Suspension V-Maxx + S-Lites = No Low???
Old Mar 21, 2009 | 01:38 PM
Mr. Incredible's Avatar
Mr. Incredible
I just finished installing the front V-Maxx coilovers on my mini and to fit the stock S-Lites back on, I had to raise them nearly all the way up... What gives? Has anyone else had this issue? I'm leery to install the rears now.
Old Mar 21, 2009 | 08:38 PM
Ryephile's Avatar
Ryephile
If you're running taller than stock tires, that would be the concern.
Have you actually put the car back down on the ground? Did you read my Alliance review of the V-Maxx to get baseline spring collar positioning measurements using stock sized tires?
Old Mar 21, 2009 | 09:49 PM
Mr. Incredible
The car is back on the ground now and the ride is great, however, I want to be lower but the collars are preventing that. Fairly certain they are the stock tire size. Without going outside to verify 205/45/17.
Old Mar 22, 2009 | 11:05 AM
Ryephile's Avatar
Ryephile
The V-Maxx are designed to operate with a bit more comfort than stock with no more than a 2" lowering. Get the tape measure out a check where you're sitting.
Old Mar 22, 2009 | 05:08 PM
Wake|MCS's Avatar
Wake|MCS
Throw some wheel spacers on there, slam the car and be done with it.
Old Mar 23, 2009 | 09:08 AM
Mr. Incredible
new wheels may be in order...
Old Mar 23, 2009 | 05:51 PM
MUShadd's Avatar
MUShadd
buy mine
Old Mar 23, 2009 | 06:28 PM
DarthbladerNI's Avatar
DarthbladerNI
mine was like that. get some spacers and it will be fine
Old Mar 24, 2009 | 08:55 PM
MUShadd's Avatar
MUShadd
what size spacers did u go with?
Old May 16, 2009 | 11:34 AM
Mr. Incredible
I just wanted to update this for everyone. I have since bought and installed 5mm spacers for the front wheels and as you can see by the pics below, 5mm won't cut it, nor will 8mm by the looks of it. Plan on going at least 10mm if you want to be low.
Old Feb 25, 2010 | 11:29 PM
dustinhxc's Avatar
dustinhxc
Hey would 12mm be enough to slam it or 16mm? I have slites also
Old Feb 26, 2010 | 08:11 AM
Mr. Incredible
Hmmm, I ditched my S-Lites for some Drag DR-21. They are 17x7.5 et 45 and clear by a **** hair. You'll clear with 12mm spacers but then I think you'll have some rubbing issues in the back. I rub a bit on big bumps or dips on the highway when going along at a good clip.
Consider this...
If you run a 12mm spacer, you'll have PLENTY of room on the inside but you'll be out 5mm more than I am. I think it will look great with the proper drop, but I don't think it will provide you with optimum slammage because of rubbing.
Old Feb 26, 2010 | 09:04 AM
dustinhxc's Avatar
dustinhxc
Aww man those wheels look so nice.. I had some 25mm without lowering my car which looked sick but they rubbed on the back over bumps. So I'm sort of used to it but I want to really slam it dang.. Thank you so 16 it would rub worse I get it cool. Thank you! Ps I eventually plan to get some 18x7.5 will I need diff spacers then?
Old Feb 26, 2010 | 07:52 PM
JohnnyVillan's Avatar
JohnnyVillan
Dont worry too much about the rubbing, it's just plastic. It wont damage the tire and after a while it'll just wear away and give you more clearance.
Old Feb 26, 2010 | 10:26 PM
dustinhxc's Avatar
dustinhxc
haha that is awesome. 12mm it is. : )
Old Mar 16, 2010 | 12:05 PM
04indimcs's Avatar
04indimcs
I don't understand. How can you clear with a 17x7.5 et45 but not with an s-lite that's 17x7 et43 (with the 5mm spacers)? The 17x7.5 et45 is 8.4mm closer to the suspension that the s-lite with 5mm spacers...
Old Mar 17, 2010 | 10:30 AM
Mr. Incredible
haha, ya know... I never really thought about it. I might have gotten the et wrong on the S-lites, not sure. All I know is, I didn't clear with the S-Lites and a 5mm spacer and I do with these wheels.
Old Mar 17, 2010 | 02:46 PM
JohnnyVillan
I'd be willing to bet its the difference in tire size. It's not the wheels that hit the strut, it's the tire.
Old Mar 17, 2010 | 10:22 PM
not-so-rednwhitecooper
Yep.
ryGuyMCS
Oct 6, 2015 12:04 PM
vargasgal
Sep 17, 2015 10:02 AM
kjd186
Sep 9, 2015 10:02 AM
