Suspension Anyone installed BC Coils on R56?
Old Mar 11, 2010 | 09:22 PM
oda's Avatar
oda
Hello i am new here, i am wondering if there is anyone that installed the BC Coilovers on R56?
I've only seen the one on the 1st gen mini and they had to modify the tower and also drill holes to get the adjuster out? is this the same case for the BC coils? cus i dont want to do any of those surgeries to my mini
also, if i dont do those surgeries, is it still ok to fit the suspension? would it be difficult to adjust the height, stiffness and rebound in the future? thanks
Old Mar 11, 2010 | 10:09 PM
JamesHunt's Avatar
JamesHunt
they bolt right in the r56 with no mods needed .
will post a step by step in a couple of weeks.
Old Mar 11, 2010 | 10:36 PM
ThumperMCS's Avatar
ThumperMCS
Are u running them??
Old Mar 12, 2010 | 01:57 PM
D Unit's Avatar
D Unit
I have BC coilovers on my Mini. It's a daily driven Mini that has never seen the track. I didn't install the extended adjusters in the rear or make any additional holes in the front. I simply set everything in the middle and let it be. Again, very happy with them overall.
Old Mar 12, 2010 | 04:38 PM
Creeve's Avatar
Creeve
I just installed mine a few weeks ago.
No you do not need to drill or cut anything. Generally people who modify the car in that way are going to the track often and need to constantly adjust their camber and dampening. So instead of it taking a half hour every time it only takes 3 minutes.
Old Mar 12, 2010 | 06:21 PM
JamesHunt's Avatar
JamesHunt
not yet.bc racing is sponsoring the jcw for 1 lap
Old Mar 16, 2010 | 11:06 AM
geekswrath's Avatar
geekswrath
Are you guys running the springs that came with the BC's or have you installed another set like Swifts? I've read a lot on the 1st Gen forum about this.
Old Mar 16, 2010 | 12:51 PM
JamesHunt's Avatar
JamesHunt
swift
Old Mar 16, 2010 | 12:58 PM
D Unit's Avatar
D Unit
How about letting us know which swift springs are compatible? IIRC, they inner diameters are 2.5", but I don't know the proper lengths to get the correct preload on the springs.
Old Mar 16, 2010 | 01:01 PM
JamesHunt's Avatar
JamesHunt
call one of the guys at bc .bc hooked me up on the springs and coilovers
Old Mar 16, 2010 | 06:10 PM
user 7082082's Avatar
user 7082082
Info for swift springs.
Fronts - Freelength 152mm, diameter 65mm, 8kgmm
Backs - Freelength 178mm, diameter 65mm, 6kgmm
I have the BC springs currently which I like a lot, but I will be swapping to Swift soon with a lower spring rate.
Old Mar 17, 2010 | 06:30 AM
geekswrath's Avatar
geekswrath
Any reason you aren't running 178mm (7") springs on both f&b?
What rate are you planning on going to and why?
Old Mar 17, 2010 | 11:46 AM
D Unit's Avatar
D Unit
It's probably because he's trying to keep the front and rear lengths as close as possible to the stock BC lengths (since the BC coils are different lengths front and back).
Old Mar 17, 2010 | 12:51 PM
geekswrath's Avatar
geekswrath
I thought the BC's came with 6" springs front and back with a 7/6 rate.
Old Mar 18, 2010 | 06:26 PM
user 7082082
D Unit is right about trying to keep the same lenght. My bc springs came with 8k front and 6k in the rear. My car has no sunroof, no back seats, and is right around 2650lbs with me in the car. I think going to 6k front and 5k rear will make the car ride a lot better.
Old Mar 18, 2010 | 08:24 PM
JamesHunt's Avatar
JamesHunt
6.5 to 7k all the way around
I will run 7k all the way around after consulting with Pete at BC about total weight and tire.
Old Mar 27, 2010 | 11:13 AM
oda's Avatar
oda
just changed to bc racing! the ride is good but i've got a problem, there is some clunking sound from the front left suspension when turning (slowly or at idle) ...anyone know whats the problem?
Old Mar 28, 2010 | 07:35 AM
Creeve's Avatar
Creeve
the front endlinks are probably hitting the control arms.
Old Mar 28, 2010 | 11:06 PM
oldcracker's Avatar
oldcracker
what would cause the front endlinks to hit the control arms?
Old Mar 29, 2010 | 05:26 AM
Creeve's Avatar
Creeve
Being lowered more then 1.5" or so. Some coilovers come with different endlinks for this reason.
Old Mar 29, 2010 | 05:37 AM
oda's Avatar
oda
so does it means i have to change my endlinks ?
Old Mar 29, 2010 | 09:42 AM
JamesHunt's Avatar
JamesHunt
if the endlinks are not adjustable you will need to purchase replacements .
Old Mar 29, 2010 | 10:48 AM
oda's Avatar
oda
they are the stock ones any advice on which endlinks to buy?
Old Mar 29, 2010 | 10:54 AM
oda's Avatar
oda
and there is only a clunking sound on the front left, shouldnt it happen on the right too if thats the case?
Old Mar 29, 2010 | 11:49 AM
Creeve's Avatar
Creeve
Maybe cause of the unequal load of the driver being on the left side? Just a guess.
