Suspension Replacing Control Arm Bushings in Pairs??
Old Apr 24, 2007 | 04:40 AM
johnD's Avatar
johnD
Coordinator :: ClubMINI.ph
Hello,
I'm about to replace my right hand control arm bushing tomorrow as there is already a small tear in the rubber. This was probably due to my bad shock on that corner. The problem is I've just read the service manual and it says "Caution - Replace control arm bushings in pairs." I'm assuming they meant both sides. What is the reason for this? Would it matter that I only replace 1 as I have only 1 new bushing and it's pretty hard to get a hold of it in my area.
Thanks!
John
Old Apr 24, 2007 | 03:21 PM
meb's Avatar
meb
The compliance between new and old rubber can be quite large. The car will pull to one, brake to one side and in general, do things that won't make your day. In pairs for sure!
Old Apr 25, 2007 | 07:23 AM
cristo's Avatar
cristo
Alliance Member
Given the labour (drop the subframe) to get to them, I'd replace both at once.
Old Apr 25, 2007 | 07:34 AM
ChrisW's Avatar
ChrisW
Do both otherwise you'll be sorry for reasons stated above.
Old Apr 25, 2007 | 07:47 AM
meb's Avatar
meb
AND, replace the two inner ball joints as well! The subframe needs to be lowered/removed to get at these...you can also remove axles to replace the inner ball joints, but if the subframe is off, do it.
Old Apr 25, 2007 | 09:30 AM
defylogik's Avatar
defylogik
most things are better replaced in pairs.. brake rotors.. pads.. axles...struts.. yadda.
Old Apr 25, 2007 | 09:56 PM
johnD's Avatar
johnD
Ok ok, I get the picture!! Thanks guys. Do I really need to lower the subframe to do this? As I see it, it looks like I can get the control arm bushings out even without dropping the subframe. All I need to do is make a special puller to get it out, or buy the puller from MINI.
John
Old Apr 26, 2007 | 07:41 AM
meb's Avatar
meb
Drop the sub-frame! Life will be much easier...you'll think it not necessary until you get into the job. The tool sometimes get ledge in the boring...so drop the frame far enough to remove the bushing mounts.
Old Apr 26, 2007 | 09:59 PM
johnD's Avatar
johnD
Argh!! I thot i could get away with just using the tool. How hard is it to drop the subframe?
John
Old Apr 26, 2007 | 10:35 PM
002's Avatar
002
Are you replacing the bushings with stock or aftermarket? If stock, just the bushing or the bushing with the carrier? The stock bushings will need to be pressed into the carriers (if not replacing the whole unit) then the control arm will need to be pressed into the bushing. I don't think you will be getting the arm into the stock bushing without the factory tool or dropping the subframe.
The powerflex bushings are easier to install, especially getting the control arms into them.
I would recommend a beginner completely drop the subframe to work on it out of the car. T his way you can find a shop to press out the bushings if you don't have the right tools.
The subframe is not as bad as it looks. Remove the front bumper, pop the tierods, remove the outer ball joint and steering shaft bolts, remove/bend the exhaust heat shield and release the powersteering reservoir...
...Yeah, maybe this is an advanced job. It reall depends on your level of self efficacy.
If you are going to do it, there are a few people here, including myself, with experience and will help you through it.
Old Apr 26, 2007 | 10:37 PM
002's Avatar
002
Oh yeah, search this forum for "wishbone bushing install" That will give you some idea of what is involved.
Old Apr 26, 2007 | 11:57 PM
johnD's Avatar
johnD
Hmm.....sounds a bit tough to do, but I will be having a local shop here do the replacement, so it's their problem, I just want to give them an outline on how to do it. Why are the powerflex's easier to install? Was there an increase in vibration coming into the car with the powerflex bushings? This is the main reason I didn't go for powerflex bushings.
John
Old Apr 27, 2007 | 06:11 AM
k-huevo's Avatar
k-huevo
For dropping the subframe https://www.northamericanmotoring.co...23#post1420223 , for the thread referenced by 002 https://www.northamericanmotoring.co...ad.php?t=63869 .
For the Powerflex question there are many different answers; here is mine plus an alternative to pressing out the old and pressing in the Poly https://www.northamericanmotoring.co...ad.php?t=98700 .
Today I’m installing a new control arm bushing for one that only lasted 1,000 miles before loosing its internal fluid.
Old Apr 27, 2007 | 10:53 PM
002's Avatar
002
John
They are more difficult because the control arm has an interference fit into the bushing. Based on how much effort is required to remove the arm from the bushing, it is going to be tuff to get the arm back in without a special tool. The powerflex bushings just slide onto the arm.
I didn't notice any extra vibration, but it will hit a little harder on potholes, etc... I put these in a girlfriends car and she said they feel smoother.
W0TM8
Dec 19, 2019 07:50 AM
Toolman
Jan 20, 2016 06:50 AM
maestro39
Oct 27, 2015 02:38 PM
JPMontes3
Aug 23, 2015 01:26 AM
Minibeagle
Aug 13, 2015 10:00 AM
