Suspension Feedback on camber plates requested.
Old Jun 24, 2009 | 03:47 PM
KrautHammer's Avatar
KrautHammer
My 2009 R56S with the dealer installed JCW suspension kit tells me that it needs about 1 degree of front camber but the stock mounts have only given me 0.6 and lost one locator pin in the process.
After doing a lot of reading in the forum's database I have some questions left unanswered.
What I look for in camber plates, fixed or adjustable, is:
- Aprx 1 degree of camber, no more than 1.25 max.
- Plates with OEM style rubber bushings as I don't want race car clutter.
- Plates that will not change the ride height.
- Plates that have adequate OEM spring to body panel clearance.
Thanks guys.
Old Jun 24, 2009 | 06:36 PM
Lil Blue Coop/Mini Rose's Avatar
I have IE Fixed Camber plates. These add approximately 1.25 degrees of negative camber to the front suspension. Great addition.
Old Jun 24, 2009 | 07:26 PM
STLMINI's Avatar
STLMINI
I've heard some horror stories about IE plates from a while back. Don't know the problems have been resolved or not. I just posted a question on a related thread and hopefully someone can clarify if they've fixed it.
I went ahead and got the Vorshlag plates from Outmotoring.com. They are more expensive but people aren't experiencing the issues that IE had with them.
Old Jun 24, 2009 | 08:06 PM
BlimeyCabrio's Avatar
BlimeyCabrio
The issue was with the IE *adjustable* plates - which have since been redesigned - but they're not the ones you want because you say you want OEM style rubber bushings. Only the IE *fixed* plates have those. They are a very well executed design. But they WILL raise you about 1/8".
BTW - you'll want more than -1 deg of front camber. More like -1.75 to -2.0 is better for handling and tire wear for most folks - and that's what you get with the Ireland fixed plates.
Old Jun 24, 2009 | 09:15 PM
AutoXCooper.com's Avatar
AutoXCooper.com
The issue was address way back when it happen and after 18 months and dozens of sets installed I have not had any customers with issues.
The fixed plates work very well for most daily drivers and the only time we encourage adjustables is for drivers really looking for track and or AutoX fine tuning. Funny thing is, most end up setting them near -1.75 and never touching them again.
Old Jun 24, 2009 | 10:21 PM
billie_morini's Avatar
billie_morini
I, too, have Ireland Engineering Fixed Camber plates. Bought them used. These plastes add about 1 degrees of negative camber to the front suspension. They are a great addition that really reveal themselves at the apex of a turn. Action at the apex is faster and more precise. MINI should send these automobiles from the factory with this type of camber plate.
Ride height is not changed.
Works very well with stock suspension (that is what I have still, but one day...)
There are black plastic caps that can be inserted in the top of the shock tower and you would never know these camber plates are installed. Heck, you can hardly tell without the plastic cap.
Old Jun 25, 2009 | 04:45 AM
KrautHammer
Thanks guys, very helpful.
So it looks like the Fixed Irelands are the best way to go but the ride height issue is unclear.
billie_morini experienced no ride height change while BlimeyCabrio got 1/8 height increase and I wonder if this may be due to the plates starting out at +1/8" and settling down to 0 once the rubber insert settles after some driving.
I would not want any height increase up front as the car has a pleasant stance now that the JCW bits have settled down.
BTW how long does it take to install them -not including the alignment- and are there any tricky paths to follow?
Old Jun 25, 2009 | 05:19 AM
BlimeyCabrio
It's 1/8"... which is very minor, most people never notice it, it's so small. But they *do* raise ride height by the thickness of the steel reinforcement plate on the IE plates (about 3mm). At least they do on the 1st gen cars. 2nd gen may be different - I haven't compared stack height of the IE plates with the 2nd gen OEM upper strut mount.
Mine were still about 1/8" higher AFTER settling.
Takes me about 1 to 1.5 hours to do camber plates now that I've done it a few times. Took me about 3 hours the first time. For the first gen cars, keith did an excellent diy for springs - camber plates require the same steps. 2nd gen is similar:
https://www.northamericanmotoring.co...ll-how-to.html
Old Jun 25, 2009 | 06:43 AM
KrautHammer
... they *do* raise ride height by the thickness of the steel reinforcement plate on the IE plates (about 3mm). At least they do on the 1st gen cars. 2nd gen may be different ...
