Suspension Help me decide on my suspension set up
Old Nov 3, 2009 | 09:44 AM
thevelourfog's Avatar
thevelourfog
I'm gonna ask something many have asked before. Should I get KW V1's or NM Engineering Springs and a 19mm rear sway bar?
I have Challenge Wheels with 215/45's so I'd need 5mm spacers if I get coilovers I believe.
I'm looking for a modest drop, maybe around 1"-ish. My main concern is getting rid of some of the body roll I'm experiencing with my base suspension and improving handling in general. I auto-x rarely but do drive aggressively, so I don't know if coilovers are overkill. Should I get adjustable endlinks if I get the rear sway bar? Should I consider camber plates instead of a rear sway bar?
Thanks!
Old Nov 3, 2009 | 10:19 AM
andyroo's Avatar
andyroo
I would get the KW's simply because of the extra suspension travel. Lowering the car on stock struts is like starting with 1 hand tied behind your back....
Just my opinion.
- Andrew
Old Nov 3, 2009 | 03:40 PM
etalj's Avatar
etalj
coilovers + camber plates > Springs + Swaybar
Old Nov 3, 2009 | 09:02 PM
slinger688's Avatar
slinger688
Thanks!
When you drive aggressively on the street, what do you not like about the way the car handles?
Old Nov 3, 2009 | 09:33 PM
thevelourfog
Feels like it's got a lot of body roll and could use some more grip.
Old Nov 3, 2009 | 10:19 PM
slinger688's Avatar
slinger688
Springs will help the body roll. Lowering will help you with the overall grip since it reduces the cg. A sway bar will help you with the body roll as well but do not overdo this as it will cause oversteer and the back end can step out. A 19 mm is generally fine and will not cause the inner rear tire to lift off the ground in a turn. If you lower the car, you should get end links to keep the sway bar level and balanced. It is perfectly OK to go with springs if you are doing street driving. Most people like coils as it gives them adjustability. Coilovers such as KW V1 are generally not recommended for heavy duty track use.
Camber plates will help you with the understeer or push. Since you did not specifically mention that problem, you can do those incrementally at a later time.
Tuning a suspension can be done incrementally and is not a one size fits all such as do these 5 things and your car will handle perfectly. It depends on the problem you are trying to solve, what you do with the car and how you drive. Try a few things and see how if suits you, then try a few more.
Hope this helps.
Old Nov 3, 2009 | 10:31 PM
IceManMCS's Avatar
IceManMCS
Slinger688 said it perfectly.
From what you stated, you definitely don't need coilovers. The NM springs and a stiffer rear sway bar would be a great starting point. Fixed camber plates and adjustable rear control arms could would be the next small step to further improve handling and prevent uneven tire wear.
Old Nov 3, 2009 | 11:17 PM
thevelourfog
It sounds like I should go for the springs rear sway + endlinks first and see where that takes me. I can always get camber plates later and coilovers if I start driving more seriously.
If I was tracking the car a lot I'd go for the KW V2's at the min. from what I know. Suspension tuning in the past for me has always been springs and bilsteins/konis so I'm a little lacking in the specifics of the other components.
Thanks!
Old Nov 4, 2009 | 04:18 AM
slinger688's Avatar
slinger688
You can also improve the grip substantially with a proper choice of tires.
The rear control arms may be necessary (depending on how much the car is lowered) to give you adjustability of the rear camber and toe beyond what is avialable from the factory.
These do not help much with the body roll.
Old Nov 4, 2009 | 07:55 AM
thevelourfog
My tires are 215/45/17 Star Specs. I feel like the tires are giving me excellent grip, but suspension is the next step to improving handling.
Old Nov 4, 2009 | 07:57 AM
slinger688's Avatar
slinger688
Great tire. I wore down two sets this summer.
Old Nov 4, 2009 | 08:29 AM
thevelourfog
Yeah, zero complaints about this tire, they're just about perfect!
Old Nov 4, 2009 | 10:19 AM
LiLReD1's Avatar
LiLReD1
Just my opinion.
- Andrew
+1
and yer 215/45 tires sound kind of tall. If you desire a good stance with the right look of a drop coil overs are also adjustable so you can get that look you're looking for. Coil overs is the only way to go for myself.
Old Nov 4, 2009 | 12:21 PM
Robin Casady's Avatar
Robin Casady
215/45-17 tires are generally 24.6" dia. The 205/45-17 Dunlop SP Sport 01 DSST runflats that came with my 2007 MCS were 24.5" dia.
Old Nov 4, 2009 | 12:37 PM
LiLReD1's Avatar
LiLReD1
Tire calcs are showing almost a 1/2" difference. 24.26" on the 205, and 24.6 on the 215. Still not that drastic. Some reason I was thinking 40 series on stock 205 at the time.
Old Nov 4, 2009 | 01:37 PM
Robin Casady
I was using TireRack spec numbers. The online calculators are theoretical. I assume the TireRack numbers are closer to real life.
Old Nov 4, 2009 | 01:53 PM
andyroo's Avatar
andyroo
God i want some Mini Challenge wheels for my R53. So hot.
- Andrew
Old Nov 4, 2009 | 02:25 PM
thevelourfog
Whoops I meant 215/40's
Old Nov 10, 2009 | 01:24 PM
LiLReD1's Avatar
LiLReD1
- Andrew
I'm actually considering selling those.
Finhead
105
Aug 14, 2023 07:51 AM
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
ccccPUNISHER
Aug 20, 2015 09:02 PM
nomar116
Aug 10, 2015 11:24 PM
