Suspension Linear Springs
Old May 24, 2005 | 05:54 PM
badassmini's Avatar
badassmini
Linear Springs
I wanted to get some linear spring to go w/ some koni shocks. The stock springs are linear and Dinan is the only aftermarket springs that I found that is linear. Anyone else make a replacement linear springs????
Seems like everyone is making progressive springs.
Old May 25, 2005 | 01:17 PM
meb's Avatar
meb
Eibach will make anything you want, but they don't like to make custom progtessive rate springs - I never asked why.
Call Truechoice. Truchoice is also the only US company authorized to rebuild Koni dampers. They are a very knowledgable company. However, you can get stuck with some one who really ought not answer questions, and, tis the racing season - they're really busy.
Good luck
Old May 25, 2005 | 01:36 PM
JeffS's Avatar
JeffS
The easiest thing to do is buy some Ground Control coilover sleeves, with whatever spring rate you wish.
That way, if you want to change the rates in the future you'll be dealing with a standard, easy to get size.
Old May 25, 2005 | 02:17 PM
flyboy2160's Avatar
flyboy2160
are these available yet? i've been waiting 2 YEARS....
Old May 25, 2005 | 02:38 PM
meb's Avatar
meb
I would expect Ground control adjustable sleeves to be available for Koni/Eibach from Truechoice. Just make sure you specify the clamp type sleeves rather than the allen screw stop type - the later are difficult to locate because they are small, and, they rust in place very easily.
Make sure you match your sleeves to the spring diameter you purchase - either 2.25" or 2.5" dia. springs
In reality, once the weight of the car is on the sleeves, they do not need to be tightened a lot.
Michael
Old May 25, 2005 | 05:22 PM
badassmini's Avatar
badassmini
Jeffs,
Ground control looks like the ticket. Went on their website and no mini kits on their site. I will call them tomorrow. Do you know if they are available for the mini?
Emmanuel
Old May 26, 2005 | 04:25 AM
meb's Avatar
meb
I inlcuded a link that doesn't work, sorry.
Old May 26, 2005 | 04:12 PM
badassmini's Avatar
badassmini
All,
I tried calling ground control since their website doesn't have an application for the mini updated. I was put on hold twice and third time went to voicemail and it was full.
Does anyone know if the kit is available for the mini yet? Anyone talk to ground control? Their website does not allow you to even email them.
Emmanuel
Old May 26, 2005 | 04:54 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
For Linear or straight springs try
http://www.bmw2002.com/ Talk to Jeff the owner.
Start at about 350 pounds for the front and 450 pounds for the rear
using 2.5" diameter springs.
Or from any good race shop or Ireland engineering.
Old May 27, 2005 | 03:45 PM
badassmini's Avatar
badassmini
Ground Control
Bad news. Just spoke w/ ground control and they do not have any Mini kits and no indications on when they will have one available.
Old Jun 28, 2005 | 11:36 PM
matma92ser's Avatar
matma92ser
So what did you decide on getting Emmanuel? Still using H-Sport for now?
matt
Old Jun 29, 2005 | 07:25 AM
badassmini's Avatar
badassmini
Matt,
Got some koni's and using the front hsport springs w/ the konis and the rear I'm using the stock rear spring w/ the konis. Seem to work pretty good. Check it out. Did you get your car yet?
Emmanuel
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
CooperSharp
Oct 12, 2015 09:21 AM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
nshannon29
Sep 30, 2015 05:21 PM
