping..
i can promise this car i have put together for it to be able to be run as hard as you want to push it.. since having it in its current setup , i never tracked the car ( well once at the 1/4mile strip for 3x runs when it had half the mods ) BUT i have tested it and put it through its paces on our local country /back roads ..
shoot me a pm and we can exchange #s and i can send you vids or pics of anything specific you might want , like cold start good pics of interior or underbody ect..jlmk , legit the car has 0 and I mean 0 issues.. I just really need the extras space and cash since winning custody of my son after a 10yr battle.
Old Mar 15, 2024 | 06:45 AM
SEB3510's Avatar
SEB3510
See private response
Old Mar 16, 2024 | 06:26 AM
MiniManAdam
Community Builder
BTW guys. This car isn't being sold because of some issue or kink that can't be worked out or fixed.
if there's was any issues , I state them. Im trying to be as upfront as i can about this car..
I would part it out and get 3x my asking price IF my life didn't take a 180. I won custody of my son after a 10yr non stop battle and it happened literally over night and went from 0-100 real quick. our 2bdrm apt isn't going to fit us so I'm selling this car to use as a down-payment on another residence and to get my son living like a normal kid again ( mother was useless )
I love LOVE this car , it's one of the most enjoyable cars I've ever EVER driven nonetheless got to actually own. But I love my family more...so sacrifices need to be made and this is what I gotta do..
Old Mar 19, 2024 | 02:00 PM
MiniManAdam
Community Builder
The car has sold...
I appreciate all the interest...
All I gotta say is..
Someone GONNA BE HAAAAAAAAPPY !
