Suspension Swift Springs dynoed
I would think that most here will be putting these Swift springs or rather lowering springs on OEM struts/shocks. Some do have aftermarket like Koni, etc.
So yes, it will work with OEM struts.
Dang.. I was under the impression that the Cross/JIC setup was the Bees Knees... That is why I went "all-in" with them... Now you have me thinking about the swift springs.
My current daily driving comfort is better than stock, but a little ***/bouncy for my tastes
I really only need 2 more people if the list still stands true. But then again its been such a long time Im sure that some people on the list got some other form of lowering springs so I'm going to have to check in with each person.
I just got off the phone with swift and here are pretty much the conditions
I'm going to need to get payment for the springs up front from the first 15 people that wants a set. But at the same time the first 15 people will get a drastic discount. These springs will end up retailing for 400 dollars, The first 15 sets will be around 200-250 per set, they will get back to me, and confirm the exact price. After everyone sends payment it will take about a month (4-6 weeks) and they will be in.
As for the specs of the springs, they are going to drop about an inch all around and the spring rates will be made more track oriented than most other lowering springs. I decided if I'm going to make lowering springs why try to compete with all the other lowering springs that are out, instead make a more affordable option to going to the race track.
Some of you guys are probably going to shy away from this because of the conditions but its the best I can do. I'm not going to make anything out of this nor do I need this because I run coilovers on my car. Just trying to help out the community thats all.
Anyways for questions or anything you can go ahead and pm me directly.
thanks
ninjlao
thanks
ninjlao
We do not have the exact rates, but Im thinking it will be around 4-5.5kg. They are not going to be coilover stiff. hehe. but they are going to bring the most the stock shocks can take.
By the way Mental brought up a point that I wanted to share with the community.
Originally Posted by M3NTAL
One more question - my main concern with the cross setup now is the "bouncy-ness" of them?
Originally Posted by Ninjlao
I don't really understand what you mean by bounciness. If you think it's too bouncy why would you increase the spring rate? Im guessing its not bounciness from it being too stiff. The spring rates that you have decided on, I think is a decent setup.
Another reason why the suspension might be bouncy is because Cross suspension does not come with rear top mounts, so you are still running on the stock rubber bushing that goes in the stock top hats. This could cause the bounciness that you are experiencing. Sounds odd but I have driven on many different setups and I refuse to drive with any coilovers that use the stock tophats.
I found two solutions to this problem:
-buy topmounts for the rear of the car and rigg it onto your Cross (Megan and BC makes them)
-buy the mini-madness polyurethane kit(not as effective because there is still slight flex)http://www.mini-madness.com/index.as...ROD&ProdID=260
I'm in for some springs as well, but my stock shocks are at 50k already so would it be better to get new shocks as well? If so which shocks would be best to run with the swift lowering springs?
koni yellows are popular with lowering springs. or bilstein sp's. plus side of the koni's is they are adjustable (rebound) out of the box. bilsteins can be revalved.
I already talked about that. It's possible but not likely. I need 20 orders of both front and rear, and the price is a bit more than 600 dollars for both. This is the reason why I didn't even bring it up.
Well, if the springs are going to be more track oriented, then I would say I am out. Kinda looking for something more practical for daily use, almost no tracking.
Thanks, ninjlao.
Thanks, ninjlao.
Unfortunately, I'm out too. As much as I would LOVE to have it track oriented, my MINI is my DD. Needs to be somewhat comfortable on day-to-day driving. After all, I need to keep it comfortable 'enough' for my wife and daughter to enjoy the ride too.
