Suspension Webb Motorsports Extreme Swaybar
Also having trouble contacting Randy
Hey THEITCH, I placed an order with Randy almost three weeks ago, have called three times, and sent four emails with no result. I'd like to cancel the order but I can't get a hold of them so it's not just you. I don't want to bash as I'm new to the MINI scene and have little experience with most of the vendors but I wanted to share my experience. Hope this helps.
I too have been trying to order a rear swaybar from him for the last 3 weeks. It shows he has 11 in stock.
Left messages and emails. He replied last week to one email saying he will call me that week... but nothing.:impatient Very frustrating to say the least.
www.bmw2002.com <---- their website
It's not all fancy and red......but it's "infinitely" adjustable and their customer service isn't lacking
ireland engineering sells a swaybar that works in the same way and is much less expensive......and best of all, you are actually able to order the part and have it shipped
He's moving? Where's his new shop location?
BTW,I believe he is a full time pilot too...
He is moving his shop back to his home iirc. He is a full-time pilot for United as well. You really need to catch him on a good weekend. Otherwise, Alta is open ALL THE TIME!!! I love my setup!
The WMS extreem sway bar can be purchased direct from the designer.
Tarett Engineering, 858-674-5573, tarett.com.
He is a very nice guy and very responsive. I have had none of the problems that I have had with Randy.
Steve
Steve
I have Alta 22mm rear bar, set on softer setting and it is excellent. No service /maintenance issues at all. Unless you are a racer, it does not make sense to me to make suspension too complicated.
Answered the phone first ring and had it shipped with a tracking # the same day...
should get it on Wed... can hardly wait to put it on.
daniel
Winnar!
Dab
I'm sure that you will not be dissapointed. If you do not want to save your original bar (replacements can be had pretty cheap if you ever needed one) you can just cut off one side and just pull it out. That will save you from dropping the rear subframe and a re-alignment in the rear. I used an abrasive cut off wheel in an electric drill (purchased from a hardware store for about $8.00) and had the old bar out in about 10 minutes.
Enjoy, Steve
Enjoy, Steve
Dab
Enjoy, Steve
Enjoy, Steve
I just hope Dab has it in by this sundys track day, thats all i can say. You listening Daniel? hahaha. I guess i dont have to Worry about that, so long as it arrives in the mail.
Beecher
Beecher
Where did you set the stiffness? I am 2 large marks from the stiffest setting with stock sport suspension.
I am pleased and suprised at its performance. Not sure why it reacts that way but that was my first track day with the bar and that was my experience. Will have to wait for the next lapping day to play with it more.
daniel
I am running KW2 coilovers and a cooper front bar so my settings would be different. But what i can tell you from my track day is that the bar felt quite different from the H-Sport Comp i had on before. The track has alot of 60km/h transisions and one higher speed sweeper starting in 2nd gear and shifting to 3rd then 4th on exit. I found with the h-sport when adjusted for good rotation with the lower speed transitions... the car was understeering (plowing) through the high speed sweeper. With this new bar, the high speed sweeper was very planted with no plowing and i was able to keep the gas on much more through the whole turn resulting in a much faster exit speed....And in the lower speed turns i would have to push the car much harder to get oversteer. I'm sure i could have stiffened the bar more since the lower speed transitions could have done with more rotation but had no time.
daniel
daniel
-Brian
vetsvette
Oct 20, 2015 07:42 AM
Colt45Magnus
Oct 1, 2015 04:08 PM
