Suspension JCW Strut Bar prevent mushrooming?
Old Jan 21, 2007 | 08:54 AM
Amygdaloid's Avatar
Amygdaloid
I know the topic of strut tower mushrooming has been discussed extensively, in particular the virtues and vices of the M7 Strut Reinforcing Plate and Strut Tower Brace. What I haven't seen discussed is if the JCW Strut Tower Brace will actually help prevent strut tower mushrooming.
So, what I am looking for is comments from any users of the JCW Strut Tower Brace to see if they have had any evidence of mushrooming developing AFTER they installed the JCW bar. I have not found any indication of this so far in my searching of NAM.
To me, it seems the mounting plate of the JCW Strut Tower Brace should offer enough stiffness to at least significantly decrease the potential of mushrooming compared to using no strut plate or bar at all.
From what I have read, mushrooming involves the strut bolts deflecting from the vertical as the strut dower deforms. The JCW mounting plate looks sturdy enough to hold the studs in there proper allignment, which should limit the chance of deformation.
Anyone care to offer evidence that they had mushrooming after they installed the JCW bar???
Old Jan 21, 2007 | 10:00 AM
minimarks's Avatar
minimarks
Have not seen any mushrooming with my JCW brace. I agree with you, it would seem like the plates would keep this from happening.. But I'm not an expert. Would also like to hear from others on this topic.
Old Jan 21, 2007 | 10:18 AM
Amygdaloid's Avatar
Amygdaloid
How long have you had the JCW Stut bar installed?
Old Jan 21, 2007 | 06:07 PM
minimarks's Avatar
minimarks
Since last September. 7000 plus or min. miles.. Also on '06 Cooper S.
Old Jan 21, 2007 | 06:19 PM
everytimeidie027's Avatar
everytimeidie027
I'm really curious to hear what others say, I had this same question in mind
Old Jan 21, 2007 | 09:50 PM
1nf3rn0's Avatar
1nf3rn0
I installed a JCW bar with 100 miles on my car. I had it on for 3000 miles. When I took it off to put an M7 STB on, i noticed significant mushrooming.
If you look at the JCW bar, you will understand why it doesn;t help prevent mushrooming. It simply doesn;t have enough strength to resist the deformation of the metal of the strut towers. I have nothing against the JCW bar. I only got rid of it because it wouldn;t fit over my Alta intake. I just feel that to effectivley prevent mushrooming you need something that has some mass like the m7 bar. It also helps to have a camber plate because it effectivley sandwhiched the strut tower between two pieces of strong metal.
Old Jan 21, 2007 | 11:49 PM
everytimeidie027
damn, well it looks like I'll buy the JCW CAI over the strut brace, since I only wanted to get the brace to prevent mushrooming
Old Jan 22, 2007 | 08:25 AM
1nf3rn0's Avatar
1nf3rn0
If you don't care about the handeling benefits of a STB (they are negligable anyways), you might want to look into the m7 STRPs. They are significantly cheeper than the JCW bar and will prevent mushrooming as well as M7's STB.
Old Jan 22, 2007 | 11:00 PM
everytimeidie027
Thanks I was thinking of buying these, I think I'll buy some after the JCW intake. oh and do you know if I'll have to modify the JCW intake if I buy the M7 strut brace?
Old Jan 22, 2007 | 11:02 PM
everytimeidie027
I just checked the M7 site and it says that the strut brace should clear the air box, I'm guessing that the JCW intake cant be that much bigger than the stock intake
Old Jan 23, 2007 | 12:06 AM
maxmini's Avatar
maxmini
The M7 brace will clear the JCW box with no issues.
Randy
M7 Tuning
Old Jan 23, 2007 | 10:20 AM
1nf3rn0's Avatar
1nf3rn0
It will also clear the Alta CAI, which is something the JCW bar cannot do.
Randy
M7 Tuning
Old Jan 26, 2007 | 11:13 PM
TMini's Avatar
TMini
JCW bar and Alta Intake
I have a JCW bar that clears my Alta intake with no problem? Although I do not have the full box around the intake...
Old Jan 28, 2007 | 03:30 PM
1nf3rn0's Avatar
1nf3rn0
Really? I'm suprised. On mine, with the JCW bar flus on one side, the other side was 3 inches in the air....
Mikli
R55 :: Clubman Talk (2008+)
Jun 26, 2019 05:58 AM
Dec 23, 2015 10:36 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
nomar116
Aug 10, 2015 11:24 PM
