Suspension coilover install
Old Dec 10, 2005 | 02:17 PM
jonsibal's Avatar
jonsibal
coilover install
I'm a bit new here but my wife have owned her MC since 02. I'm finally getting around in fixin it up a bit.
I'm wondering how involve is the installation of coil overs for MC. I'm thinking of doin it myself but not sure if there are any special tools required.
I'm considering the H&R coilovers. Does this require cutting the bump stops?
Also, do most of you who have installed this did an alignment job afterwards? Thanks.
Old Dec 13, 2005 | 06:46 PM
kenchan's Avatar
kenchan
the only 'special tool' you might consider special is the socket you need to
loosen the front strut piston shaft nut if you plan on using the factory
mounts.
i cracked loose the nut while it was on the car and used a 1/2" drive
socket and channel lock to loosen the nut while I held the piston in
place with an hex key. a little tricky at first, but no big deal.
i believe coilovers come with its own bumpstops, but if not, you can
cut the factory bumpstops if you are planning to lowering it quite a
bit. (koni also sells progressive rate bumpstops which are pretty cool).
if you plan on lowering more than 1", it would be a good idea to
get an alignment after you get your corners balanced.
goodluck an post picts when you're done.
Old Dec 13, 2005 | 07:14 PM
Android993's Avatar
Android993
Small correction on the alignment, the corner balance and the alignment have to be done at the same time. Changing one, changes the other, small amounts but it can make a difference. Just make sure the shop does both at the same time, its really worth it. You can do the alignment w/o the CB and if you want but why do just half a job on it. Go all the way and really enjoy it.
Old Dec 13, 2005 | 09:42 PM
kenchan's Avatar
kenchan
oh yeah, and a little further comment forgotten by Android993, make
sure you are in the car while they conduct the corner balance and
alignment. why do a half assed job if you're not specifically in the car.
smart ***
CORRECTION: oh and another thing, make sure you get adjustable endlinks
too which Android993 and I also FORGOT to mention. he's still a newb so
cut him some slack.
Old Dec 14, 2005 | 11:11 AM
jonsibal's Avatar
jonsibal
Thanks for the info guys. I appreciate it.
So no need for spring compressors either huh. I'm considering the H&R coilovers. I just ordered the Bentley Service Manual to do more reading so I can figure this out.
Thanks again.
Old Dec 14, 2005 | 12:01 PM
fj0's Avatar
fj0
Glad to see you around here Jon.
Can't really help you out though, good luck!
Old Dec 14, 2005 | 12:40 PM
kenchan's Avatar
kenchan
If you don't plan on using the stock mounts, you won't need it.
Thanks again.
Old Dec 14, 2005 | 12:47 PM
JeffS's Avatar
JeffS
Everyone's entitled to their opinion I suppose. My 2 cents is that corner balancing a street car is a waste of money - even if you know of a cheap place to get it done.
Old Dec 14, 2005 | 01:04 PM
kenchan's Avatar
kenchan
^^^ +1
although i am starting to think i might just get it for dressup
purposes mostly since my dampers will probably start giving out
pretty soon. not concrete yet on the direction.. that, or the
Koni Yellow's probably.
Old Dec 14, 2005 | 01:10 PM
Android993's Avatar
Android993
As my friend says "a seat for every *** and an *** for every seat" to each his own. If its only a street car, sure skip the corner balance and be happy knowing you didnt do it, and just wonder why people have it done.
PS: Kanchan thanks for being a smart *** too and picking up our mistakes, hate to see us leave something out.
Old Dec 14, 2005 | 01:20 PM
kenchan's Avatar
kenchan
that's kenchan with a "e" you ****!
From a dressup perspective it's not so critical to get it corner balanced,
but to get just the right amount of drop and wheel gap. with springs
you kinda only have one stab at it while with coilovers you can play
around with the height until it's eyeball perfect.
As my friend says "a seat for every *** and an *** for every seat" to each his own. Why do coilovers then, just plop on some M7 springs and be lowered?!
If its only a street car, sure skip the corner balance and be happy knowing you didnt do it.
PS: Kanchan thanks for picking up our mistakes, hate to see us leave something out, smart ***
Old Dec 14, 2005 | 01:36 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Yah, im so used to drooling over pics of your car on DTMpower....welcome
Old Dec 14, 2005 | 01:51 PM
Itsdchz's Avatar
Itsdchz
H&R coilovers require you to cut your factory bumpstops, they do not come with them. By a new set, that way you just have to pull the stock components of as a whole, and not tear anything apart.
Old Dec 14, 2005 | 08:19 PM
Android993's Avatar
Android993
Your right again!! Rats! Kenchan, Kenchan, Kanchan - I tried saying it three times really fast but still couldnt get it straight.
Old Dec 14, 2005 | 08:52 PM
ScuderiaMini's Avatar
ScuderiaMini
you gotta learn how to leave with him, but he is a good source and a good friend, you gotta keep an eye on our head bumps time to time
KEEEEEEEEEEEEEEEEEENNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN , I HATTTTTTTTTTTTTTTTEEEEEEEEEEEEEEEEEEEEEE HONDASSSSSSSSSSSSS
Old Dec 14, 2005 | 10:26 PM
kenchan's Avatar
kenchan
hey berky, I still can't spell your new name right... scudelieriousMINI? scudileriousMINI?
Old Dec 15, 2005 | 08:48 AM
jonsibal's Avatar
jonsibal
Mario and RallyMINI, thanks for the welcome. I've been a lurker here and really enjoyed the wealth of information in this board.
Still working on my E36 though. That money-pit is never gonna be done
Old Dec 15, 2005 | 01:44 PM
Android993's Avatar
Android993
LOL
At least eveybody has a good sense of humor.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
