Suspension IRELAND fixed 1.25 degree camber plates.
Old Mar 25, 2007 | 08:43 PM
  #126
mbotvinick's Avatar
mbotvinick
Competent would be the key word
You need to remove the struts. It could easily take 1/2 hour per side to do.
Old Mar 25, 2007 | 09:00 PM
  #127
SMSgt Bo's Avatar
SMSgt Bo
Originally Posted by Rich.Wolfson
How long did it take a competent mechanic to install the plates and what is a typical installation charge?
Rich
I think I still saved money over having a German mechanic do the work if you don't take the cost of aggrivation into account. We'll see if I have to tear it back down for adjustment.
I had the dampers, springs, and rear sway bar swapped at the same time and it ran almost $335 USD. With the time wasted for the rework (removing and reinstalling the plates in the proper positions and replacing a broken plate stud) it took nearly 12 hours.
Anyone know if Dinan Koni yellows come pre-adjusted?
Old Mar 26, 2007 | 05:27 AM
  #128
PGT's Avatar
PGT
yes - that's their idea of 'custom valved' they are identical to the off the shelf Koni yellows
Old Mar 26, 2007 | 08:55 AM
  #129
SMSgt Bo's Avatar
SMSgt Bo
I hope you're right. The kit came with installation instructions and one of the steps was to adjust the dampers all the way down then back off 1.5 turns. I asked the mechanic if he checked the adjustment before installation and of course he didn't.
If any of my guys performed maintenance like that I'd make sure they never turned wrenches on an aircraft again. Hmmmmm, maybe that's what happened to this guy.
Old Mar 26, 2007 | 09:01 AM
  #130
PGT's Avatar
PGT
'all the way down' meaning to full soft? Then, firm up by 1.5 turns? Same front and rear? If that's the case, then I came to the same conclusion as Dinan on my own.
Old Mar 26, 2007 | 09:02 AM
  #131
PGT's Avatar
PGT
I got that tidbit direct from someone at Koni and Victor at MINI Works told me that as well.
Old Mar 26, 2007 | 09:11 AM
  #132
SMSgt Bo's Avatar
SMSgt Bo
Oops, the secret's out.
Old Mar 26, 2007 | 09:14 AM
  #133
PGT's Avatar
PGT
can you confirm this?
Old Mar 26, 2007 | 09:26 AM
  #134
SMSgt Bo's Avatar
SMSgt Bo
Not 100% until I get back home to check the paperwork. I know it gave 1.5 turns front and back and I'm reasonably sure it was from full soft, but don't quote me on it.
conky
Apr 6, 2016 08:03 PM
wesmc
R55 :: Clubman Talk (2008+)
Sep 28, 2015 12:07 PM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
vargasgal
Sep 17, 2015 10:02 AM
veevsato
Sep 15, 2015 06:04 AM
