Suspension Lowered on H&R Springs with Alta 22mm Sway
Old Apr 16, 2008 | 01:24 PM
MiniJayhawk's Avatar
MiniJayhawk
Finally took some photos of my R56 dropped on H&R sprngs. Also added the Alta 22mm Rear Sway. Love it. I can confirm it helped quite a bit with torque steer to the point of virtually eliminating it. I have noticed improved turn in with the rear sway, but will really test it on the track soon.
These are going on Friday!!!
Old Apr 16, 2008 | 01:31 PM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
Nice!
Old Apr 16, 2008 | 01:41 PM
masterd78's Avatar
masterd78
MANIAC
Post pics when you get the new shoes on!!
Old Apr 16, 2008 | 01:54 PM
sirr6's Avatar
sirr6
Nice,did u have to re-align your car?
Old Apr 16, 2008 | 01:57 PM
PGT's Avatar
PGT
Old Apr 16, 2008 | 02:00 PM
MiniJayhawk
No. We measured toe after the swap and the front had a slight toe in which was fine. It does not pull either direction on the highway and shows no signs of misalignment. We adjusted the rear cam bolt to remove some of the added camber from the drop but it still added a fair amount. But to me, coming from an E36 M3 with Ground Control suspension, that is a good thing. I may take out the set screw inthe front struts and slide them in as far as possible in the tower slots to get as much camber out of the front as possible. If I do that I will probably also do a string alignment and set the front toe to zero.
Old Apr 16, 2008 | 02:01 PM
MiniJayhawk
Originally Posted by PGT
When did you go to the black wheels?
Old Apr 16, 2008 | 02:03 PM
PGT's Avatar
PGT
stanley
Old Apr 16, 2008 | 02:08 PM
MiniJayhawk
Check. Just ordered a set 20 seconds ago. Thanks! Anything else I am missing? Oh, hood scoop needs to go black. I'll get right on that.
Old Apr 16, 2008 | 02:44 PM
PGT's Avatar
PGT
stanley
Old Apr 16, 2008 | 02:50 PM
MiniJayhawk
I need to paint a bunch of sh*t in my engine bay, too.
Old Apr 16, 2008 | 03:53 PM
PGT's Avatar
PGT
stanley
Old Apr 16, 2008 | 11:04 PM
ugliboi_87's Avatar
ugliboi_87
holysh*****TTTT
you have a really nice car.
was it hard for you to do the beltline?
i was a pain in the butt for me to do it and it's peeling out right now :(
Old Apr 17, 2008 | 12:23 AM
amazingrando's Avatar
amazingrando
Auto on Sport Button guy
That's because you didn't use my kit
The Joey Mod is great, Looking forward to seeing those new wheels on
Old Apr 17, 2008 | 03:21 AM
ThumperMCS's Avatar
ThumperMCS
Can't wait to see those wheels on! They look great
Old Apr 17, 2008 | 06:39 AM
MiniJayhawk
holysh*****TTTT
I got the 3M tape from Outmotoring (I think) and it was a breeze. I have done all of the blackout myself and the key is heating the tape to make it pliable. I hardly used any heat on the beltline and did it only at the curves because the heat allows it to stretch and you don't want to reduce the width of the beltline tape by stretching it too much. I forgot that the tape had a clear film on top for a day or so. When I took the protective film off it looked 10x better.
Old Apr 17, 2008 | 08:46 AM
Bhatch's Avatar
Bhatch
Enkie NT-03?
I was considering these for my R56 in silver.
Old Apr 17, 2008 | 01:22 PM
TheBigNewt's Avatar
TheBigNewt
What's with the red KU decal? I thought blue was their color.
Old Apr 17, 2008 | 01:24 PM
MiniJayhawk
Crimson and Blue!!!!!!!!
Old Apr 17, 2008 | 08:33 PM
ghosthound's Avatar
ghosthound
January? That's my winter set. Here's my track set (take notes )
how wide are those? they look quite beefy.
Old Apr 19, 2008 | 09:29 PM
penguinpwrdbox's Avatar
penguinpwrdbox
I LOL'd
Old Apr 19, 2008 | 09:33 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
PGT, your car is looking good
Old Apr 19, 2008 | 09:35 PM
penguinpwrdbox
+1 - I dig the understated look.
Old Apr 19, 2008 | 09:36 PM
PGT's Avatar
PGT
wonder if the Motegi's will be any match for my new summer wheels?
Old Apr 19, 2008 | 09:38 PM
penguinpwrdbox
These?
