Suspension What is better for a dropped MCS? FSD's or Bilstein SP's?
Old Feb 6, 2007 | 07:09 AM
johnD's Avatar
johnD
Coordinator :: ClubMINI.ph
First of all, I have an MCS with Eibach Prokit springs and stock dampers. The shocks are busted so it's time to buy a new set....which is a great oppurtunity to upgrade.
I use the car on weekdends on not so smooth / pretty bad raods, so comfort is one of the issues. But it will see a more trackdays now so I would like it to perform better in the track as well. Maybe 6-8 times a year.
By the way, are there different models of the Bilsteins? And are they compatible to an MCS with a build date of 04/02? The one's I found on MiniCarParts say they are only compatible on cars built after 06/02? Is this correct? How about for the FSD's? Are they compatible to all build dates?
Thanks!
John
Old Feb 6, 2007 | 07:18 AM
snid's Avatar
snid
FSDs are not designed for lowered cars.
Old Feb 6, 2007 | 07:21 AM
Larry Clemens's Avatar
Larry Clemens
FSDs work great if the drop is not too aggressive (less than one inch). FSDs work awesome with H-sport and H&R springs.
Old Feb 6, 2007 | 07:43 AM
johnD's Avatar
johnD
Hmm...I guess it won't work good with my Eibach's which drop the front 1" and the rear 1.2" Darn.
John
txwerks's Avatar
txwerks
The Bilstein SP's are stiff - stiffer than the SS+ struts by a fair margin. However, those with H&R springs was a rockin' combination - but somewhat of a beating on the street.
Old Feb 6, 2007 | 07:58 AM
ScottinBend's Avatar
ScottinBend
Go with the FSD's and a set of TSW springs.
Old Feb 6, 2007 | 08:02 AM
johnD's Avatar
johnD
Argh!! I was hoping to just change the dampers....now it seems like I have no choice but to change everything....or maybe just suck up the bad ride with the Bilstein SP's!
How harsh are the Bilstein's? I was told they are similar in technology to the FSD's, only stiffer?
John
Old Feb 6, 2007 | 08:03 AM
Mini Works's Avatar
Mini Works
take a look at the Koni Sport Yellow adjustable shocks,
They are designed to work woth lowered suspensions,
come with a lifetime warranty,
and are fully adjustable
victor
Old Feb 6, 2007 | 08:31 AM
Dr Obnxs's Avatar
Dr Obnxs
A couple of thoughs...l
most fixed height dampeners are designed to work with a certain spring. You can make some changes around this, but go to far and you find yourself where you are now.
So you've got a couple of choices.
1) Get a fixed strut that's close enough for you.
2) Get a package of struts and springs and sell off the springs you havfe.
3) Get some adjustable struts and have at it.
FWIW, there are coil-over set ups that show up in the marketplace. That can be a cost saver.....
Matt
Old Feb 6, 2007 | 08:35 AM
Mini Works's Avatar
Mini Works
The Koni Sport suspension kit is also an option,
4 Koni yellow adjustable shocks matched with 4 koni springs,
all that at a fraction of the cost of coil overs
victor
Old Feb 6, 2007 | 09:03 AM
txwerks's Avatar
txwerks
John
The internals are nothing like FSD's... I just got to see the insides of one the other day...
It's not that they ride "bad", it's that they are just firm...
Old Feb 7, 2007 | 04:31 AM
johnD's Avatar
johnD
Dr O.
When you said adjustable shocks, were you referring to something like the Koni yellow adjustable shocks?
To the rest:
Someone is actually offering me a set of Sachs Suspension Kit. It comes with eibach springs. The price is actually pretty good, the problem is i haven't heard anything about it. How about you guys?
I'm actually leaning more on the Koni adjustables right now, but if I will also be expriencing same problems as I have now, then I might be better off getting a complete set.
John
Old Feb 7, 2007 | 06:55 AM
txwerks's Avatar
txwerks
Sachs makes a lot of OEM shocks/struts and a lot of OE replacement parts... They've been around forever... And, Eibach we all know about. If Sachs did their homework (and they likely did), and matched their valving and chosen Eibach spring rates, I'm certain they are good...
Same goes for the Koni Sport Kit.
But, if you already have the springs, just toss on a set of Koni Yellows (aka Sport shocks). I think you'll like that much better than the Bilstein SP's - and the Yellows are designed for lowering springs (unlike the FSD's, which are only designed for OE ride height and/or slight lowering).
