43mm Turbo
Engine - Power Adders
  • Engine - Power Adders - 43mm Turbo - Used - 2007 to 2013 Mini R56: "Mk II" Mini Hatch/Hardtop range - Columbus, GA 31906, United States
    $400
    • OBO
  • Location Columbus, GA, 31906, USA
  • Compatibility
Make Model Year
Mini R56: "Mk II" Mini Hatch/Hardtop range 2007 - 2013
Anyone looking for an R56 turbo?
This is a 43mm (43/56) Quick Spool turbo with a Forge diverter valve. I received this turbo as a warranty replacement for a failed mQubed Motorsports (Mario kart, Mario Palza) 43mm turbo. This turbo developed a boost leak and rather than deal with another potential failure I replaced it with an OEM JCW turbo.
I've rebuilt this turbo and replaced every seal inside and out with new seals from Turbo Lab America. I also replaced the bearings with a true 360 degree thrust bearing and twin oil feed bearing.
Also included is the OEM diverter valve that came with the turbo and a Forge Motorsports N18 diverter valve.
This turbo was great and had no issue quickly spooling to 23lbs. The issue it had was, it could not put up with the sustained abuse of track use. I would absolutely not recommend this if you are using your car for track days (road course). It will be fine to daily when you want a little extra kick. It will probably work fine for Auto X and 1/4 mile stuff. Just not sustained lapping.
You will need a tune to make full use of it.
$400, open to offers.
Old Jun 26, 2021 | 05:11 AM
Yoshimura 1's Avatar
Yoshimura 1
There's no markings on the housing for the make up of it.
Old Jun 26, 2021 | 05:32 AM
scotty_r56s's Avatar
scotty_r56s
That's correct. As noted in my review of the turbo, there are absolutely no markings. This is what Mario sent me as a replacement for one of his failed turbos. I replaced the bearings and seals, so it should no longer have a boost leak.
Old Jun 26, 2021 | 06:06 AM
Yoshimura 1
Ohh okay thanks
Old Jul 8, 2021 | 08:06 PM
scotty_r56s
Sale fell through. Price drop, just want this thing gone.
Old Jul 9, 2021 | 07:12 AM
Yoshimura 1
Pm'd you
Old Jul 9, 2021 | 08:17 AM
MiniManAdam's Avatar
MiniManAdam
Community Builder
I'm a player in it for 400$ my buddy really REALLY could use that for his rebuild rite now..pm sent
Old Jul 9, 2021 | 03:46 PM
Yoshimura 1
Pm'd you
