Suspension Coilovers - Which to buy????
Old Dec 1, 2005 | 06:23 PM
nparker's Avatar
nparker
I'm looking to change from my H-Sport springs and get coilovers for my ride. I'm on a budget and want to get them by the end of next week. Here is my list of what I can afford to get. If anyone has experience with any of these, please give me your opinion.
Koni - adjustable damper
H&R
Tein:Basic
Spax - adjustable damper
These are all about $1K.
Help!!
Old Dec 1, 2005 | 06:34 PM
newbs49's Avatar
newbs49
I guess we need to know what your going to use your car for. Is this just for looks, ride, auto-x, track days, or a combination of these.
Old Dec 1, 2005 | 07:06 PM
90STX's Avatar
90STX
I had good luck with a set of SPAX. They worked well for autocrossing, and could also be adjusted to give a ride very similar to stock (or even softer). Of course you could also set it dramatically stiffer than stock.
Some folks have hinted at quality problems, but I didn't have any. I have PSS9s now, and there are times that I miss the SPAX.
Scott
90SM
Old Dec 1, 2005 | 09:22 PM
matma92ser's Avatar
matma92ser
What is it about the SPAX that is better/different than the PSS9? I am considering the PSS9 so I am very interested in your opinion of how they compare with others.
Old Dec 2, 2005 | 07:18 AM
nparker's Avatar
nparker
Want it about 1/2" lower, maybe a few days on the track or auto-x.
Old Dec 2, 2005 | 11:27 PM
90STX's Avatar
90STX
Spax vs PSS9s
Bilstein damper body and shaft design is far stouter, and thus will defect less under load, in theory - winner PSS9
Adjustments - both can be reached without removing anything, but SPAX are much easier to use. SPAX have much more noticable detents, and they are evenly spaced. Bilstein "clicks" are much softer, though they have gotten easier to feel with use. There is a big step between 1&2, and 8&9 on Bilstein, with 2-8 very close together. Damper adjustements have similar felt change for each click on SPAX, while Bilstein is less linear. - winner SPAX
Springs - PSS9 spring rate is higher than SPAX. SPAX are linear rates front and rear, Bilstein are linear in rear and progressive in front. - I'll call it a toss-up, with a possible bias towards SPAX
Street feel - highly subjective and road quality dependent - streets here in Indiana are pretty cr@ppy, with frost heaves and lots of seams. SPAX were far more comfortable on these surfaces, and could be adjusted very close to stock ride feel (around 8-10), a bit firmer and "sportier" (12-15), or softer (5-7). Anything softer got sort of floaty and 70's Cadillac like. PSS9s at 9 (softest) in rear still transmits some seams as a sharp impact. Fronts at 9 less so, probably due to the progressive springs, but pavement ripples put the car into choppy oscillations despite trying a variety of settings, something the SPAX never did.
Autocross - the SPAX set at 24-28 depending on course and surface felt very good. Even at 28 (full stiff) the tires never lost contact with the track over bumps. Turn in was very immediate, especially with front damper settings approaching 28. I tried the PSS9s because I wanted to experiment with stiffer springs and damping, which they do have. The first two events they were brutal set on 1, but after that they seemed to wear in a bit and are now much better. They feel great except for intial turn in, where the front feels like it rolls more than the SPAX did. Again, this is probably because of the progressive front springs. I have to say that the behavior and grip of the SPAX were probably very close to the PSS9s (better in slaloms, maybe not quite as good in sweepers, but very subtle difference). I can't tell a difference using a g-cube, but of course autocross courses don't repeat like tracks so it is tricky to quantify. I suspect that the Bilsteins would be superior on a race track, but the SPAX were a definite improvement over stock too. I'll call it a tie, but I lean slightly towards SPAX.
Finish - the Bilsteins are impressive, but I had to send my first set back due to finish coating and weld defects. Return service was excellent. Bilstein is the winner so far, but I've only had them for about 25K miles while I put 40K on the SPAX before swapping. As I said before, I've heard of others having problems with SPAX, but I didn't.
Scott
90SM
Old Dec 3, 2005 | 05:27 AM
SpiderX's Avatar
SpiderX
Spax vs PSS9s
Scott
90SM
I never tried the SPAX but after reading this review I probably would have......I really like my PSS9s vs stock and then Koni/H sport
Old Dec 3, 2005 | 10:55 PM
matma92ser's Avatar
matma92ser
Spax vs PSS9s
Wow, thanks Scott! That was very thorough and informative!
matt
Ryan Caballo
Sep 10, 2015 10:10 AM
OutMotoring
Sep 8, 2015 06:27 AM
RIchard Nguyen
Sep 6, 2015 07:21 PM
Ryan Caballo
Sep 4, 2015 12:20 PM
