2002 R53 part out
2002 Mini R53: "Mk I" Mini Cooper S
  • 2002 Mini R53: "Mk I" Mini Cooper S - 2002 R53 part out - Sebastopol, CA 95472, United States
    Expired
    Expired
  • 2002 Mini R53: "Mk I" Mini Cooper S - inside door lock cable - Accessories - $7 - Sebastopol, CA 95472, United States
    Expired
  • 2002 Mini R53: "Mk I" Mini Cooper S - Koni FSD shocks with factory sport springs (front only) - Accessories - $50 - Sebastopol, CA 95472, United States
    Expired
    Expired
    Expired
  • 2002 Mini R53: "Mk I" Mini Cooper S - Panther leather interior non-heated - Accessories - $100 - Sebastopol, CA 95472, United States
    Expired
    Expired
    Expired
  • 2002 Mini R53: "Mk I" Mini Cooper S - Manual - Accessories - $10 - Sebastopol, CA 95472, United States
    Expired
    Expired
    Expired
  • 2002 Mini R53: "Mk I" Mini Cooper S - tail light- driver's - Accessories - $15 - Sebastopol, CA 95472, United States
    Expired
  • 2002 Mini R53: "Mk I" Mini Cooper S - Stock air box - Accessories - $20 - Sebastopol, CA 95472, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
  • 2002 Mini R53: "Mk I" Mini Cooper S - front bumper carrier beam - Accessories - $50 - Sebastopol, CA 95472, United States
    Expired
  • 2002 Mini R53: "Mk I" Mini Cooper S - front crush tubes - Accessories - $10 - Sebastopol, CA 95472, United States
    Expired
  • 2002 Mini R53: "Mk I" Mini Cooper S - Long block with single mass flywheel - Engine - Complete - $50 - Sebastopol, CA 95472, United States
    Expired
  • 2002 Mini R53: "Mk I" Mini Cooper S - 6-speed manual transmission - Miscellaneous - $300 - Sebastopol, CA 95472, United States
    Expired
My MINI DRIVER doesn't.
Reducing prices. I need to move on.
With lower prices, though, I'm not really interested in shipping things. It's time consuming for very little money.
The common shaft for the supercharger and water pump failed at 97k miles, puking oil and coolant on the highway before I noticed the pegged temperature gauge. It still started but the engine made noises and smoked when I parked it. I do not know the extent of the damage.
Parked it in July 2021 under a canopy. Purchased in March 2017 with just 47k miles on it from the owner's widow. It had sat for 3 years. Sonoma and Marin County, California car for its life, I believe, so no rust has been found.
Here's some of what's not available:
rear hatch, bumper and bumper cover
supercharger
door cards
complete exhaust system
passenger visor
hood, headlights and trim (going to make a cool awning for my garage man door)
passenger-side drive axle
mirror caps
power steering pump
rear shocks and springs
Some of what's available:
6 speed manual transmission
engine
radiator
A/C compressor, pump,
doors (sound insulated) A couple of dings.
front brake calipers with and rotors
alternator
radiator
fender trim ($90 new)
I will add more parts and photos as I have time.
Pickup preferred. Apple Pay and Venmo preferred as PayPal charges a fee.
Low ballers will be sent on your way.
Whatcha need?
Picture Title Part Category Price Part Description
inside door lock cable Accessories $7 Bought this cable and it wasn't the issue according to my mechanic.
Never mounted. Didn't return to Pelican as it was too much trouble and cost for a $17 part.
Pick up only.
https://www.pelicanparts.com/More_Info/51217143538.htm?pn=51-21-7-143-538-M26
Koni FSD shocks with factory sport springs (front only) Accessories $50 Maybe 20,000 miles on them. Springs are original to the car.
I don't see any leaks.
I tried Bilstein B4 shocks but the ride was too harsh with run flats.
I switched to Konis at the same time I got rid of the Bridgestone run flats, so, I don't know which had a larger effect on ride quality.
Needs new rubbers.
Panther leather interior non-heated Accessories $100 I replaced my torn vinyl interior with these leather seats.
Cheaper than reupholstering just the one seat.
We had to steal a part from my old driver's seat to fix the recline mechanism.
As a result, the adjustable lumbar doesn't work on the driver's side.
I did have an airbag light which may be the passenger seat according to my mechanic.
Some scuffing on the driver's seat entry bolster.
Invest $25 in some leather dye and a foam brush to make them shine!
Seats have been removed if you want more photos.
Manual Accessories $10 Good condition.
Case is scuffed.
Did anyone ever really get 33mpg?
tail light- driver's Accessories $15 The picture looks better than the real thing. Driver's side is a little cloudy.
Stock air box Accessories $20 All tabs are intact.
Includes ECU cover.
front bumper carrier beam Accessories $50 Aluminum front bumper carrier.
Not too keen on shipping it as the freight appears to be more than the part cost.
front crush tubes Accessories $10 front crush tubes
Long block with single mass flywheel Engine - Complete $50 Engine turns but there's glitter inside.
Single mass clutch and flywheel with about 40k miles.
I don't know the extent of the damage.
6-speed manual transmission Miscellaneous $300 97k miles. Out of the car now.
Shifted fine.
It seemed like there was a bit more effort required for 5 and 6 but I don't have anything to compare it to since I've only driven my MINI.
