Suspension Stratosphere VMAXX?
Old Jun 28, 2010 | 05:30 AM
  #201
iwashmycar's Avatar
iwashmycar
if you have the extra cash, youll be happier with the KWs im certain
Old Mar 23, 2011 | 02:50 AM
  #202
blackedout's Avatar
blackedout
HOW LOW IS THIS?
thanks
Originally Posted by VicSkimmr
Bump, after a few thousand miles, mine are still going strong. The ride is stiff, but that'll happen with any set of coilovers when they're this low.
Ride height with one person in it:
Old Mar 23, 2011 | 02:51 AM
  #203
blackedout's Avatar
blackedout
HOW LOW IS THIS?
thanks
Originally Posted by BuffMini
Well here it is... I Put them on my car at 900 miles and I'm rolling to about 13k, 5 auto-x days and a road rally plus one 2600 mile trip down south and 7 runs thru the Tail of the Dragon on my way back up north and my verdict is:
There OK...
Pretty stiff, not bouncy at all yet , But enough to get annoying sometimes espically living around a urban area...But Being decently low its my own fault i know
I had FK Silverlines on my 03 VW GTI on the last threads and I Still think it rode better.. but that might be due to the heavier car or longer wheel base..
So far for what I paid for them and there excellent service( Including them replacing my endlinks when the rubber boot failed)
So all in all you get what you pay, there not the $1600 set I used to own but there not bad!
Here's some pics
Old Mar 23, 2011 | 05:00 AM
  #204
Mini Fireman's Avatar
Mini Fireman
This low...
Old Mar 23, 2011 | 05:18 AM
  #205
iwashmycar's Avatar
iwashmycar
Looks around how low my car is at arches 23.5" off ground up front and 23.75" off ground out back.
Old Mar 23, 2011 | 06:18 AM
  #206
Stratmosphere's Avatar
Stratmosphere
Looks awesome
Originally Posted by blackedout
HOW LOW IS THIS?
thanks
Great shot!
http://www.stratmosphere.com/mini_drivetrain.htm
Old Apr 10, 2011 | 08:49 PM
  #207
PiemanPie's Avatar
PiemanPie
Hey guys,
I just installed these coilovers on my 07 MCS today. So far i love them, but i have 2 small issues that maybe you guys could help me with. First is that when i got the ride height and spacers on to clear everything, my ABS sensors are now going off... Ive done some research and im thinking it maybe due to the camber in the rear wheel, witch is pretty significant, or so my mechanic friend says. Apparently the ABS and DSC sensors will go off if the wheel tilts to much. My second problem is that when i accelerate from about 15-45 mph the car kind of whobbles alittle. when i let off the gas it stops, but when i press it it shakes. and only in that mph range. Dose anyone have any ideas?
Kev
Old Apr 10, 2011 | 10:13 PM
  #208
etalj's Avatar
etalj
Originally Posted by PiemanPie
Hey guys,
Kev
Could have disturbed the Wheel speed sensors. ABS and DSC will be disabled if it senses that the wheel speed sensor is not functioning correctly
Old Apr 11, 2011 | 02:43 PM
  #209
PiemanPie's Avatar
PiemanPie
Is there a way to reset them without going to the dealer?
Old Apr 11, 2011 | 06:54 PM
  #210
Mini Fireman
Vibration is normal after lowering due to the axles being worn in at your previous height. The added camber didn't cause your light to go on. You probably have a bad or unplugged wheel speed sensor.
Old Apr 11, 2011 | 07:11 PM
  #211
etalj's Avatar
etalj
I don't think it's a software issue, you most likely damaged or loosened one. Once you plug it back in (or repair it) the problem will go away.
Is it always there, or intermittent?
Old Apr 13, 2011 | 04:47 AM
  #212
PiemanPie's Avatar
PiemanPie
Its always there.
Old Apr 13, 2011 | 07:39 AM
  #213
SooperCuperErik's Avatar
SooperCuperErik
The wheel speed sensor (a wire by your front tires, next to your brake lines) are being worn and exposing the wires. The reason for this is when you're lower, the wire arches more, thus contacting rotating parts. This is what happened to me. I wrapped them in electrical tape as they haven't worn all the way out yet, and ziptied them to the brake line to make sure they don't rub anymore. Take off your wheel and stick your head behind the rotor, you'll see what i'm talking about. However if your light doesn't go off (mine went on and off intermittently), then your wire is prob worn too far and done for. $125 for new ones (either each or the pair) from the dealer.
Old Sep 20, 2015 | 03:13 PM
  #214
Chase Roberts's Avatar
Chase Roberts
Can i run 17x9.75 et25 all round with no camber adjustment in the rear? On a clubman?
I think the best thing you can do is do some searching....especially over on vwvortex. Tons of people are using them. Some love them some hate them. It's definitely a situation where you get what you pay for. Do a little research around the web as lots of other cars have had VMAXX's for some time now
I think they're a great alternative to just lowering springs when you want to go lower. These aren't meant to be track coilovers by any means......but for around $600 I think they're a good option for someone looking to lower their ride more than normal springs on a budget.
Im looking at xxr 527s, and im debating on vmaxx or waiting for st coilovers. Any advice? Also could i run the 17x9.75 on stock suspension. And lastly is it smarter to go wity 17x8.25 0 offset in the front only? Or just say **** it and go wide asf all the way around?
Im also interested in tire recommendations, im going for a decent strech in the back maybe none or just a little in the front
submitaweasel
33
Aug 21, 2018 12:12 PM
RIchard Nguyen
Sep 14, 2015 02:45 PM
RIchard Nguyen
Sep 14, 2015 01:02 PM
OutMotoring
Apr 7, 2014 12:38 PM
bgrpph
Oct 11, 2004 02:22 PM
