Suspension "new" Helix vs Megan Control Arms Quick ?
Old Sep 6, 2008 | 08:51 PM
jtack's Avatar
jtack
I have searched a lot regarding this and keep hearing that the heim type lower control arms (alta, helix, etc) are more noisy than than that of megan, h-sport, etc. Can someone describe this noise and harshness that is felt using the heim type control arm.
Whats the benefit of the heim type control arm?
Thanks!
Old Sep 7, 2008 | 11:12 AM
AutoXCooper.com's Avatar
AutoXCooper.com
and the NEW TSW arms came in Friday, look for more details soon. They will set a new standard in arms.
Old Sep 7, 2008 | 04:13 PM
spdfreak's Avatar
spdfreak
Come on Dustin you can't leave us hanging like that we need more info
Old Sep 8, 2008 | 10:33 AM
AutoXCooper.com
Here they are http://www.autoxcooper.com/tsw_suspension.html
Old Sep 8, 2008 | 10:41 AM
FeedBack's Avatar
FeedBack
From: AHHH!! The Weather...The Beach... The Bikinis!
Instead of hijacking the thread, how about an answer to the question!
Old Sep 8, 2008 | 11:18 AM
AutoXCooper.com
I was not hijacking the thread.
The Megan's don't make noise, they are rubber. The New TSW is also Rubber.
So the hi jacking police can relax.
Old Sep 8, 2008 | 12:43 PM
jtack's Avatar
jtack
why should I buy these instead of the new helix or the megans. I didnt want the megans because they are blue.
Old Sep 8, 2008 | 12:59 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Traditional heim joints are bearings, i.e. there is metal-to-metal contact between the moving parts. Stock control arms and many aftermarket ones use a rubber sleeve to allow for motion between the two parts. The rubber also isolates noise and vibrations from traveling through the joint to a certain degree, whereas heim joints can conduct noise and harshness through the joint. In other words, any noise, vibration or harshness imparted to or coming from the wheel/hub assemblies has a more direct path to the body of the car. You'll hear all the rocks and cracks in the road much louder inside the car versus a traditional rubber bushed joint. Also, since traditional heim joints are metal-to-metal, and looseness or play in the joint that arises as the joint wears will sound like a rattle as you travel over bumps, etc.
The reason why serious drivers use heim joints is that there is very little deflection in the joint compared to the factory stuff. The rubber has a certain amount of give, and when a lot of side force such as when cornering is applied to the joint, the joint gives, knocking the alignment out and reduces traction. This general sloppiness reduced the predictability and repeatablity in the suspension as well.
Many performance arms come with harder rubber or use a plastic bearing material to approach the accuracy of heim joints while still allowing some isolation of road noise. Also, heim joints need to be lubricated regularly and their open design leaves them vulnerable to dirt and moisture infiltration in daily driving. Rubber or similar aftermarket flexible joints are not affected like this and last longer in daily use and are often maintenance free.
Hope this puts the thread back on track.
Old Sep 8, 2008 | 01:14 PM
Jonv's Avatar
Jonv
Nice write up. I'm sure that's what he was looking for.
Old Sep 8, 2008 | 01:17 PM
jtack's Avatar
jtack
That is exactly what I was looking for!! Thank you very much!!!!
Old Sep 8, 2008 | 02:26 PM
flyboy2160's Avatar
flyboy2160
do the tsw bushings in the new arms have a solid sleeve up the middle?
Old Sep 8, 2008 | 02:34 PM
txwerks's Avatar
txwerks
Yup!
Old Sep 8, 2008 | 05:28 PM
spdfreak's Avatar
spdfreak
The Texas Speedwerks arms look VERY nice.
Old Sep 8, 2008 | 05:36 PM
Minitauro's Avatar
Minitauro
Will there be an R-56 application???
Old Sep 8, 2008 | 05:37 PM
AutoXCooper.com
There will be a test fitting soon to see what changes need to be made.
Old Sep 8, 2008 | 05:52 PM
HighLife4136's Avatar
HighLife4136
I wonder how the H-Sport arms compare?
Old Sep 10, 2008 | 09:59 AM
Ralph@Helix's Avatar
Ralph@Helix
Excellent write up. In regards to the OP's post I'd like to mention that our control arms come pre-lubricated and have boot sealed spherical bearings which means excellent long-term weather durability.
Old Sep 19, 2008 | 09:08 AM
Dave.O's Avatar
Dave.O
I currently have the New Helix control arms with boot sealed spherical bearings installed and have no problem with them at all.
The new ones are now powdercoated and weatherproofed.
*Repete* No Noise what so ever.
http://www.helix13.com/mini/products/suspension-chasis
Old Sep 20, 2008 | 01:32 PM
oxtox's Avatar
oxtox
+1, no noise, no worries. are very light to boot!
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
Toolman
Jan 20, 2016 06:50 AM
Manny_cooper
Nov 4, 2015 09:42 AM
LordOfTheFlies
Oct 19, 2015 05:02 PM
