Suspension Strut tower brace vs. Strut tie bar
Old Feb 13, 2008 | 03:48 PM
drewster's Avatar
drewster
I'm still researching what I need for lowering the R56 and it's been recommended to me by someone in the know that it would be good insurance to add some kind of strut reinforcement in case of some hard pothole hits.
Craven offers a strut tower reinforcement
http://www.cravenspeed.com/index.php?productID=104
who else sells these?
Question 2, will a strut tie bar be as effective in protecting the strut towers or are they mostly designed for front end rigidity?
Thanks.
Old Feb 13, 2008 | 04:00 PM
NoModMini's Avatar
NoModMini
.....chassis flex......unless you race and have specific front end alignment specs dialed in and/or you want bling, it is another way to separate a man from his wallet.....
Old Feb 13, 2008 | 04:12 PM
drewster's Avatar
drewster
which is why i'm asking about the strut tower reinforcement which is designed to protect the strut towers from damaged from road hazards usually not encountered on the track. I don't think there was any mention of chassis flex that i was trying to lessen.
Old Feb 13, 2008 | 04:36 PM
PGT's Avatar
PGT
Craven's plates are excellent for my R53. I expect no less from the R56 versions
Old Feb 13, 2008 | 04:55 PM
ScottinBend's Avatar
ScottinBend
The M7 strut bar is the only one at the monent that will do both jobs.
If you are considering getting camber plates in the future, save your money now. Camber plates will do a more effective job of preventing tower mushrooming.
Old Feb 13, 2008 | 06:49 PM
n1tr0's Avatar
n1tr0
M7 hasn't released a bar that'll fit the R56 yet, but it's apparently in the works ...
Old Feb 14, 2008 | 08:26 AM
drewster's Avatar
drewster
there is also this one from DDMWorks
http://www.ddmworks.com/MiniStore/MI...bay_brace.html
What's a good guess as to the cost of this when it is available?
Old Feb 14, 2008 | 08:42 AM
scott48's Avatar
scott48
JCW front strut brace is good....I like it.
Old Feb 14, 2008 | 09:12 AM
drewster's Avatar
drewster
looking a pictures that looks like a conventional strut brace and doesn't have the reinforcements to prevent strut tower mushrooming which is still what i'm wanting to prevent for happening.
Old Feb 14, 2008 | 09:43 AM
scott48's Avatar
scott48
The way it attach to the upper strut towers, it does cover up like 50% of the upper tower, so it will definitely help from that standpoint, plus it's tying in both strut towers making everything more rigid....will definitely help and you get the added handling benefits.
Old Feb 14, 2008 | 08:43 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Has there been any reported issues of strut tower mushrooming on the new r56's? It seems like something that MINI would/should have addressed in the new design.
Old Feb 14, 2008 | 08:59 PM
rkw's Avatar
rkw
I've wondered the same thing. The R56 has been in production for well over a year and many tens of thousands sold. I have not seen even a single case of mushrooming reported in the forums.
Old Feb 15, 2008 | 08:27 AM
MiniJayhawk's Avatar
MiniJayhawk
I thought I read something that said the R56 was designed to fix this problem.
Old Feb 15, 2008 | 08:34 AM
PGT's Avatar
PGT
why else do you guys think the R56 has the SUV ride height for?
Rally@StanceDesign
The dealers and miniusa knew about the problem when the r56 was being designed....I don't know why they wouldn't strengthen up the area a bit.
Old Feb 15, 2008 | 09:09 AM
drewster's Avatar
drewster
well i guess for 'cheap' insurance i ordered the craven version of the reinforcement rings. i thought about the m7 version which also has an option to add a strut bar for not too much more $$ than the craven ( should be available in a couple weeks) but decided on the craven, sometimes simple is better....
Old Mar 2, 2008 | 03:14 PM
drewster's Avatar
drewster
here they are, they look pretty anyway
Old Mar 2, 2008 | 03:41 PM
PGT's Avatar
PGT
nice. I like the Craven too....mainly because of the small detail that they bevel the edge. My square edge of M7 strut bar plates cut through the sheath on my hood release....two M7 bars, two diff cars, same result.
Old Mar 2, 2008 | 05:18 PM
white rocket's Avatar
white rocket
I'm definitely waiting for M7 to release the R56 version of the bar/plate combo. I think the plates are available now and the bar will be available mid-March.
Old Mar 23, 2008 | 05:32 AM
etmaguire's Avatar
etmaguire
Drewster,
I have Craven's on the way & they should be here this week. Did you have any problems installing yours and is a torque wrench needed for assembly?
Good luck with yours. They look great!
Ed
Old Mar 23, 2008 | 05:44 PM
ANT818's Avatar
ANT818
Thumbs up for the Craven.
Old Mar 24, 2008 | 05:16 AM
Arnbut's Avatar
Arnbut
This is the way to go for a lowered car that also has/wants a CAI.
Any day now...
Old Mar 24, 2008 | 02:03 PM
drewster's Avatar
drewster
Originally Posted by etmaguire
Drewster,
Ed
Very easy install except don't drop one of the nuts down into the engine compartment, you'll never be able to find it and then you'll only have one strut defender for a week until Craven sends you a replacement nut.
I don't recall the exact torque but I think it is 25 ft.lbs. I would get a torque wrench to be on the safe and it will also be handy if you ever want to check the torque on your wheel lugs.
Old Mar 24, 2008 | 06:50 PM
rkw's Avatar
rkw
No, don't make the same mistake I did. You need different torque wrenches for the two applications because the values are too different. The wheel lugs torque at 88 ft-lbs (or 104 ft-lbs for 14mm lugs). The strut towers at 25 ft-lbs is too far down for the same torque wrench to be accurate. I used my wheel torque wrench, set to 25 ft-lbs but it was shearing off the tower bolt before it started clicking (expensive mistake). For 25 ft-lbs, I would get a torque wrench that has a top reading of no more than about 50 ft-lbs.
Old Apr 11, 2008 | 08:03 PM
drewster's Avatar
drewster
where do you find a torque wrench with the lower readings? I tried searching sears and home depot and the lowest i found was 0 - 75.
