Suspension DDC vs. KW V1
DDC vs. KW V1
I currently have a 2019 JCW with DDC. I want to reduce the body roll as much as possible. I installed an NM RSB already but am thinking about adding the V1's. I don't care as much for the drop as I do handling. For anyone that has changed from either the DDC or sport suspension to the KW V1 please let me know what your thoughts are and if it improved your handling.
I would suggest going with a set of KW V2 as they are much better than the V1 and will really improve the handling. We use them on that 3 F56 builds we have done. If you really want to go for it we even have an open box set of V3s that are a great deal.
https://www.waymotorworks.com/kw-var...overs-f56.html
https://www.waymotorworks.com/open-b...-with-ddc.html
Seeing you have a 2019 and would still have a warranty, why not just buy the John Cooper Works Pro Sport Chassis setup. That way you still get your 4yr/50K warranty with it. At least that's what I ordered. The dealer said they could still install if you have DDC.
The KW DDC kits also include the modules to bypass the DDC which is needed to make it all work right.
The JCW kit doesn't offer a kit for the DDC cars, and you can't put the JCW kit on a DDC as it physically won't fit.
Honestly most people just set the rears to the middle and never adjust them again. At that setting they are actually really good ride quality.
Is it a different top mount? do you have pictures or more information you can share please.
I am curious as to why, if the KWs fit in DDC-specced cars, why the JCW Pro suspension (which is basically a KW v1, made by them and branded for Mini) would not also fit?
I have a '19 Cooper S 3 door hatch (not a JCW, even though I have the tune and exhaust). Came with DDC. I hated it. Initially, the dealer said they couldn't swap out for the JCW Pro suspension, so I went aftermarket. I did have to buy KW's DDC cancellation kit for everything to work (this is an assumption, since I didn't attempt to install the aftermarket kit *without* the cancellation kit). Anyway, long story short, went back to the dealer told them I *really* wished I could do the Pro suspension. So they did. Yes, I have the JCW Pro suspension on a DDC car.
Caveat: The Pro suspension is covered under parts/labor warranty, but not under the original 4yr/50k warranty. But, the suspension is awesome
It's not as easy as it sounds as there are various other parts like the mounts and such that would also need to be replaced if a car had DDC and you bought a non DDC coilover kit like the JCW. That is why it is better to just go with a KW V2 kit for a DDC car as it includes the modules to bypass the DDC and the correct size shocks and that to reuse the stock mounts so you don't have to buy extra parts. https://www.waymotorworks.com/kw-var...overs-f56.html
Seems like a good option. Still weighing our options. Don't even have the car, yet, so we'll see.
Sailorlite
Apr 20, 2015 11:14 AM
