Suspension Anyone got Bilstein Shocks on their R56 yet?
Old Aug 16, 2010 | 07:19 AM
  #126
MCS Fever's Avatar
MCS Fever
Still stock S suspension, leaning towards either FSDs or B6s and probably justa springs for best possible ride.
Spent 8 hours in the saddle yesterday on a 300 mile trip over Chinook Pass (5,400ft elevation). Lots of twisties and bumps. Almost made the 1,200 miles "break-in" point, 150 miles to go. I will say you get used to the ride on that long a drive. The only thing wearing out was my right leg and foot with not using cruise control during break-in. Wife took over after about 6 hours. We felt no worse for wear than we would have in my 2008 GMC 3/4 ton crewcab diesel truck, or the PT Cruiser that the MINI replaced.
Darn if the left front wheel didn't come loose not even halfway into the trip, started feeling something like a wheel bearing thumb, thump, thump only in tight left turns. Just had the wheels changed out at Les Schwab a week ago, so pulled over in the 96 degree heat and check the lugs. Sure enough, very loose. Glad MINI has a lug wrench in the car, even with no spare.
Got in late have to remove and check it tonight for lugs and wheel damage. Hopefully none. Will switch that wheel to the rear regardless. And check torque every few days for awhile! The new wheels had stickers on the back of them right on the lug mounting area. Thinking Les Schwab did not clean off the sticker material fully, or poor torque job, or skipped that wheel torque all together!
Post #11 here makes me wonder if they torqued them to 88 ft lbs in error.....
https://www.northamericanmotoring.co...ut-torque.html
Also they never said to come back in 50 miles to re-torque them...
Old Aug 16, 2010 | 10:01 AM
  #127
MCS Fever's Avatar
MCS Fever
Hmmmm .. Just called the dealership parts dept - And he said there are 3 levels of springs, and that my car does not have the sport suspension. Says it already has the softest springs.....
I see that's true in the MINI configurator - a $500 option you can add even to a justa....
So now it's just down to which struts/shocks.... FSD or B6.......
Old Aug 16, 2010 | 12:42 PM
  #128
tvrgeek's Avatar
tvrgeek
As best as I have gathered:
Justa in the 3.2K range, MCS in the 4.9K range and Works option "slightly stiffer" I believe the works option is also linear, where the base and S are slightly progressive. Maybe. Series one were quite a bit softer, 2.9K on the Justa.
I guess we could all plead you to go FSD just so we got some feedback.
Old Aug 16, 2010 | 12:49 PM
  #129
andyroo's Avatar
andyroo
Where did you get the info that the MCS springs are almost 280 lbs/in? I'm not sure I believe it.
- Andrew
Old Aug 16, 2010 | 05:53 PM
  #130
MCS Fever's Avatar
MCS Fever
FSDs for sure.
Well I took that wheel off that came loose, thankfully no visable damage to the lugs or wheel. Torqued them all to 103 ft lbs per the manual. They were more like 50 ft lbs from Les Schwab, set the torque wrench to 88 and it still turned them a bunch.
Old Aug 17, 2010 | 08:43 AM
  #131
andyroo's Avatar
andyroo
From TSW:
Originally Posted by txwerks
OEM rates are "freakin' coat hangers" (~150 lb/in) in the front and 212 lb/in rear.
- drew
Old Aug 17, 2010 | 01:44 PM
  #132
tvrgeek's Avatar
tvrgeek
That would have been Gen one Justa. I came up with the value by comparing vendors that gave their ranges as well as a % change from stock MCS. At least two did. As the gen 2 MCS is still slightly too stiff on the spring, and having driven the Justa and first gen Justa mush-wagon, I tend to believe these numbers are in line. Rember that the OEM springs have some amount of "tender" or progressive rate so measurement is not as simple as a scale and a brick.
Finally got the front end to chirp a tad, so my setup still has basic understeer. I will leave the bar adjustment alone.
Old Aug 17, 2010 | 01:59 PM
  #133
andyroo's Avatar
andyroo
No, i got that from TSW's thread on their replacement springs for R56....I should have posted the link. Their own TSW springs for the R56 come in at 229 front 260 rear or something. Seemed like they got pretty good reviews.
