Suspension NM-Eng Rear sway links clunking like crazy
Old Feb 27, 2018 | 07:15 AM
trentiles's Avatar
trentiles
I've had the 25mm NM rear sway installed for over a year on the stock end links. Well last week there were popping noises from the rear so I took a look and the driver side rear link was broken.
I quickly placed an order for the NM rear sway bar links, got them in 2 days, and promptly installed them according to the instructions.
Everything was nice and quiet for around 4-5 days and now the rear is clunking like crazy. Any little bump, microscopic pebbles creating absolutely insane popping/clunking from the rear.
Has anyone else experienced this with the NM links? The endless clunking, literally hundreds of times over a 5-10 minute drive makes me hate my car at the moment.
Old Feb 27, 2018 | 07:31 AM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
I had the same thing and for me, it was actually the sway bar needed greasing on the bushing. I could have sworn it was the end link but once I greased the bushings everything stopped clunking
Old Feb 27, 2018 | 07:42 AM
trentiles's Avatar
trentiles
Guess I need to go and buy a grease gun to work with the fitting that come with the race bar.
What grease did you use?
Old Feb 27, 2018 | 09:16 AM
TVPostSound's Avatar
TVPostSound
Amazon Amazon
Old Feb 27, 2018 | 09:48 AM
trentiles's Avatar
trentiles
Good ol super lube
The bushings will get the ol super lube later on today and I will report back.
Old Feb 27, 2018 | 11:27 AM
Mini_Vinnie
Moderator
Yep, pretty much that. Admiditly, I think I got mine at Wally World
Old Feb 27, 2018 | 07:29 PM
mattkosem's Avatar
mattkosem
I've had mine on for about a year, no noise from the links. I got some squeak when the weather cooled down, but hit the bushings with super lube and it's been quiet since.
--Matt
Old Feb 27, 2018 | 10:56 PM
vetsvette's Avatar
vetsvette
Moderator
Almost two years for me with no problems.
Old Mar 2, 2018 | 07:45 AM
trentiles's Avatar
trentiles
Issue has been fixed. The driver side link to sway bar nut became loose enough that there was a couple millimeters of movement between the link and bar. Absolutely insane the amount of noise that was causing.
I tightened it up and it's been good so far.
Old Mar 2, 2018 | 10:27 AM
WhatV8's Avatar
WhatV8
Good to hear you found your issue and it was 'easy' too! As for grease on bushings, especially units that are driven on a daily kind of basis, I would suggest using a water resistant lube. I have been using the Sta-Lube marine grease (link below) for years in my Mustang's suspension and have never had a squeak from the poly units.
https://www.amazon.com/CRC-SL3184-Trailer-Bearing-Cartridge/dp/B000M2QS4S/ref=sr_1_2 https://www.amazon.com/CRC-SL3184-Trailer-Bearing-Cartridge/dp/B000M2QS4S/ref=sr_1_2
Old Mar 2, 2018 | 11:29 AM
TVPostSound
https://www.amazon.com/CRC-SL3184-Tr...S4S/ref=sr_1_2
One should avoid petroleum based lube on poly bushings.
Teflon (PTFE) grease is best.
Old Mar 2, 2018 | 03:18 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
I found from experience that some loctite blue on the nuts keeps the rattles and clunks from re-appearing.
Old Aug 13, 2020 | 06:58 PM
Maze Kim's Avatar
Maze Kim
i have the noise for over 1year too, my mec. told me it was cause by the NM endlink as it has no any bushing /rubber in it, he said the only way to avoid it is to change back the OEM end link
but after many user review and report the same issue, i tried all the method but the noise still here.
today I heard from another mec guy, he said the NM 25mm swaybar has a design failure, the swaybar will hit to the chassis and that's the reason of the noise.
anyone heard about this problem ?
Old Aug 20, 2020 | 01:02 PM
TVPostSound
The previous bars without the bushing stops will allow the bar to slide in the bushing on turns.
Worse with the NM links as they have more movement.
ltjpunk7
Suspension
36
Feb 8, 2017 11:36 AM
zcast
Nov 19, 2014 07:43 PM
Enav
Feb 11, 2013 03:55 PM
robino
May 18, 2007 06:00 AM
