Suspension IRELAND fixed 1.25 degree camber plates.
Old Dec 20, 2006 | 08:40 AM
  #101
jymontoya's Avatar
jymontoya
I know where your rubbing (I'm running 235/40/17's). Its the spot i'm going to have to watch when I install these with my new Koni Coilvers.
Your rubbing your front strut below the spring perch. Turn your tires full lock right, then with a flashlight, stick your head under the drivers side wheel well... look up at where your tire is hitting the strut
You might consider using a 5mm spacer up front to take care of it.
Last edited by jymontoya; Dec 20, 2006 at 08:47 AM. Reason: left out which spot it was...
  #102
PGT's Avatar
PGT
hay, you cyan't say that on NAM! People might be get offensive it by.
Old Dec 20, 2006 | 08:43 AM
  #103
JustJAY's Avatar
JustJAY
Ok, BOT, so you can put a 225 on a X7. What would I have to watch for?
Old Dec 20, 2006 | 08:55 AM
  #104
PGT's Avatar
PGT
the sidewall rolls over a bit more than on a 7.5". More importantly, you need to worry about the actual section width and outside diameter (OD) of the tire you choose (not all same sized tires are alike!), the alignment, the offset of the wheel, and whether or not you are lowered. With a 225, you run the possibility of touching the interior edge of the rear plastic fenders (easily fixed with a Dremel), and I think the front struts are also a complication. There's a 'sweet spot' combo of everythign working together, thus most people stick to 215's. I know one person is actually running 235's, but on coilovers.
Old Dec 21, 2006 | 05:48 AM
  #105
etalj's Avatar
etalj
Originally Posted by Hammer
I just had the IE fixed camber plates installed, now my front tires rub when turning 90* left or right. Suspension is stock (except for the camber plates), I'm running a 225/45/17 tire on a 17X7 wheel (on the street - I run 16's for AX) with ET42. Anyone else have a rubbing issue? I know 225 is a lot of tire, but I like the look and feeling of security with all of that rubber. I haven't had a chance to to see what part of the tire is rubbing what part of the fender, but if others have already had this issue can you point me in the right direction?
Thanks!
i reckon 225 is too much. I don't reckon you'll get anymore grip
Old Dec 21, 2006 | 12:56 PM
  #106
Hammer's Avatar
Hammer
But all of that tire on the Mini just looks so
Old Dec 21, 2006 | 07:38 PM
  #107
jymontoya's Avatar
jymontoya
I 'reckon' you dont know just how much grip there is to be had... try 235's, then we'll talk.
Old Dec 21, 2006 | 07:42 PM
  #108
PGT's Avatar
PGT
what else is needed beyond springs and struts and camber plates to assemble a complete bolt-in set? spring seats and rear tophats?
Old Dec 23, 2006 | 06:07 AM
  #109
etalj's Avatar
etalj
:D good point. It does look tough.
Or we could just not talk at all
Old Dec 23, 2006 | 06:53 AM
  #110
robino's Avatar
robino
didn't have time to read the whole thread but let me get this straight...
these are fixed at 1.25" negative camber? So there's no adjustment to be done, just install and voila'...instant 1.25 camber?
Old Dec 23, 2006 | 07:32 AM
  #111
jymontoya's Avatar
jymontoya
correct. unless u are lowered. then the camber will be slightly more negative.
Old Dec 23, 2006 | 07:52 AM
  #112
robino's Avatar
robino
ahh...
so if i had a set of KW version 1 coilovers lowered 1.5-2"...what would be the final neg. camber? And would i be better off going to a more adjustable set of camber plates at that point so as not to have too much neg. camber?
Old Dec 23, 2006 | 10:06 AM
  #113
k-huevo's Avatar
k-huevo
If you don’t have time to read at least look at the pictures and much will be revealed.
With the Ireland Fixed Camber Plates and two inches lower ride height than stock, negative camber around two degrees or more could be expected after the bearing bushing has settled.
Old Jan 8, 2007 | 12:50 PM
  #114
THE ITCH's Avatar
THE ITCH
I just spoke with Ireland Engineering on the fixed plates.They told me that the fixed plates would add -1.25 to whatever your stock MINI front camber specs are. Presently after having an alignment done I have -0*47" R, -0*46"L. So what they are telling me is that with these fixed plates I should end up with -2* on both sides. Another point of interest is that your strut will move approx 1/3" for each degree change. Right now with the GP up on jackstands and the wheels straight I have enough room to put my fingers between the springs and the fender well in the tightest area. So it looks like, with a little luck I would not have to massage the fenders.