I think they measured R53 at around 160-ish front and rear.
In my experience advertised "% increases from stock" from vendors are highly susceptible to marketing spin and should never ever be taken as fact, espcially with progressive springs. Depending on the intended market, the percents may be fudged or taken from different parts of the progression to provide the user with a certain perception about the spring that may not be that accurate in reality. When they don't post the actual number, you have to take it with a grain of salt.
Remember the "feel" is deceptive because of the highly progressive and highly active bumpstops.
Unfortunately not many people care about the actual spring rates of most of the aftermarket springs out there.
Would like to see what the NM springs are.
- Andrew
Old Aug 18, 2010 | 01:34 PM
  #134
tvrgeek's Avatar
tvrgeek
Listed as 4.3 and 3.7 progressive. As they are progressive, a single number is useless. About all I know is members seem to like them very much.
R53 at 160-ish. That's right in what I had heard, 2.9K or so. TSW, 4 to 4.7. About what I had.
Here is the list of what I have gathered:
Apex/Moss Sorry, $30 a spring just can’t be good.
B&G S2 1” “higher rates” progressive
Dropzone 1.5
Eibach 1.2,” 3.2 to 4.3 progressive
H&R 1.25” 4.9
Koni 1.2”
M7 1.5 progressive
Mach V Technic 1.25” 5.1, 5.1 progressive
Mini R53 0 2.9, 2.9
Mini Base 0 3.2-ish
Mini R56 0 4.9K–ish
Mini JCW .4”, lin (stiffer)
MiniMadness Sport 1 progressive
Mini Mania 1.2” looks prog
MiniMania perfor 1.25 stiffer
NM 1.2 1.2” 3.7, 4.3 prog.
TSW 1, .75 4, 4.8 Linear
Tein-STECH 1.2, 1.1 3.8, 4.5 progressive “style”
Tien HTECH .6, .5 3.7, 4.1 “luxury”
I have numbers for a lot of coilovers too. The basic trend seems to be about what I would expect. I agree, for many the drop and the price seem to be important, not the handling.
Old Aug 18, 2010 | 01:43 PM
  #135
andyroo's Avatar
andyroo
Where are the NM rates posted? I've been looking for those.
I have an "in" and i'm going to see if i can get the actual stock spring rates and maybe even a shock dyno of the stock struts. We'll see.
I do mostly trust TSW's measured rates but would still be nice to see some verification. I really don't trust advertised percent increases.
- Andrew
Old Aug 18, 2010 | 01:52 PM
  #136
tvrgeek's Avatar
tvrgeek
I have a set of R56 struts with only 10K on them available for testing. My stock springs are, of course, on the car.
No idea where I dug TSW rates up. I made a lot of calls and e-mails, and did a lot of Googling.
Old Aug 18, 2010 | 02:00 PM
  #137
andyroo's Avatar
andyroo
^ might take you up on that in a month or so. We are considering doing a set of springs for the R56. Mild drop, 10 to 15mm at most. Nice medium rates....probably do some fairly firm spring rates a starting point to test from. With the mild drop it should ride well thanks to staying off the bumpstops more and dealing with the overdamped stock struts. Will of course change with testing and the shock dyno.
The numbers i had for the R56 were posted by TSW somewhere deep in this thread:
https://www.northamericanmotoring.co...ming-soon.html
- Andrew
Old Aug 20, 2010 | 05:36 AM
  #138
MCS Fever's Avatar
MCS Fever
Done! Order placed last night, confirmation says shipping in 1-5 days. So should have them within a couple weeks.
A local club member sent me his FSD results on 2 cars:
FSDs made a big difference in the ride and handling - they take the shock and judder out of rough pavement and are very firm when required for cornering. We wanted our cars set up for back road touring rather than track days and are very pleased with the results. In addition to the FSD's I also put 16" wheels with higher profile tires, ( 205-50-16 Michelin Pilot Exalto A/S). My car also has the MiniMadness 22 mm rear sway bar and both cars have the M7 strut tower brace. We are very pleased with the ride and Handling - just got back from a 3,000 + mile trip to MINIs in the Mountains where we took part in sevaral "spirited" mountain drives (like the drive up to 14, 173 feet on Mt. Elliot) and some long drives on back roads on the way down and back (Denver to Boise in one day) and were very comfortable - don't think I would have done that on the stock S suspension and 17" run flats...