The difference between R53 and R56 may be the answer you think?
Interesting that the camber plate -which is also acting as the top mount, correct?- is retained by the same single bolt that holds the spring top plate. Or am I missing something here?
Old Jun 25, 2009 | 07:17 AM
STLMINI's Avatar
STLMINI
Vorshlags don't increase the ride height at all and they adjust out to -3 degrees. The R56 doesn't need to be heightened. Eeek!
Old Jun 25, 2009 | 07:54 AM
snid's Avatar
snid
The ride height change amounts we are talking about are less than the ride height change you get when you replace your worn out tires with brand new tires.
If you don't notice the change when you change tires, you won't notice the change when you add camber plates.
Old Jun 25, 2009 | 09:04 AM
AutoXCooper.com
You are right and it's the same setup on the OEM system. The Camber Plate replaces the OEM "top plate" and on the IE system you use the OEM top spring plate/cup/holder but others, like Vorshlags, do/may come with a custom spring plate/cup/holder too.
Old Jun 25, 2009 | 10:01 AM
BlimeyCabrio
... but they don't have the rubber bushing the OP asked for.
Old Jun 25, 2009 | 10:51 AM
RUMM's Avatar
RUMM
I was going to install the IE adjustables on my R56 when I put the TSW springs in but decided not too at the last minute since I'm probably getting a 2010 WRX this fall since they are finally coming with a 6 speed manual. First $100 takes them including freight.
Old Jun 25, 2009 | 01:48 PM
billie_morini
Put me in the club that never noticed the 1/8 inch change in ride height.
Install time: not long; hour or so for left and right
Old Jun 25, 2009 | 10:26 PM
dunphyj's Avatar
dunphyj
i disagree with some of the people here saying you need a lot of camber... you really don't with the mini and most european cars because they naturally have a lot of CASTER, which when the wheel turns gives you camber naturally... what i suggest is a more "sedated" approach, i'm running -1.5 degrees negative camber all around, Vorshlag plates and custom coilovers wiht TSW rear lower control arms... i don't run as much static negative camber because of the amount of caster the MINI has... now, my car is a doulbe duty car, daily driver and track car, so that's one reason i run less camber, but obviously the amount of camber is kinda more up to the user... i have seen no wear problems with my set up at least. and the car still handles great... can outhandle my friend's suspension only modded STI 04, then again that could be due to my 225 tires on my wheels...
i'm just saying, personal opinion, that you really don't need a lot of static negative camber...
Old Jun 26, 2009 | 04:48 AM
BlimeyCabrio
Hmmm... I wouldn't consider -1.5deg "a little" and -1.75 to -2.0 "a lot"... the difference of half a degree (especially up front) is very little... now if folks were suggesting he run -3 or -4 deg of camber, that's A LOT - and too much for anything but maybe autocross... but I stand by -1.0deg being too little for spirited driving styles and your setup seems to reinforce that.
Old Jun 26, 2009 | 05:28 AM
KrautHammer
Good discussion and much appreciated.
Talked to Ireland yesterday and I am satisfied that the accurate height increase is 3/16". No big deal and I may end up grinding the top of the spring coil flat to maintain the current JCW suspension height.
The bearing-rubber bushing itself is the BMW Z4 unit with its 1.25 Camber mounted in Ireland's plate to fit the R56. Since my OE Camber is 0.3 I can probably wiggle a 1.25 - 1.50 final setting which is all that I am looking for in a street set up. dunphyj ^ is correct IMO.
Good news about the OE rubber to bearing configuration as one of my main concerns was noise.
Adjustables are not really for me as this car will see no more than an occasional track day and good alignment shops don't abound in my area.
The Irelands should be installed sometime next week and I can set about terrorizing innocent lifted truck drivers and assorted Miata folk with increased fervor.
Old Jun 26, 2009 | 05:34 AM
BlimeyCabrio
Cool - you'll be happy!
got_mini?
Oct 7, 2015 02:12 PM
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
