Suspension My lifted mini is done!
Old Apr 2, 2015 | 04:18 PM
  #151
simpsonna's Avatar
simpsonna
Update
Just an update,
I've put 1,000 mi or so on mine since the lift. No problems But I do need an alignment after hitting a massive hole in the road a little while ago. I think I'm going to try the DIY string method as I believe I can do it better than an expensive machine operated by a 19 year old kid at Firestone since I actually care to get it right.
I will say that the lift does change the camber a good bit and you will need to buy more parts to correct that. I got a set of adjustable rear camber links to replace the fixed stock lower ones. This gave me an adjustment to return to a negative camber in the rear, it was pretty much Zero after the lift. And I still need to get camber plates for the front, they are close to Zero also.
I bought the H-Sport Rear links from Way at WMW, but I really DON'T suggest you do so. I was close to Atlanta for work so I went to the store in person and as I was paying I explained to Way that I had put the lift on and this was to help the camber, Way proceed to tell me how dangerous and stupid lifts are and that he thought I was dumb to have done it. I understand theres a difference in opinion but WOW. Some customer service right? Not to mention the customer on the phone that he was making fun of while I was there.
Old Jul 4, 2015 | 09:01 PM
  #152
Burgermeister's Avatar
Burgermeister
I am liking what I am reading about how this has helped out for snowy climates. Impressive.
Old Sep 20, 2015 | 03:58 AM
  #153
tournot97's Avatar
tournot97
nice
Old Mar 2, 2016 | 09:24 PM
  #154
89AKurt's Avatar
89AKurt
~bump~
This Subaru made me think of this thread.
Old Mar 3, 2016 | 06:03 AM
  #155
bratling's Avatar
bratling
Super Moderator
Originally Posted by 89AKurt
~bump~
That's awesome! Where did you find that? Are there more pics somewhere?
Old Mar 3, 2016 | 10:45 AM
  #156
toolmonger's Avatar
toolmonger
My lift is finally installed too. The rears were pretty easy. Fronts were even easier since I had both axles out (leaky boots).
The list of repairs also included replacing the valve cover gasket, bypass valve (broken spring), water pump, crank position sensor O-ring and oil pan gasket. I was only able to do this by watching all the ModMini videos, reading the Bentley manual and buying another $200 or so in tools.
The supercharger looked in fine shape so I didn't do anything other than change the oil. Very anxious to see what replacing the bypass valve will do. I believe the spring has been broken since I bought it and now I know why I was so under-whelmed with performance.
I guess this belongs in a different thread, but here's some pics anyway. Hope to get it on the road this weekend.
Start
Midpoint
Almost done
Old May 2, 2016 | 03:14 PM
  #157
toolmonger's Avatar
toolmonger
2" Cooper Crap lift installed. No more scraping on the driveway!
Not yet sure what size tires to put on. I'm thinking 195/65R15.
The rims that came with it were aftermarket and seemed very heavy. I had 205/60R15's mounted on them.
I bought the rims you see in the picture off craigslist a while back. They are very light and currently have 175/65R15's.
Old Jul 1, 2017 | 10:40 PM
  #158
Tanner Stinson's Avatar
Tanner Stinson
I know this is a pretty old thread, however, what is the total offset of your wheels, wheel spacer included? Thanks! They seem pretty heavily negative, but I could be wrong.
-Tanner
Old Sep 30, 2017 | 12:04 PM
  #159
Ankersen21's Avatar
Ankersen21
How
what did you need to do that?? Can't figure it. Out I have the 04 Mini
Old Feb 16, 2026 | 06:26 AM
  #160
smithjn's Avatar
smithjn
Wow, thats an amazing job It must feel really satisfying to finally see your lifted Mini driving down the road after so many hours of work and even a hospital visit. I like that you’re thinking about adding custom fender flares and a bull bar next those will really finish the look. Out of curiosity, when planning a lift like this, do you usually check resources or guides from places like Metrowest Car Service to understand the suspension setup and alignment? It’s inspiring to see that with patience and effort, a project like this can really come together.
Dec 23, 2015 10:36 AM
honderpilot
Aug 31, 2015 02:53 AM
kpl
Aug 11, 2015 04:52 AM
Dashdog
Aug 10, 2015 06:17 AM