I also did Hawk Ceramic Performance brake pads when we did our FDS Struts - less brake dust, very quiet and great performance in all but very high speed tracking.
Welcome to the club -
Another local club member that also has FSDs on 2 cars, WORD:
I have FSDs on both my MINIs. I am just returning from a 3,000 plus mile trip in my wifes MINI and the ride was great even fully loaded with our belongings and all my wife bought along the way. I had the FSDs installed just before we departed.
FSDs smooth out the ride through it's damping action. They are great for touring. I use mine with the original springs. I do believe that you will be very pleased with them.
Old Aug 20, 2010 | 10:45 AM
  #139
tvrgeek's Avatar
tvrgeek
Excellent. I know the BMW 3 series folks love the heck out of them, and they were all Bilstien guys.
Old Aug 20, 2010 | 05:36 PM
  #140
MiniCuse's Avatar
MiniCuse
I ordered a set of Bilstein HDs from Bavauto today to go with the NM springs that will be here monday.
Old Aug 22, 2010 | 12:08 AM
  #141
chilimini81's Avatar
chilimini81
^ very nice, you won't be disappointed!
Old Aug 22, 2010 | 05:32 AM
  #142
futuremini's Avatar
futuremini
Old Aug 26, 2010 | 05:55 AM
  #143
MCS Fever's Avatar
MCS Fever
FSD lady arrived today via FedEx home delivery. Pretty quick shipment...... Here's were I got them from:
http://jdmultimate.com/store/product...?itemid=342345
Exactly 1 month from taking delivery of the MINI......
Old Aug 31, 2010 | 08:56 AM
  #144
BostonR56S's Avatar
BostonR56S
hey chilimini81... could you send me an email at erik.kong88 [at] gmail.com?
I saw you have mach v springs matched with the bilsteins... I had a few questions if you didnt mind... and I don't have PM's unfortunately... thanks!
Old Sep 1, 2010 | 05:24 AM
  #145
D-Unit's Avatar
D-Unit
Ask 'em here if you don't mind. That way everyone can be informed.
I'm still on the fence between the bilsteins and the konis. The only thing really pulling me towards the konis is the adjustability.
Old Sep 1, 2010 | 02:34 PM
  #146
tvrgeek's Avatar
tvrgeek
Then you are looking at Koni yellows. Very different shock. My experience with them is they my be too stiff for street use on the Mini. The FSD is a very different animal. I might also note the RSX crowd had a lot of problems with Yellows blowing out. Different car for sure. If you want to drive yourself crazy adjusting shocks, go all out and grab the PSS10's.
RSX base had more low end torque than the type S, so it was more fun. Nothing like the MCS torque! I hated the way the manifold snapped in and out and the abrupt action of the v-tech. Much worse wheel hop than the Mini. It was half the car my 88 Prelude si was. But, it was a very high quality and durable car. I had zero manufacturing defects and only one warrantee repair in almost 180K. Sure can't say that about my Mini.
Old Sep 1, 2010 | 02:59 PM
  #147
wrx_xb9r's Avatar
wrx_xb9r
There is not that much adjustment needed on the PSS10's. I have basically set and forget. If I do AutoX or track day then I will need to adjust again.
I love mine.
Old Sep 2, 2010 | 01:03 PM
  #148
tvrgeek's Avatar
tvrgeek
wrx, if you would let folks know what street and track settings you use, it could reduce the amount of fiddeling others will do. Needed or not, there is the temptation to go one click here and there just to achieve some perfection that never comes. Without adjustments, you spare yourself the torture.
Old Sep 2, 2010 | 01:36 PM
  #149
wrx_xb9r's Avatar
wrx_xb9r
Street use.
My wife prefers 2 I prefer 3-4 all around.
Autocross
I am not sure what is best yet.
I am leaning towards 6 on the fronts and 5 on the rears.
No track days yet. Expect similar to Autocross.
Old Sep 2, 2010 | 01:43 PM
  #150
tvrgeek's Avatar
tvrgeek
Useful for all. Good show!
