Suspension My lifted mini is done!
#101
Who makes that basket ?
Do you have a model number ?
#103
Questions:
Would it be possible to lift an R53 2-3" seasonally? I love the idea of having mine clear the snow better. I have to find out what the local laws are about tires outside of the wells. It looks awesome, but it can't be legal around here (Ontario). I'll need new winter rims and tires next year anyway, so that's moot.
What would be involved? I can't seem to find any R53 lift kits. What about air ride (I know nothing about suspension)? If I can install/convert the car in 6 hours I'd do it
Please help edubcate the noob
#104
And bigfiero, you're inspiring the hell out of me to do mine...
Questions:
Questions:
i have not seen any for the R53 but Moby911 might be able to help you out with that.
On my R56 kit bought from Coopercrap.com.
Front: uninstall the strut as if you were going to replace them. unbolt the lower controll arm (2 bolts) not ball joint. Attach the kit to the top of the strut then place the strut back in the car and attache the top mount. putting the strut back into its lower mount (took two people) and attach the lower control arm (2 people).
the front took some work to get back in but everything mounted back up including endlinks and sway bar.
Rear: uninstall the strut as if you were going to replace them. attach the kit to the top bolt everything back up. i did this myself.
Total time 4.5 with no instructions and help from one person. used a shop with car lift/ impact wrench/ torque wrench.
another solution if you cant find a kit is something like but it only gives you 1 inch lift at best. http://shop.mr-gasket.com/suspension...ng-spacer.html. i have these installed as well and they are really easy to put in. lift car off ground install between springs.
if you want more info just let me know n i can get you some more details.
#105
Air ride was something that I had thought about but I couldn't conceive a feasible way to install a system A)While being a cheap bastard and B)without it always being a little higher than normal ride height.But that may be because I've never installed air ride before so my lack of experience in that department is why I didn't look too hard at that option.Or you could get a set of big *** air shocks like guys used to put in the back of mustangs to give a bit of rake. :P
#106
#108
After quite a bit of research, it appears that for a seasonal lift, airbags are not really piratical (I'm talking about resetting the base of the airbag on the threaded strut - not day to day usage). The strut has to be removed to make the major adjustment. It would be great to have the ability to slam it occasionally in the summer, but not worth the cost for my usage.
At that point, static spacers might as well be used.
Now - where can I get spacers for an R53? Coopercrap can't help at this time, unless a bunch more people show interest - and they get an R53 to work on for a few weeks.
Moby911 - how'd you make yours?
After that I have to decide what to do about the brakes/rims/tires. I'd really like to have a R56 Brembo kit installed, but with the 15" steels you guys are using, that's not going to be possible. I need to run 17" rims (unless someone can verify a 16" rim setup for the Brembo's)
#109
I took my own measurements and designed something based on what made sense.What I can do for you is take some measurements and make up a drawing .I'll do it in a cad program so you have an actual schematic to go off of.It'll be a lot better of a design than I originally made.Might take me a few days though, I've got a few things going on right now.
#110
#113
#114
Personally I didn't experience much of a loss if any at all.My thoughts on the subject were that on the highway the taller tires make it to where your engine is running at lower rpms at 70 mph than you would be with smaller tires.Luckily these are such ballsy little cars they can handle the extra torque needed to spin a 28" tire without breaking a sweat.I would always refer to my mini as the alpha male of minis because it was bigger than the others haha.Please join the alpha mini club dude!And pertaining to the cad drawing of the lift,I'm sorry it's taking so long I'm getting ready to move so there's a lot going on for me.I promise I will get it done.
#115
Again, I refer to my F150, I could definitely feel the 35", 90 lb (each wheel) mud terrains trying to roll!
I want to do the lifted mini look, I think it looks completely bad ***! A downhill mtn bike would look more appropriate atop one of these 'alpha minis' lolol
thanks for the reply!
#119
as high as I could with my adjustable endlinks. I shrunk them as small as they would go but under hard turns the endlinks were hitting the brake line bracket and when the car was lifted off the ground you couldn't turn the steering wheel more than half a turn either way before they would hit and bind it!
#120
I'm on my way to a Moby lifted R53.
My first step was to get some wide arches - success.
Next will be working out the Wheel and Tire selection (opinions wanted), but that should probably wait until I have the Moby lifters/plate made.
Were there any other things you guys needed to change (suspension, brake lines etc) when you lifted?
Did you both get an alignment done after the lift?
I'm probably going to have to start my own thread as to not hijack this one.
#121
an that,
#122
#123
I went from 30 to 23. With roughly 3000 miles on it so far. But I have a rack, grill, and lights.. plus the wheels stick out as well.
#124
#125
Maybe I'm misunderstanding what you wrote.
This is perfectly timed as I've been researching control links. The only link I can find that allows for positive camber adjustment is the Eibach one that allows for +4 to -4 degrees of adjustment. They appear to be the best thing around, but are obviously priced that way as well:
http://performance-suspension.eibach.../pro-alignment
