Suspension Corner Weights
Old Oct 28, 2013 | 03:42 AM
zre's Avatar
zre
Corner Weights
For those who have had thier R56 MINI corner balanced what are your corner weights? I had mine done and the LR is light, fronts are close to same but rears are off.
Old Oct 28, 2013 | 03:58 AM
1qwkmini's Avatar
1qwkmini
If you want it to work really well, the most important thing is to balance the cross weights. RF + LR should equal LF +RR. Shifting weight front to back with coils is nearly impossible...so just concentrate on cross weight (with driver in car)
Old Oct 28, 2013 | 05:58 AM
countryboyshane's Avatar
countryboyshane
That's what I was about to say. As long as the cross-weight is 50%, why worry about the individual weights?
Old Nov 10, 2013 | 06:24 PM
honda93's Avatar
honda93
Also, did you disconnect the swaybars? They can preload and give false readings if bound.
Old Nov 10, 2013 | 06:27 PM
1qwkmini's Avatar
1qwkmini
That being said, you also need adjustable end links to allow the cornerweights to stay the same after the bars are reconnected.
Old Nov 11, 2013 | 03:27 AM
zre's Avatar
zre
Repair lower rear damper connection and re-balanced car, cross-weight 0.8 lb difference. Re-adjust sway bar end links.
bADbOYbECK
41
Oct 16, 2015 12:39 PM
krohm
Sep 28, 2015 12:16 PM
Tires, Wheels & Brakes
Sep 9, 2015 11:08 AM
Suspension Products
Sep 2, 2015 10:32 AM
