Suspension R52 "Lower" Tension Bars on R53
Old Sep 12, 2008 | 03:21 PM
howsoonisnow1985's Avatar
howsoonisnow1985
R52 Subframe "Lower" Tension Bars on R53
Has anyone put the cabrios oem "lower", subframe, down below, underneath, (Tension Struts) bracing on a R53? I wanted to know if the holes are pre-drilled on the rockers and frame. I am NOT reffering to the ones that go in bonnet, from towers to frame. I am talking about the ones that are UNDER the car. Please look at pic below:
Old Sep 15, 2008 | 09:36 PM
howsoonisnow1985
nobody?
Old Sep 16, 2008 | 04:36 AM
PGT's Avatar
PGT
there is a whole thread about just this from a few days ago
Old Sep 16, 2008 | 05:21 PM
howsoonisnow1985
Yeah i accidently posted on it and brought it back to life but realized it was the "upper" diagnoal bars they were reffering to.
Old Sep 16, 2008 | 05:50 PM
Partsman's Avatar
Partsman
Legion_of_Doom
I look at those bars every time we have a cabrio on the lift and more often than not there is a hardtop on the lift next to it.
You will either need to use the cabrio rear axle carrier or have someone weld pads on to your carrier to mount the bars.
The two carriers have different part numbers.
It's hard to see if there are holes to mount the front part of the bar because the bolts go through the side skirt to the floor.
Old Sep 18, 2008 | 12:04 AM
howsoonisnow1985
I have the part numbers for the Tension bars, tension mount bar, and the bolts, but not the rear axle carriers. Did not find them on realoem, do you know the part numbers?
Old Sep 18, 2008 | 05:28 AM
Partsman's Avatar
Partsman
Legion_of_Doom
The part number for the cabrio rear axle carrier is...33 31 6 761 716
Here's the link to realoem...
http://www.realoem.com/bmw/showparts...27&hg=33&fg=30
...number 1 in the illustration is the carrier you need.
Old Sep 18, 2008 | 06:15 PM
howsoonisnow1985
Holly moly that looks like a bit of a PITA install
Old Sep 18, 2008 | 06:32 PM
Partsman's Avatar
Partsman
Legion_of_Doom
It would be a few more steps than a rear sway bar install...but not as bad as it looks.
Aug 19, 2015 12:21 PM
Aug 19, 2015 12:03 PM
Aug 12, 2015 01:24 PM
Aug 7, 2015 09:51 AM
