Suspension camber plates help??
Old Mar 16, 2010 | 10:11 PM
carlitosway's Avatar
carlitosway
I bought a set of Ireland engineering camber plates and i can see that everything is straight forward except that i don't know which camber palte goes to the left and which goes to the right.
thanks in advance.
Carlos.
Old Mar 16, 2010 | 10:46 PM
carlitosway
I got them today but i need help with the installation.
sorry for the interruption.
HOW I know which plate goes to the right and which one go to the left?are they are marked?
Old Mar 17, 2010 | 12:41 PM
hunter99's Avatar
hunter99
Look at the bolt pattern on top of your strut towers, You'll notice that they match the plates. The Camber bearing is then offset towad the center of the car.
If you look at the stock camber bearing (you can see it through the hole in the top of the strut tower) you will notice it is aligned with the hole. The IE plates will, again, offset it toward the center of the car.
Old Mar 17, 2010 | 01:56 PM
carlitosway
Thanks for you help.
Carlitosway
Old Mar 27, 2010 | 09:47 PM
carlitosway
what is the correct alignment!!!
Hi all,
I installed a set of irland engineering support plates to avoid the mushroom problem but I need to know the best set up for alignment( This is my driving style:80 % straight (Monday to Friday) & roads 20% curves (Weekends).
Also,
I notice that the driver side hits the inside wall,
anyway knows how to correct this?
thanks in advance.
Old Mar 27, 2010 | 09:57 PM
carlitosway
the driver side spring is hitting again the wall, what to do to fix this issue?
Old Mar 28, 2010 | 08:04 AM
MLPearson79's Avatar
MLPearson79
Several threads combined into one, and all moved to the proper forum.
Please do not cross-post! Simply place your thread in the proper place and it will get answers.
From Site Guidelines:
SEARCH
Before posting, use the Search function to see if there has already been a thread on the same subject. Do not start identical threads or cross-post the same thread in different forums.
Old Mar 28, 2010 | 09:02 PM
hunter99's Avatar
hunter99
This problem has been seen before. On the earlier R53's the inside of the tower has to be massaged to clear the spring.
Old Mar 29, 2010 | 01:09 PM
carlitosway
Hi Hunter99,
So what is the solution, bend the area that the spring touches?if i do that do you think i could damage the wall?
I rerally appreciate your reply.
got_mini?
Oct 7, 2015 02:12 PM
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
