Suspension Powerflex or OEM Control Arm Bushings?
Old Jun 12, 2014 | 01:34 PM
Courtois's Avatar
Courtois
My MINI mechanic suggested I replace the control arm bushings on my 2004 MC, 40K miles, sport suspension plus. Should I go with Powerflex polyurethane bushings or OEM rubber bushings? Is there any increase in vibration felt in the steering wheel with the Powerflex bushings?
It seems most folks like the Powerflex bushings (https://www.northamericanmotoring.co...-feedback.html), but every so often I'll see a post that mentions problems:
"After driving around with lubed urethane bushings for 5K miles, I can tell you that they squeak & transfer more NVH which causes your dash to rattle/squeak more. This has always been my experience with urethane bushings but after hearing everyone on the Web say how great they are, I wasted hours of my time to make my car worse than stock."
(https://www.northamericanmotoring.co...ll-joints.html)
I use the MINI for TSD rallies, a few solo events a year, but mostly for transportation, although it's not a daily driver. I've been very happy with the OEM sport suspension plus, so I hesitate to make any changes, but I don't want to miss the chance to improve things if the Powerflex bushings really are better.
Thanks for your thoughts,
Marty
Old Jun 12, 2014 | 03:42 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by Courtois
My MINI mechanic suggested I replace the control arm bushings on my 2004 MC, 40K miles...Thanks for your thoughts,
If you don’t go with PowerFlex you will be replacing these bushings every 40,000 miles. Do you want to do that? The urethane may actually last as long as the car.
Mine have never made a squeak and I would never recommend OEM on LCA bushings EVER!
///Rich
Old Jun 12, 2014 | 04:07 PM
kazlot's Avatar
kazlot
Marty
Why change if you're happy. Is it really an improvement for a few events a year if the rest of the time it's not an improvement.
Everybody has a difference of opinion on how much NVH is acceptable and if you're concerned don't use aftermarket.
Now having said all that of course the Powerflex LCA bushings are an improvement
just like polyurethane lower engine mounts and transmission mounts are an improvement.
If your mechanic is recommending new LCA bushings even stock ones will be a noticeable improvement.
Hope this helps...
Old Jun 12, 2014 | 05:19 PM
ZippyNH's Avatar
ZippyNH
Powerflex....basicly a lifetime part.
NVH change was not noticeable IMO....very subtile at best/worst.
Old Jun 12, 2014 | 06:43 PM
Melangell's Avatar
Melangell
You really have no idea (nor sought to really research)... Endearing...
Old Jun 12, 2014 | 07:10 PM
Sideways's Avatar
Sideways
Do it!
I'm about to replace my PowerFlex LCA bushings at about 90,000 mi. on the car (2008 MCS - had em' in my R53 also). I had them installed @ ~15,000 mi. and I still consider them one of the most essential mods, especially for the R56. The stock "tuned for runflats" bushings in the R56 are crap - even softer than the R53. IMHO that's the main reason that everybody said the electric power steering in the R56 sucked. Very little increase in NVH and much more precise steering are the benefits. Not a cheap mod, but if you have to replace yours anyway, PowerFlex 100% all the way.
I do a dozen to 20 autocrosses a year and we have some pretty nasty roads in central Mass (daily driver). So, while they might not be "lifetime" parts, I'd say they start off much better & last about twice as long as the stock bushings.
Old Jun 15, 2014 | 02:14 PM
ashchuckton's Avatar
ashchuckton
I have the Powerflex control arm bushings. I'm very sensitive to NVH. IMO they don't add any, go for it.
Old Jun 17, 2014 | 11:38 AM
Courtois's Avatar
Courtois
Thanks to everyone for your thoughts on this. I know this topic has been discussed a lot, and the evidence is overwhelmingly in favor of Powerflex bushings, but the occasional negative comment sticks in my mind.
In terms of NVH, I could live with an increases in Noise and Harshness, but I really don't want to feel any Vibration, particularly through the steering wheel. In your experiences with Powerflex LCA bushings, did you notice any increase in vibration through the steering wheel?
Thanks again!
Marty
Old Jun 17, 2014 | 11:47 AM
c0op3r's Avatar
c0op3r
Is this a real question? Cause it should not be!
(say it in an Obi Wan Kenobi voice) Trust the mechanic and the parts will be be with you . . .
Old Jun 17, 2014 | 11:54 AM
Swimbaxter's Avatar
Swimbaxter
You will never get 100% of the people on here to agree on 100% of anything however Powerflex in this circumstance is all but unanimous as a recommendation. That's as good as you will ever get for a rec. I have done it and didn't notice any NVH. This is clearly the way to go.
Old Jun 19, 2014 | 06:34 PM
CARdiac's Avatar
CARdiac
I am a +1...did the poly on my S the same time MINI did the stock on my wife's S...time to replace the wife's, mine are still good. No road noise that I noticed....no squeaking, I am very happy with mine- not so much with my wife's
Old Jun 24, 2014 | 11:28 PM
jgk6502's Avatar
jgk6502
Another option is, instead of stock OEM rubber bushings, ask your mechanic about higher-end rubber bushings.
The reason I suggest this, is because when I took my MINI in for an inspection, the mechanic suggested to replace the bushings. I asked if he recommended Power-flex and he said that they use bushings meant for BMWs that fit the MINI. Better quality rubber. It was a highly recommended shop in my area too.
I ended up changing them myself, and it was the first major car work I did other than changing engine and trans fluid. Took me forever, but the results were great. And you definitely need a press if you go the rubber route.
Old Jul 5, 2014 | 06:57 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Go with the Powerflex Bushings. We install them on every MINI and have done hundreds of sets with not one problem.
W0TM8
Dec 19, 2019 07:50 AM
Mini7
Feb 2, 2016 07:52 PM
Toolman
Jan 20, 2016 06:50 AM
maestro39
Oct 27, 2015 02:38 PM
JPMontes3
Aug 23, 2015 01:26 AM