Old Feb 11, 2007 | 12:51 AM
johnD's Avatar
johnD
Thanks for the input.....my options keep changing, currently they are:
1. Koni Yellows
2. Tein Coilovers (they have in stock where I am and have heard great reviews, but the price is a bit ard to swallow. )
John
Old Feb 11, 2007 | 08:32 AM
Dr Obnxs's Avatar
Dr Obnxs
Remember the marketplace...
there are coil over set ups that go there pretty often. Also, Nuzzo is selling stuff off, you might want to contact him. I watched the marketplace when I found me Ledas, and I got them for $1000 instead of $1900. I had to get some different springs for the front, but that was only $150....
Savings is there to be had. Just have to be patient and look.
Matt
Old Feb 11, 2007 | 08:43 AM
mitchman's Avatar
mitchman
Couple of things:
1) The Koni Sports (yellows) are great shocks, but you can't get to the adjuster on the top of the rear shocks without removing them. It's pretty easy to remove them, but not the idea scenario.
2) The Bilsteins are non-adjustable, but.....you can send them to Bilstein and have them re-valved for $65 per shock.
Finally, lowered suspension with the correct shocks. If it was me, I would get the measurements from the bottom shock hole to the top of the body. It would interesting to see if one brand of shock is shorter than the other. A shorter shock will give you more suspension travel before you hit the bump stop. But then, you can always cut down the bump stop and almost accomplish the same thing.
Old Feb 12, 2007 | 06:51 PM
orthomini's Avatar
orthomini
ride
i have the bilstein sp/h&r spring combo. not anymore harsh a ride than the stock ride in the 03's but with great handling.
Old Feb 13, 2007 | 03:38 PM
sportek1's Avatar
sportek1
John
The Bilstein are monotube shocks, whereas the Koni Yellows and the FSD are twintubes.
Bilstein's demping force is higher at low shock travelspeed, so these feel more stiffer.
Old Feb 13, 2007 | 03:43 PM
sportek1's Avatar
sportek1
Mini changed the front shocks setup in 02. I do not know the exact date though. Simply said, they modified the front shock+spring setup to cater for more spring and shock travel. Therefore, all the German shock and coilover manufacturers also have changed their parts.
What year is your Mini?
Old Feb 18, 2007 | 07:58 AM
johnD's Avatar
johnD
My MCS is an '02 model. I've decided to get Koni Adjustable shocks! None of my first options! Thanks for the inputs.
John
Old Feb 19, 2007 | 09:01 AM
Phantom's Avatar
Phantom
1. Koni Yellows
John
I WILL ONLY USE KONI YELLOWS! I have a set on my 93 Rx7 and LOVE THEM!!!!
For my MCS I'm going to be getting Koni Yellows and Dinan springs, and I WILL stand by that choice, Dinan seems to have their act togeather so go by them. Tiens are crap at least I think so dont go with some product Japan for a europen car, go with a race and time proven Konis and a spring of you choice (I reccomend Dinan), thats made to handle, also if not already upgrade your rear sway bar to a 19mm (19mm is my choice dont want to much)
Old Feb 20, 2007 | 07:08 AM
Supercharged in Asia's Avatar
Well, my previous experience with Koni shocks were on my previous rides:a Miata and a Lotus Elise. Great shocks. But had Bilstein on another previous ride too: Porsche 964 too. Fantastic too. There is no question in my mind that Bilstein and Koni make amazing shock absorbers.
Have Bilstein sport with Eibach springs on my MCS currently. When I first put them on, they were harsh and there was a bit of rubbing under compression from potholes. I thought I had made a bad decision. However, after about 1,000 kms or so, the spring rate seems to have raised itself slightly (it rides higher then when first installed) and ride has become fairly supple (not as good as the ride on my mate's MCS JCW with FSDs though). Crucially, I made a nine second lap time improvement at my favourite local track. The only change was the suspension. My ride now corners flat, the suspension has virtually eliminated the strong understeer exhibited by the standard shocks and I get more feedback of road surfacing and conditions on this set up.
I would heartily recommend the Bilstein sports with the Eibach Pro springs. If I could have afforded it, I would have gone to PSS9s perhaps though!
Go for it!
jesterofatlas
Sep 1, 2015 11:26 AM
sabjcw
Aug 14, 2015 07:40 AM
Emnotek
Aug 13, 2015 05:47 PM
minipopkart
Aug 13, 2015 05:22 AM
robyb
Aug 8, 2015 06:04 PM
