Suspension Torque Specifications / Specs
Old Jul 18, 2005 | 12:11 PM
LordOfTheFlies's Avatar
LordOfTheFlies
Hi all,
I was wondering if we could start a thread so that eeveryone who was into DIY projects could easily find the torque settings they needed.
I recently checked my plugs and made sure they were at 20 ft. lbs.
Lug nuts were set to 80 ft. lbs.
Does anyone have the settings for the brake caliper bushing pins? I changed out my pins but I couldn't find what the correct torque setting is.
Since I had to change out my rotors (cross drilled holes started to crack) I had to remove the 16mm bolts that hold the caliper in as well and I couldn't find the torque setting for that either.
So let's start a list and anybody who has any additional items to add to the list, please post it up. Thanks.
Note: if you have Nm values, multiply it by .74 to get the ft-lb value (according to Nick T.)
This is what I've got so far.......
Description -- Torque ft. lbs/Inch.lbs
1) Lug nuts - 80/960
2) Spark plugs - 20/240
3) Strut tower bolts - 25/300
4) Oil Drain plug - 23/276
5) Oil filter housing - 18/216
6) 17% Alta Pulley - 6.67/80
Looking forward to a nice big list here.....Let me know if people would find this useful....
Old Jul 18, 2005 | 12:27 PM
ingsoc's Avatar
ingsoc
great idea! nothing to add though .
Old Jul 18, 2005 | 01:55 PM
mini-rolls's Avatar
mini-rolls
Aftermarket Supercharger Pulley 80in lbs
Old Jul 18, 2005 | 01:59 PM
mmMatt's Avatar
mmMatt
Not quite true, as the materials the pullies are made out of differ greatly. Alta makes their pullies out of stainless, whereas we use 6061 aluminum. We use grade 10 bolts, they may use something different. It's the little things that count when figuring a good torque spec.
Old Jul 19, 2005 | 09:42 AM
betet's Avatar
betet
What about we PM/post the torque specs and you just keep editing/adding what we send.... so at least it stays on the 1st page.. Just a suggestion..
But anyhow great idea..
///Gilbert
Old Jul 19, 2005 | 09:55 AM
LordOfTheFlies
Sure, that works......Anybody out there with any other specs?
Old Jul 21, 2005 | 06:37 AM
NeilM's Avatar
NeilM
Originally Posted by LordOfTheFlies
Hi all,
I was wondering if we could start a thread so that everyone who was into DIY projects could easily find the torque settings they needed.
If you're in to DIY Mini projects you should invest - and yeah, it's not cheap, so it is a bit of an investment! - in a Bentley shop manual, which will also give you all the torque values you need.
Neil
05 MCS
various other cars
Old Jul 26, 2005 | 03:27 PM
mataku's Avatar
mataku
i was hoping some more numbers could get added to this.. numbers i'm looking for:
rear strut top bolt
rear strut bottom bolt
sway bar bolt
if anybody could give me the specs for these that would be really handy, I placed the wires wrong when i installed the rear and plan on rechecking everything tomororw.
Old Jul 26, 2005 | 04:03 PM
LordOfTheFlies
I was wondering if anyone knew what the oil pressure sensor should be torqued to.....
Old Jul 29, 2005 | 09:38 PM
J0kER's Avatar
J0kER
very useful !!!!
i think that 80lbs is not accurate on lugs cuz a bit ago i mounted custom wheels and im torqued down to 91lbs..... maybe im wrong? i should check & get back
Old Jul 30, 2005 | 10:20 AM
obehave's Avatar
obehave
Lugs are 120nm or 88lbs/ft
Old Jul 30, 2005 | 12:43 PM
J0kER's Avatar
J0kER
kool!
Old Jul 30, 2005 | 03:08 PM
hornguys's Avatar
hornguys
For autocross I found that the lug nuts come loose at 88. I have to use 93.
Kosei K1 TS 15x7 wheels, Hoosier 225/45/15 tires.
I use 90-92 on the street, or else they eventually work loose. 15x6.5 Rota Circuit 8 wheels, BFG KDW-2 205/50-15 tires.
Not sure why.
Old Jul 30, 2005 | 04:48 PM
chows4us's Avatar
chows4us
What he said. Its all in the manual ...
Old Jul 31, 2005 | 09:53 PM
mataku's Avatar
mataku
I will be investing in one soon, however, I hear that there's one coming out at the end of the year for the 05's. Because of this, I rather get that one, even though there are little changes in the models. In the meantime though, it would be nice for a little fill in.
Old Aug 1, 2005 | 06:50 AM
Tirewarmer's Avatar
Tirewarmer
Does anyone know when the new 05 manual will be released?
Old Aug 1, 2005 | 12:56 PM
chows4us's Avatar
chows4us
for 2002-2004
Oil pressure switch to oil filter housing 15 ft-lb
Old Aug 1, 2005 | 01:02 PM
chows4us's Avatar
chows4us
(FOR 2002 - 2004)
rear strut top bolt (center strut retaining nut - 22 ft lb)
rear strut bottom bolt (lower strut mounting bolt - 103 ft lb)
sway bar bolt ???
Stab bar to rear subframe 14 ftlb
Stab link to stab bar 41 ftlb
(not sure which one your looking for) From Bently
see above
Old Aug 1, 2005 | 01:15 PM
MGear's Avatar
MGear
Upper Shock Bolts to Chassis = 64
Subframe to Body = 74
Old Aug 1, 2005 | 01:19 PM
MGear's Avatar
MGear
Say Lordoftheflies, since this was your idea, and a good one at that, once this is all done I nominate you to compile the total listing
Fordgt4
Oct 10, 2015 10:42 AM
krohm
Sep 28, 2015 12:16 PM
SneedSpeed
Sep 21, 2015 06:06 AM
hydouken
Sep 15, 2015 05:49 AM
cw40342
Sep 2, 2015 06:01 AM
