Suspension HELP! Sway bar install emergency...
Old Sep 14, 2008 | 09:03 AM
SNEEEZY - Erika's Avatar
SNEEEZY - Erika
Rattle Can Queen!!!
I'm in the middle of installing a new rear swaybar on Schultze and I simply cannot loosen the two subframe bolts. I had very little problem loosening & removing the first two subframe bolts (the ones nearest the wheel wells) but I simply CANNOT loosen the other two subframe bolts.
HELP!!!
Erika
Old Sep 14, 2008 | 09:08 AM
minimarks's Avatar
minimarks
Have you tried soaking them good with liquid wrench? Sounds like they have seized.
Old Sep 14, 2008 | 09:12 AM
SNEEEZY - Erika
Rattle Can Queen!!!
Liquid wrench? Is WD-40 a reasonable substitute?
Old Sep 14, 2008 | 09:18 AM
minimarks's Avatar
minimarks
Not really. You need something that penetrate more and desolves the rust inside. There are different brands for this and usually require you to put it on and wait a little while. Just don't get in a hurry, you've got to work them loose. If you are like this , walk away ( go get the right product) and come back to it.
Old Sep 14, 2008 | 09:22 AM
SNEEEZY - Erika
Rattle Can Queen!!!
Ug. That means driving the Ford Escape since Schultze is up on jack stands right now.
I didn't think the bolts would seize with only 26K miles...
I suppose it's NOT a good idea to use the torque wrench to loosen, eh?
Old Sep 14, 2008 | 09:26 AM
minimarks's Avatar
minimarks
It's not very good on your torque wrench but you do need some sort of breaker bar and at least spray it down good with the WD-40. Good Luck!
PS: If ya went to the store you could also pick up some Anti-seize to put on all the bolts........
Old Sep 14, 2008 | 09:33 AM
kazlot's Avatar
kazlot
On the plus side you have a vehicle to go for parts and on the minus where you live will have an effect on bolts freezing up faster than expected.
Do your self a favor and NEVER EVER use a torque wrench as a breaker bar.
A torque wrench is for setting and checking the proper torque only.
If you use it as a breaker bar it will screw it up and you will not get the proper readings.
Ask me how I know...
Old Sep 14, 2008 | 09:38 AM
SNEEEZY - Erika
Rattle Can Queen!!!
Actually, the torque wrench question was tongue-in-cheek...
Headed to Burger King for sustenance and then to autoparts store...time for a BFH!
Old Sep 14, 2008 | 09:41 AM
CR&PW&JB's Avatar
CR&PW&JB
I hope in this case, the BFH is a Big F'n Hamburger.
Old Sep 14, 2008 | 09:43 AM
minimarks's Avatar
minimarks
and don't forget the Anti-seize to put on all the bolts before you put it back together.....
Old Sep 14, 2008 | 10:20 AM
SNEEEZY - Erika
Rattle Can Queen!!!
Well...THAT and a Big F'n Hammer! LOL
Just got back...time to eat & then CONQUER those two #@%&! bolts!!!
Gave the bolts a drenching of WD40 before I left and just now...the autoparts store didn't have "liquid wrench".
Old Sep 14, 2008 | 11:13 AM
Warped1966's Avatar
Warped1966
Do NOT put anti-seize on suspension fasteners! You want them to seize and thus never vibrate out of place!
Old Sep 14, 2008 | 11:24 AM
Yo'sDad's Avatar
Yo'sDad
They are just in there very tight, get a long breaker bar and apply some hero sized elbow grease. They will come loose, but even after you break them loose, then will still be hard to remove for several threads. Rent or borrow an impact wrench to get them out. I installed a new alta about a month ago, just on jack stands. Using an electric impact driver to remove the bolts in question, I was rubber on the ground and back to rubber on the ground in about 1 hour 20 min.
Good luck
YD
Old Sep 14, 2008 | 06:08 PM
erickvonzipper's Avatar
erickvonzipper
PB Blaster is as good as, if not even better than, Liquid Wrench.
Old Sep 14, 2008 | 06:17 PM
BlimeyCabrio's Avatar
BlimeyCabrio
+1 for PB Blaster.
+ a million for impact wrench (that's how I did mine).
Old Sep 14, 2008 | 06:22 PM
Crashton's Avatar
Crashton
If you are torquing the fasteners correctly having them loosen up on their own isn't going to happen. A good substitute for antiseize is blue #242 Locktite. Using it both locks the fastener in place & keeps moisture out of the threads stopping corrosion. The #242 is removable with hand tools. Don't use the red stuff unless you never want to remove that fastener again. Well it can be removed if heated with a torch.
Old Sep 14, 2008 | 06:43 PM
Warped1966's Avatar
Warped1966
We're just going to have to agree to disagree about anti-seize. I've always been taught that anti-seize is only for fasteners that are routinely removed (lug nuts/bolts, caliper fasteners) or low friction interference situations such as caliper sliders and such. I do agree wholeheartedly about the blue #242 loctite though.
Old Sep 14, 2008 | 06:46 PM
Apple's Avatar
Apple
use mayo just kidding
Old Sep 14, 2008 | 07:19 PM
SNEEEZY - Erika
Rattle Can Queen!!!
Here's an update:
https://www.northamericanmotoring.co...84#post2468784
Old Sep 14, 2008 | 07:25 PM
Crashton's Avatar
Crashton
I agree to disagree too. No mayo.....
Old Sep 15, 2008 | 11:08 AM
Yo'sDad's Avatar
Yo'sDad
The problem is that the four bolts in question go up vertically through the subframe and into the body of the car. It is hard to get a good shot of any sort of thread loosening agent to go uphill and past all that to get to the threads that are actually doing the 'hang on tight' act.
Impact driver and long socket extensions are a must.
YD
Old Sep 15, 2008 | 11:47 AM
justaguyinvegas's Avatar
justaguyinvegas
I second the impact driver.
Old Sep 15, 2008 | 04:19 PM
british RACING green's Avatar
i know karate
Old Sep 16, 2008 | 10:46 AM
SNEEEZY - Erika
Rattle Can Queen!!!
You guys are too funny!
Impact driver is on my list...as well as extension drivers.
Old Sep 27, 2008 | 05:15 PM
Ryephile's Avatar
Ryephile
That's amazing you can't get the subframe bolts out...as the chassis boss threads are hardly strong, meaning it's not tough to strip out the chassis for those 4 bolts. Are you using a proper 1/2" drive breaker bar...something a couple feet long? The fact your car is only a few years old means the car can't be seized up that bad! The bolts are only supposed to be torqued to 74Lb/Ft, IIRC.
+1 for PB Blaster. No shadetree mechanic toolbox is complete without it.
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