Old May 3, 2023 | 02:34 PM
djmini420's Avatar
djmini420
Rims
Hey there. Are the rims available? Would be interested.
Old May 3, 2023 | 05:51 PM
NomadMac's Avatar
NomadMac
Both sets of rims are still available.
Are you interested in the Enkeis or S Lites?
Old May 3, 2023 | 06:11 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
How much for shipping on coil n wires to 53154 ??? I am interested
Old May 3, 2023 | 06:44 PM
NomadMac's Avatar
NomadMac
I checked a couple of months ago on a flat rate box for USPS.
It was $15 as a recall. I have the boxes still.
Thanks for your interest.
Old May 3, 2023 | 08:50 PM
djmini420's Avatar
djmini420
Will the Enkie rims need hub ring?
Old May 3, 2023 | 10:42 PM
NomadMac's Avatar
NomadMac
They do not need hub rings.
Old May 4, 2023 | 07:24 AM
djmini420's Avatar
djmini420
Be careful. I think this thread is being hi jacked. I'm getting a response from user name Linconeous. That's why I'm so confused who sending me messages Nomadmac.
Old May 4, 2023 | 04:32 PM
MiniManAdam
Community Builder
ok , I will let you know if I can swing it on Sunday or not...
Old May 4, 2023 | 08:33 PM
Jonny's Avatar
Jonny
100% scammer scumbag. I can’t believe admin didn’t delete that account, that’s asking for trouble. He steals pics from the internet, even old classified ads from NAM, re orients them, and sends them to unsuspecting victims.
Old May 13, 2023 | 06:05 PM
bruski83's Avatar
bruski83
So, is this whole ad a scam? or is someone contacting people who post in the comments?
Old May 13, 2023 | 06:16 PM
Jonny's Avatar
Jonny
Ad is not a scam, but the member “ Linconeous “ is, and yes, he DMs people from comments. Delete any message you get from him.
Old May 13, 2023 | 10:05 PM
NomadMac's Avatar
NomadMac
Linconeous has been banned and blocked.
I've been offline most of the week as I've been dealing with family issues along with spending time with my youngest son, whom I haven't seen in two and a half years.
Old May 14, 2023 | 07:22 PM
Sto's Avatar
Sto
NomadMac- Enjoy your time spent with your son. Most Important ! what do you have as far as a radio - I have a stock boost audio sys on a 2003 S that has gone haywire.
Thx a bunch-
Old May 14, 2023 | 08:14 PM
NomadMac's Avatar
NomadMac
Thx a bunch-
I replaced the stock unit with a Pioneer with BlueTooth but it appeared that the left channel had gone bad over time.
There was noise in the speaker, I changed doors including the speaker and the noise was still there. It's not something I would feel comfortable selling to anybody as a proper working unit.
I got rid of the original amp when I had the radio installed. I needed the luggage room.
I'll see if I can remove the brake lines tomorrow. I'm kind of overwhelmed with projects including bottle feeding a lamb.
Best,
Martin
Old May 15, 2023 | 11:31 AM
EMIgaul's Avatar
EMIgaul
How much for the stock air box?
Old Dec 8, 2023 | 08:59 AM
BigDog9721's Avatar
BigDog9721
will manual transmission work on a 2007 mini? if so, how much?
Old Dec 9, 2023 | 07:56 AM
NomadMac's Avatar
NomadMac
The 6 speed transmission is $300 and has been removed from the car..
You'll have to check with others who are more knowledgeable than I whether it works with a 2007.
Old Jun 4, 2024 | 06:29 PM
smalltraveler's Avatar
smalltraveler
Part out
Hey I was wondering if you have the radiator support and if so for how much?
Thank you!
Old Jun 5, 2024 | 07:56 AM
scf's Avatar
scf
Hey, how much for the center stack switches? Ship to 03281(Weare, NH)?
Old Jun 5, 2024 | 10:19 PM
NomadMac's Avatar
NomadMac
Sorry, the radiator support is gone.
Martin
Old Jun 7, 2024 | 08:13 AM
scf's Avatar
scf
Center stack switches?
Old Jun 8, 2024 | 07:28 AM
NomadMac's Avatar
NomadMac
Sorry for being slow to reply. Been busy.
Do you need just the toggle switches or the climate control switches, too?
Partsgeek has the toggles for $216 + $10 for shipping. https://www.partsgeek.com/wdg64z6-mi...SABEgL3RvD_BwE
I'm thinking $70 shipped to you. If you need the climate control switches, make it $100.
Do you need the chrome covers for the switches? I removed them for a guy who wanted all the chrome dash covers and then flaked on me.
Thanks,
Martin
toggle switches
Old Jul 17, 2024 | 10:04 PM
SteveM333's Avatar
SteveM333
Supercharger
Hi,
I know this is an old threat. However, I'm trying to get my friends R52 back on the road. Long shot, but - Is your supercharger still available?
Steve
Old Jul 18, 2024 | 07:13 AM
NomadMac's Avatar
NomadMac
Supercharger
Originally Posted by SteveM333
Hi,
Steve
Hi Steve,
You’re a week too late. Bummer because I wasn’t getting any traction, I let it go for a hundred bucks to a local guy.
Martin
