Suspension Beveled Washer Molded into lower bushing of rearshock
Old Jan 2, 2021 | 11:05 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Question for those who've swapped out rear shocks on GP1's or those fitted with Aluminum trailing arms. On the stock GP1 shocks, the lower bushing has a beveled washer and tube molded into it which fits into the corresponding recess of the trailing arm. The beveled portion on the shock is not removeable. I doubt there will be any issue in doing without said beveled fitting but wonder if anyone has a substitute. Without it, the base of the new shock is firmly affixed to the trailing arm but about 1/2 inch outboard from the original.
Old Jan 2, 2021 | 12:58 PM
RB-MINI's Avatar
RB-MINI
Way has them.
http://waymotorworks.com/wmw-rear-shock-spacers.html
Old Jan 2, 2021 | 01:12 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
It sure what you’re asking, but you definitely want that beveled washer in there. I’ve read of the shock bolt snapping without it.
Old Jan 2, 2021 | 01:54 PM
NC TRACKRAT
Veteran: Navy
Thanks to you both! Glad I asked! Is this a great place or what?!
Old Jan 2, 2021 | 03:52 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes we have the spacers to do the conversion
https://www.waymotorworks.com/wmw-re...k-spacers.html
Old Jan 2, 2021 | 05:16 PM
NC TRACKRAT
Veteran: Navy
Order placed, Way!
Old Jan 4, 2021 | 02:43 PM
shimaze's Avatar
shimaze
Could you just use the 2nd gen rear shock with the 1st gen car when upgrading the rear control arms and replacing the struts at the same time? If so, this would save a couple of dollars. I don't what the difference is between the 1st & 2nd gen rear shocks.
Old Jan 4, 2021 | 04:47 PM
NC TRACKRAT
Veteran: Navy
Possibly but that's not my case. If someone went to the trouble of upgrading to the AL trailing arms, I would think that they would want something more than the stock shocks.
Old Jan 4, 2021 | 05:16 PM
shimaze's Avatar
shimaze
I looked at the 2nd gen shocks and they cost about $40 more for each shock so there is NO cost savings. So I will be ordering a set from WMW
I am upgrading to the aluminum trailing arms for no other reason than they were cheap at $35 for the complete kit and I am installing new struts all the way around anyway. I don't expect or desire any performance gain. I am going with the Koni red active shocks. This is a convertible JCW so I am not looking to stiffen the suspension. Plus it is a touring car that we take out on weekends and we will never take it to the race track
Old Jan 4, 2021 | 06:08 PM
NC TRACKRAT
Veteran: Navy
Good choice! I think you'll find that the KONI Special Actives (formerly FSD's) will be a nice up-grade.
mad55chevy
Jul 14, 2015 08:13 PM
Madgepetto
Apr 19, 2015 07:13 AM
HFDZDN
Apr 2, 2013 06:08 PM
jolson
Oct 23, 2011 05:55 PM
Lowell
Jul 24, 2011 05:04 PM