Steve
Old Jan 8, 2007 | 01:00 PM
  #115
PGT's Avatar
PGT
i just picked up Ireland's adjustable plates. They weren't much more than the non-adjustable ones....something to keep in mind.
Old Jan 8, 2007 | 06:07 PM
  #116
Fatherdeth's Avatar
Fatherdeth
I was told that the Ireland fixed plates and lowering springs would not cause more negative camber. Mine do not look that extreme, however I will need to do some measurements to be sure.
Old Jan 9, 2007 | 11:09 AM
  #117
robino's Avatar
robino
sweet setup right there...235's look good.
Where'd you get the Motegi Trak Lite 2.0's wheels??
with more neg offset you can possibly tuck those tires in a little more
off topic: what scoop are you running there?
Old Jan 9, 2007 | 11:47 AM
  #118
TampaMCS's Avatar
TampaMCS
Yes they will. My JCW's + the plates ended up at -1.7 and -1.92. L+R. Add a lower spring to that, by nature it will cause you to find more negative camber. Not loads, but you will find some.
Old Jan 9, 2007 | 07:34 PM
  #119
mangotangoe's Avatar
mangotangoe
How much of a difference between L/R camber would be considered "bad" and cause a pull?
Old Feb 22, 2007 | 06:06 PM
  #120
JustJAY's Avatar
JustJAY
I put the IE fixed camber plates on with H-Sport springs and have no negative camber. The front wheel sits straight up and down. In another thread I posted this and I believe it turns out that I have them installed incorrect . I believe I have to switch them, which is not going to be fun.
Old Feb 22, 2007 | 07:08 PM
  #121
PGT's Avatar
PGT
oh man....no fun at all. I've yet to get my adjustable plates on
Old Mar 25, 2007 | 10:13 AM
  #122
SMSgt Bo's Avatar
SMSgt Bo
Originally Posted by weezer2282
I thought the strut nut was supposed to be closer to the engine. It was definetly further away from the engine though. Something is not right.
Thanks Keith.
You guys are the HEAT!
I did my homework and read this thread thoroughly before having my IE fixed Camber Plates installed.
The plates went in the same time as my Dinan Stage 2 suspension by a local "suspension specialists". Knowing from this thread that the plates could be put in backward, I pointed out that with the plates installed the strut mounts should be offset inward. The “mechanic” assured me he knew what he was doing and proceeded to install them backwards.
When I picked up the car the shop manager told me the “mechanic” wanted to talk to me about my alignment. I popped the hood to confirm my worst fears. When I caught up with the "mechanic" he told me the camber plates were junk and I needed adjustable plates.
He said he couldn't get any negative camber on it at all. Hmmmm, do you think they could be in backward, I asked. They only go in one way, he said. You should have seen his face when he looked at the old plates and realized they were symmetrical. He swapped the plates around and my wife says everything seems cool now. I won’t know for sure until I get back home in May.
I’m an FAA certified aircraft mechanic and I kick myself in the @$$ for trusting my baby to an obvious hack. I was rushed to get the suspension installed before going on a two month deployment. I would have waited but there was a rebate on the suspension if it was installed within 30 days of delivery.
I should have just paid the extra Euros to have the dealership take care of it. Because of my haste I’ll have to pull everything apart once I get back home. Turns out Ol' Boy just slapped in the Koni’s and never checked their adjustment.
Old Mar 25, 2007 | 10:31 AM
  #123
caminifan's Avatar
caminifan
Originally Posted by SMSgt Bo
...I’m an FAA certified aircraft mechanic and I kick myself in the @$$ for trusting my baby to an obvious hack. I was rushed to get the suspension installed before going on a two month deployment. I would have waited but there was a rebate on the suspension if it was installed within 30 days of delivery.
Not meaning to pour gasoline on a smoldering fire, but my experience has been that everytime I rush something, I end up regretting it. I wonder if the savings from the rebate have been eaten up by having to re-do the install?
Old Mar 25, 2007 | 06:19 PM
  #124
mbotvinick's Avatar
mbotvinick
Same thing happened to me. I went out the check the alignm of the car after they isntalled the plates and he told that he was getting about 1 degree positive. I told him that he put the plated in backwards. So another few hours and voila, neg camber. They work great now.
Old Mar 25, 2007 | 07:53 PM
  #125
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by mbotvinick
...So another few hours and voila, neg camber....
How long did it take a competent mechanic to install the plates and what is a typical installation charge?
Rich
