Suspension Sports suspension plus Eibach springs
Old Feb 15, 2015 | 11:14 AM
j5ktt's Avatar
j5ktt
My car already had factory fitted sports suspension and I've just replaced the OEM springs with Eibach springs. I was a little worried about how the ride might be now the car is lower but I'm very happy to say that the ride feels better - not quite as harsh as the std sport springs.
Old Feb 15, 2015 | 01:25 PM
randomquickness's Avatar
randomquickness
looks like the rear sits just a bit higher than the front. is that accurate?
Old Feb 15, 2015 | 01:42 PM
j5ktt's Avatar
j5ktt
I think it might be just a touch higher as it's still settling after installation. Plus there was almost nothing in the car/fuel tank
Old Feb 15, 2015 | 01:52 PM
WrenchMonkey's Avatar
WrenchMonkey
looks great! Almost making me jealous. Very clean car too, of that I am certainly jealous. I'm not sure if my car is all white because of the snow or the salt...
Old Feb 15, 2015 | 01:55 PM
j5ktt's Avatar
j5ktt
An hour earlier it was also white - had not washed it for over 2 months so thought I better take a couple of pics before it's filthy again!!
Old Feb 15, 2015 | 05:47 PM
SoCalledFriend's Avatar
SoCalledFriend
Spacers? If so, what size/brand?
Old Feb 16, 2015 | 07:53 AM
j5ktt's Avatar
j5ktt
H&R 12mm at the front and H&R 15mm at the rear (also bought longer bolts)
Old Feb 16, 2015 | 09:23 AM
SoCalledFriend
Do you still have room to go wider if you wanted, or are you at the limit now with the drop?
Any rubbing?
One last question (appreciate your time).....did you stagger the front and rear so they would both be at the same point on a plane, or do the rears stick out further than the fronts? (Hard to tell from your pictures).
Thanks!
Old Feb 16, 2015 | 10:07 AM
j5ktt's Avatar
j5ktt
Any rubbing?
Thanks!
I'm not sure about wider - I'm pretty happy with how it looks and so far no rubbing at all. I chose the mm based on what I had seen on a German forum as it seems to fill the arches quite well.
Old Jun 5, 2015 | 04:42 PM
J_L's Avatar
J_L
You sure you've got Eibach springs on there? I just called them, and they said that they're still in prototyping, and that it's gonna be a while...
So are NM and H&R the only spring choices? I talked to NM, who are nice people, and gave me this info:
Stock rates: NM rates:
f 160 200
r 215 230
That's just for the standard suspension, and they didn't have info on the OEM SS. They certainly kept the rear mild, for less bounce... maybe that's a good thing. So I just wonder how this compares to the sport suspension. Using the +30% figure that some marketing info had at some point, the front NM is about as stiff as SS, and the rear sounds more mild. Makes sense.
H&R wouldn't give out rates.
If anyone has tried both springs on SS, let us know!
Old Jun 5, 2015 | 06:31 PM
randomquickness
^eibach springs have been out in Europe for a while I believe. Everything just takes forever to get stateside.
Old Jun 5, 2015 | 06:35 PM
J_L's Avatar
J_L
Huh. But he's in NY.
Also, the guy at Eibach went and checked with R&D, like they are the ones designing them there, and they're not done yet. So... I'm confused. Maybe he thought I meant the 4-door, although I'd be pretty surprised if those were any different from 3-door.
Old Jun 5, 2015 | 07:23 PM
Dr. Spade's Avatar
Dr. Spade
Correct me if I'm wrong but isn't sport suspension just better springs?
According to dealer training guy the shocks are the same.
Old Jun 5, 2015 | 07:30 PM
j5ktt's Avatar
j5ktt
f 160 200
r 215 230
I bought my Eibach springs in Germany and had them shipped to NYC - they are clearly available on the Eibach website:
http://web2.carparts-cat.com/default...B279004&12=130
Old Jun 6, 2015 | 06:55 AM
randomquickness
unless it changed after MY14 then the dampers are stiffer to match the sport springs
Old Jun 6, 2015 | 12:29 PM
J_L's Avatar
J_L
Yeah I remember reading that the shocks on SS were stiffer too. Ok actually I checked a parts catalog- there are 2 different shocks listed. One is like $10 more, and that's the part # on my shock. So yeah looks like they are different.
http://parts.miniofkennesaw.com/show...category=17343
Back to Eibach... I wonder if US Eibach springs are different? Less stiff for our bad roads? Anyone see the rates listed anywhere?
Old Jun 7, 2015 | 03:16 PM
J_L's Avatar
J_L
Ok, found this post on another forum, from an Eibach US employee, when asked if US and European Eibach springs are different:
"Typically this is the case. At Eibach North America we do all of our designing and testing around USDM cars and produce the springs here for our market.
Eibach Germany also does their own testing, designing and production for European and Asian market cars. I believe all of the kits for these markets have to be TUV certified so the specs and part numbers will vary between our two markets. In some small cases we do share the same spring application."
Old Jun 29, 2015 | 08:37 PM
Shoof's Avatar
Shoof
Looks real clean, j5ktt!
Old Jul 1, 2015 | 01:42 PM
TheBigNewt's Avatar
TheBigNewt
The SS is stiffer sway bars to reduce understeer. The springs have different part numbers but aren't stiffer, neither are dampers.
Old Jul 1, 2015 | 02:43 PM
J_L's Avatar
J_L
Dampers have different part numbers too. And they sure feel stiffer. Pretty sure they are... If anyone wants to mic their standard springs, I'll mic my SS, and we'll know...
techgearpro
Jul 23, 2019 07:09 PM
molala
Oct 2, 2015 01:53 PM
Suspension Products
Sep 3, 2015 09:41 AM
M7Speed
R58 :: Coupé Talk (2012+)
Sep 3, 2015 07:29 AM
Llanrhaeadr_Cymru
Country Roads MINIs
Sep 2, 2015 07:12 PM
