Suspension Urgent help needed!!!...Megan Coilovers
Old Dec 5, 2006 | 04:28 PM
  #301
kurvhugr's Avatar
kurvhugr
Assuming you mean the Eibach coilovers, I haven't seen rates anywhere. I have a larger version of that pic where you can read the numbers on the springs but the #s on the fronts are just the part number for the kit and the #s on the rears make no sense to me at all.
Old Dec 5, 2006 | 04:42 PM
  #302
sportek1's Avatar
sportek1
The Eibach and KW are using progressive front springs.
Old Dec 5, 2006 | 07:10 PM
  #303
kurvhugr's Avatar
kurvhugr
Sorry but neither the Eibach nor the KW front springs look progressive to me. In fact, I think I remember KWs with tender or helper springs.
Old Dec 5, 2006 | 07:14 PM
  #304
kurvhugr's Avatar
kurvhugr
I'll take part of that back. I've seen KWs with progressive front springs and KWs with linear front springs, depending on the version.
Old Dec 6, 2006 | 05:41 AM
  #305
meb's Avatar
meb
Some of Eibach's basic kits come with progressive rate springs. But you can always change these out for something else.
Old Dec 6, 2006 | 08:16 AM
  #306
sportek1's Avatar
sportek1
KW and many European coilover manufacturers changed their street spring designs around 2001 to enable for a longer stroke.
Only their race versions come with lineair springs (and sometimes helper springs), since most tracks are relatively flat
Old Apr 17, 2007 | 07:56 AM
  #307
ltz_mtr's Avatar
ltz_mtr
This thread sort of died out - is there any further news on the subject? As a couple other folks have menetioned, it does seem the entire strut body could be lengthened, as the strut stops about 1" above the bottom of the strut knuckle on the front axle.
Old Apr 17, 2007 | 08:07 AM
  #308
MSFITOY's Avatar
MSFITOY
I'm still dumbfounded by this whole controversy...I've had my set of Megans, lowered, cornered balanced for over a year and couldn't be happier...Plenty of travel, supple ride, never bottomed out in valleys, near air launches over crests and extremely hard cornering transitions in both directions...could there have been a bad batch of struts that were circulated?
Old Apr 17, 2007 | 08:18 AM
  #309
Rally@StanceDesign's Avatar
Rally@StanceDesign
word still no problems here and i'm close to no threads on the coilovers..slammed. Even faired well in the ohio winter with the potholes etc
Old Apr 17, 2007 | 12:14 PM
  #310
Megan Racing's Avatar
Megan Racing
Vendor
Wow.. who brought this back? RallyMini and MSFITOY, don't you guys both have like 15" wheels?
Old Apr 17, 2007 | 12:37 PM
  #311
MSFITOY's Avatar
MSFITOY
NOpe...spokeless 17" TDR
Old Apr 17, 2007 | 01:05 PM
  #312
Megan Racing
Vendor
"There was no doubt about it.. MSFITOY was 'The *****'."
Old Apr 17, 2007 | 01:19 PM
  #313
Rally@StanceDesign
I've run 15s and 16s....my 15s have very low profile tires as well which should theoretically be worse? i think
I'm pretty sure wheel choice isnt the difference here though....nor is ride height
But I'm not complaining
Old Apr 17, 2007 | 05:29 PM
  #314
defylogik's Avatar
defylogik
like the great phoenix, this thread has risen up out of the ashes of NAM lol
Old Apr 17, 2007 | 05:38 PM
  #315
MSFITOY's Avatar
MSFITOY
What do you mean "was"?
Old Apr 18, 2007 | 04:43 PM
  #316
ltz_mtr's Avatar
ltz_mtr
MSFTITOY, so that's what my stoptechs look like to "outsiders"!
I have to admit, I have been tracking my MINI with the Megans, and I can't say I have had issues (although it is my only point of reference, so if I am, how would I know anyway...). However, I don't get a lot of suspension travel, so when I do drive on the street with it, I avoid any large bumps or holes like the plague (but then again why wouldn't you anyway).
Soooo, I thought I would raise this thing from the dead to see if any other updates or changes had happened. By the sounds of it I am guessing no.
Old Apr 19, 2007 | 09:44 AM
  #317
meb's Avatar
meb
Bumpstop + short travel or long dampers = contact. Bumpstop contact with top of damper = instantaneous infinite spring rate which = instantaneous slide.
The fix? Shorter bumpstops + heavier spring rate up front - from 285 to 469...but the new 469# springs are the same length as the 285# springs...heavier spring rate = bigger coils...bigger coils = less spring travel...less travel = spring bind - all else equal.
I found all these problems at the track. Steve is sending new stuff out.
Old Apr 19, 2007 | 05:05 PM
  #318
jammin636's Avatar
jammin636
what new stuff? are u just talking about the new bumpstops and springs/?
Old Apr 20, 2007 | 09:04 AM
  #319
meb's Avatar
meb
Yes.
Old Apr 24, 2007 | 01:08 PM
  #320
meb's Avatar
meb
Referring to post 317...
When the damper makes contact with a hard rubber bumpstop, the spring rate - which has nothing to do with spring rate but is only a comparison - becomes infinitely stiff - like no suspension at all - Flinstone style. Thusly, an immediate slide will result.
now, some systems are designed to work with bumpstops; the mini's stock suspension is a bumpstop active system in whcih the bumpstop works like a spring as it contacts the damper - by design. No slide here.
Does this clarify???
Old May 25, 2007 | 07:46 PM
  #321
Wagnbat's Avatar
Wagnbat
I'm liking the new springs so far... Only got to ride on them a few days before shipping the car off to Guam (still waiting another 2-3 weeks for it to get here)... But combined with the new tires (Pzeros over Proxes4) with more sidewall, the ride is much more comfortable.
Old Aug 4, 2007 | 08:29 AM
  #322
cooper99's Avatar
cooper99
Starting up an old thread, can someone take a picture of thier car's stance then also of the actual Megan coilovers with the wheels off? I need help adjusting mine because I just installed the new stiffer front springs and not too sure what's the optimal setup.
Old Aug 4, 2007 | 08:47 AM
  #323
MSFITOY's Avatar
MSFITOY
just kiddn...
Here's some...
Old Aug 4, 2007 | 09:14 PM
  #324
cooper99's Avatar
cooper99
So MSFITOY are you running the new front springs on your Megans? Do you have to take back off the entire front shock assembly to lower the damn car?
Old Aug 4, 2007 | 09:28 PM
  #325
MSFITOY's Avatar
MSFITOY
Nope...installed it and forgot about about it...don't know what all the fuss is about...rides great and never crashes even when I practically get airborn...
