Suspension Cooper non-S vs Cooper S suspension question
Trying to help someone with installation questions. They have a set of non-S R56 aftermarket coilovers and want to put them on their R56 S. They were told this is not possible. This surprises me. I can't imagine any difference between the suspension components of the two models other than damping, spring rates or ride height. Do the non-S and S suspensions differ in actual dimensions or in the way they mount?
Thanks!
Doc
Thanks!
Doc
Thanks!
Doc
Thanks!
Doc
Hi there, this is the person in question. The coilovers I tried to install were a set of ST Suspension coilovers, which I needed for a 2010 JCW, but which I later found out were for the base model Coopers. I too am baffled by the thought of the 2 suspensions being radically different, but what else would explain the completely failed install? Nothing mounted up properly, whole pieces were in the wrong place and upon a little searching, I found that there are actually 2 different sets. And they look quite different. One is product # 90250 (base model) and the other is # 90608 (S/JCW). Anything is appreciated, fellas!
The # is 90250. The flanges for the break lines were damaged during the install attempt because of the way they were sitting. Now that I'm temporarily back to stock, Im hoping that a spot weld will fix these damaged flanges.
As others have said, the suspensions for all r56 MINIs are physically identical and interchangeable. From the factory, minor spring rate and damper valving changes exist to accomodate the weight differences in cars with various options. But all the mounting points and fitments are identical for the whole r56 line.
The coilovers that you have that did not fit were either not the right part for an r56 MINI, not installed correctly, or were just a bad design.
http://www.outmotoring.com/mini-coop..._bushings.html
I have been running r53 Konis on my r56 MINI for years.
silence2-38554
Nov 12, 2015 09:39 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
