Suspension Urgent help needed!!!...Megan Coilovers
Old Aug 4, 2007 | 09:58 PM
  #326
cooper99's Avatar
cooper99
Originally Posted by cooper99
Do you have to take back off the entire front shock assembly to lower the damn car?
I hope there is an easier way...
Old Aug 4, 2007 | 10:02 PM
  #327
Rally@StanceDesign's Avatar
Rally@StanceDesign
So MSFITOY are you running the new front springs on your Megans? Do you have to take back off the entire front shock assembly to lower the damn car?
HUH? I don't even remove my wheels. Why would you remove the front assembly to lower it??? Can you not fit the wrench in there or something?
Lowering coilovers is simple. Take the spanner, loosen the bottom ring. Take the spanner and move the middle ring up or down depending on what height you want. Take the spanner and tighten the bottom ring.
Old Aug 5, 2007 | 05:41 AM
  #328
sprp85's Avatar
sprp85
i found its imposible to do so without removing my wheels
do u crawl underneath or just stick ur hands in thru wheels or something?
Old Aug 5, 2007 | 07:35 AM
  #329
Rally@StanceDesign
I have 15s with 205/50s which are a measurable amount smaller in diameter from stock size or 17s so i have plenty of room when the car is just lifted a little with a jack.
Old Aug 5, 2007 | 08:24 AM
  #330
MSFITOY's Avatar
MSFITOY
I have to remove my wheels to adjust the height...spokes are too close and there's no way to get enough leverage on the lock rings from behind...
My wheel arches are 23.5" from the ground on all four corners and still have plenty of travel...two adults and full load crossing intersection crests at speed...never bottom out...rides better than my Cadillac STS4...
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
iwant2knowwhois
11
Sep 19, 2015 12:18 PM
elightbo
Aug 17, 2015 01:50 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
