Suspension WHOAH! Fantastic new suspension additions!
Old Mar 11, 2010 | 05:56 PM
Headlands's Avatar
Headlands
So I went to Mini Corsa and had him install the Hotchkis 19mm rear sway bar and Madness polyurethane front control arm bushings.
Now THIS is how a Clubman S should feel! Tight and direct steering, barely any leaning in turns, and now I know why good drivers don't like understeer -- with the rear sway bar in the middle setting, oversteer is now more present and is positively delicious. I'm LOVING these additions. With the Koni FSDs and these two new items, I feel like my MINI is now ready to take on anyone, handling-wise.
EDIT: Torque steer is lessened a tiny bit, though it's still there of course. Bump steer has not been helped at all. These two things are just what one has to accept in a MINI.
Just thought I'd share for those who might be on the fence with either or both of these things.
Old Mar 11, 2010 | 05:59 PM
JamesHunt's Avatar
JamesHunt
I have torque steer in 4th
Old Mar 14, 2010 | 05:45 PM
etalj's Avatar
etalj
get those squidgy Powerflexes out and get some spherical bearings
Doesn't minimania make them? I think they might come with lighter FLCA
Old Mar 14, 2010 | 06:05 PM
Dr Obnxs's Avatar
Dr Obnxs
Mini Madness
discontinued the front control arms, and they were a 1st gen part. The powerflex units are fine. The stock ones suck.
Matt
Old Mar 14, 2010 | 06:15 PM
etalj's Avatar
etalj
Matt
Hehe I'm joking, powerflex is an awesome company. I was just teasing Mr. Hunt
Old Mar 14, 2010 | 06:20 PM
JamesHunt's Avatar
JamesHunt
I need to get a diff installed maybe by april
I need to get the turbo dialed in
I need to upgrade the fuel system
I need to sell this moneypit and get a Panamera Turbo
Old Mar 14, 2010 | 06:39 PM
drewstermalloy's Avatar
drewstermalloy
Haha, you could spend almost 100 grand on mods for your MINI before buying that boat.
Old Mar 14, 2010 | 06:50 PM
gawannamini's Avatar
gawannamini
Torque steer and bump steer are both lessened, though they are still there of course. These two things are just what one has to accept in a MINI, though now they're not quite as bad as they were before these new installs.
How noticable an increase in road vibrations/road noise did you experience from the bushing changes?
Old Mar 14, 2010 | 07:07 PM
JamesHunt's Avatar
JamesHunt
What would you rather have , a 130,000 dollar Mini or a 130,000 dollar Porsche ?
as soon as the Turbo S comes out I will send the mini across the pond to keep the GT3 company.
Old Mar 14, 2010 | 08:37 PM
etalj's Avatar
etalj
$130,000 MINI
My cousin had Powerflex LCA bushes installed in his R53, no change in NVH
Old Mar 15, 2010 | 06:56 AM
Aeromax's Avatar
Aeromax
No wait, a $130,000 Mini, a $130,000 Porsche, or a $130,000 Panamera?
Old Mar 15, 2010 | 06:47 PM
Headlands's Avatar
Headlands
I have truly not noticed any difference in NVH with the new bushings. There are no negatives to be had for me.
I was hoping for better control of MINI bump steer, but unfortunately that didn't happen beyond a very subtle difference. I guess MINIs are just not very well designed as far as that's concerned.
Old Mar 15, 2010 | 09:55 PM
thevelourfog's Avatar
thevelourfog
I'd take a $130,000 Kia Accent over a Panamera. Is that an option?
Old Mar 16, 2010 | 12:03 AM
Dr Obnxs's Avatar
Dr Obnxs
This is going off topic a bit.
When the Panamera came out, I too hated it. But at the SF Auto Show, I got to spend a bunch of time in the car. It's really, really well done. You'd be shocked at how much rear space is in the car. No, it's not a 911 or a Cayman, but for what it is, it's shockingly good.
Matt
Old Mar 16, 2010 | 12:09 AM
etalj's Avatar
etalj
Has anyone here installed alta PSRS and noticed a reduction in bump steer?
Old Mar 16, 2010 | 04:21 PM
Headlands's Avatar
Headlands
I had a few people tell me that bump steer would be noticeably reduced with these bushings, but I found that to not really be case (again, just a very subtle difference). Most people were not speaking very highly of the Alta PSRS bushings, in comparison to the polyurethane ones, when I asked.
Old Mar 16, 2010 | 04:35 PM
etalj's Avatar
etalj
Really? What are the sort of things being said?
Old Mar 16, 2010 | 04:45 PM
Headlands's Avatar
Headlands
I erased the other messages I had, but this one was still in my box, from a fellow member here:
"Stay away from the problematic Alta PSRS as the poly bushings do the same job without the constant rattles and harshness of the Alta crap. The poly bushings were not available when I had the PSRS installed and I sure wish they were around then. I consider the Altas a liability now."
Old Mar 16, 2010 | 05:10 PM
etalj's Avatar
etalj
That's annoying, I hadn't heard anything but rave reviews of them from people that I consider MINI gurus (eg. Ryephile and Dr. Obnxs).
Thanks for your input though, I appreciate it. My PSRS are going in tomorrow, I hope my experience will be better. (I don't have access to a welder unfortunately, so I won't be able to tack weld the sleeve to the control arm, which I've heard helps things)
Old Mar 16, 2010 | 06:52 PM
ron-s mini's Avatar
ron-s mini
+1 on the PSRS !
Old Mar 16, 2010 | 10:17 PM
ALTA_Jarid's Avatar
ALTA_Jarid
Ive had PSRS bushings on my GP since about 3k. About to hit 23k (Probably tomorrow) and no noise or rattles/harshness. Im not only in sales....I'm also a customer
Old Mar 17, 2010 | 02:24 PM
Headlands's Avatar
Headlands
Perhaps these members installed/had them installed improperly? I dunno. What I do know is that the Madness poly bushings are truly fantastic on my car and don't require any welding to install. I can't compare personally since I've never used the PSRS bushings myself.
Old Mar 17, 2010 | 02:37 PM
BlimeyCabrio's Avatar
BlimeyCabrio
Matt
To continue this thread-within-a-thread... I also hated it - until I saw one in the flesh at Mandalay Bay last month. Love at first (real) sight.
And, yeah, swaybar + bushings are goodness. Just need camber plates for ultra-goodness.
Old Mar 19, 2010 | 08:11 AM
drewstermalloy
I'd say a one-of-a-kind MINI, but I wouldn't spend $130,000 on one car even if I had the money, but that's just me.
Old Mar 19, 2010 | 09:56 AM
Dr Obnxs's Avatar
Dr Obnxs
I bet
that if you did have the money, you'd think differently.
Matt
