Suspension Megan Coilover Owner Update
Old Jun 23, 2008 | 06:17 AM
  #176
meb's Avatar
meb
...one other thought here...one of the conclusions I came to a long time ago - perhaps incorrectly - is that a linear rate spring is very easy to work with.
Lets use a 400# spring as an example. It takes 400# of force to compress this spring one inch, an additional 400#s to compress another inch or a total of 800#s. However, it doesn't matter to the spring how much preload we've applied to it since we are concerned with movement from rest...the first inch of travel requires 400#s of force no matter how much preload we have... which is why I purchsed springs long or short enough to perform the job.
I am not an engineer, so I could have been wrong all these years.
EDIT - ah, but I did forget to mentioned that a preloaded spring has more stored/potential energy - for rebound.
Per above, the available travel is based upon both the spring and the damper. This is not really confusing...since a heavier rate spring of the same length has less travel and vise versa. But also, a heavier rate spring may not be heavy enough in a given application to reach block hieght at steady state and vise versa.
I think we're on the same page.
Old Jun 24, 2008 | 02:51 AM
  #177
brownflyer's Avatar
brownflyer
Just to make sure I'm following, looking at just the spring, you're saying that it will take 400# to compress the first 1" of the spring and the same amount of force (400#) to compress and additional 1" regardless of how much the spring has already been compressed. And that this is due to the linear characteristics of the spring.
This assumes that this relationship exists throughout the useful range of the spring. I believe we have mis-understood the term "linear" and have been mis-using it. I think the term refers to a "linearity" (is that even a word?) accross the useful range of the spring such that for a given compression X it requires 1.5Y load (as an example). This means that the more the spring gets compressed, the more load that's required to compress that amount. Not necessarily the same load to distance relationship as pointed at the begining.
Here is a graph that depicts this relationship much better. Notice the line for the Helical spring. Here is the link to the short article as well.
http://www.accusealmfg.com/sealdesign/loadvsdef.asp
Here is an interesting definition of a Linear spring
Now taking the whole system, here are my real world findings with the Megans and would be the case with any other C/O. For clarification purposes, when preloading a spring the damper shaft is not being extended any, the spring is simply being compressed between the upper and lower perches (since the length of the shaft is fixed) thus additional load is being applied:
By preloading the spring, the car would not settle as low as w/o preload. This was measured by 1) ride heigth 2) damper travel. And this is directly in line with the above graph in that - as the spring was compressed, the more load was require for the additional deflection/compression. In essence, the rate of the spring is changing as it's being compressed. But it is still a linear relationship.
Here is a quick read illustrating this point.
I agree that a preloaded spring will have more stored energy. So, this begs the question, How much preload can you put on a given spring so that the damper is able to effectively control the rebound? Another question, does the damper dictate the spring or is it the other way round? I would think is the spring that dictates the damper since the spring manages the weight. Digressing, sorry getting tired time for bed!
IMO the goal of the system is to maintain the damper shaft as close to the middle as possible and this can best be achieved by pre-loading.
I'm confused by this:
"since a heavier rate spring of the same length has less travel and vise versa."
Is this because for a given weight the heavier spring will compress less?
enough for now.....
Old Jun 24, 2008 | 05:35 AM
  #178
meb's Avatar
meb
no no! to the first sentence...400lbs for the first inch, an additional 400lbs for the second inch or 800lbs - 1,200 lbs for the third inch. Perhaps I did not write this very well.
i'll read on a little later - great stuff here!
Old Jun 24, 2008 | 10:20 AM
  #179
brownflyer's Avatar
brownflyer
Ok, yes I agree with you! Such that: Force = 400(change in deflection) or "Hooks Law". I think that's correct.
Old Jun 24, 2008 | 10:59 AM
  #180
SNEEEZY - Erika's Avatar
SNEEEZY - Erika
Rattle Can Queen!!!
Ow...my brain hurts!
Old Jun 24, 2008 | 06:27 PM
  #181
projekt7's Avatar
projekt7
It's because a higher rate spring has thicker coils, so spring travel reduces.
Old Jun 25, 2008 | 05:10 AM
  #182
meb's Avatar
meb
Exactly. Obviously a heavier spring will resist weight transfer a little more so in theory it shouldn't matter that there is less travel. But transient wieght shift and steady state ask different things from a spring.
EDIT IN BOLD
Old Jun 25, 2008 | 05:12 AM
  #183
meb's Avatar
meb
Hooks Law, yes...I this law also discuses the dual nature of a spring - potential and kinetic...but I cannot remember.
Old Jun 29, 2008 | 07:12 PM
  #184
MidniteCoop's Avatar
MidniteCoop
I just switched from stock to Megan's, Also ran some Helix Rear Control Arms Upper/Lower.
I'm not sure the over all drop, but I find it to have a nice ride.
I'll know better once the Alignment is dialed in this week.
The megan's are used so there broken in and the car settled quite well.
Old Jun 29, 2008 | 07:41 PM
  #185
AutoXCooper.com's Avatar
AutoXCooper.com
That's one great looking R53 and based on the sig looks like it will run with the big dogs too! Love the BBS wheels.
Old Jun 30, 2008 | 06:05 AM
  #186
meb's Avatar
meb
Is that an optical illusion or is your rear wheel toed out?
Great looking ride! Good luck!
Old Jun 30, 2008 | 07:25 AM
  #187
minimusprime's Avatar
minimusprime
i put a set of megans on yesterday. They were hand me downs from thatvguy. That means i'm running 6" barrel shaped 440lb front springs from ground control and stock megan rear springs. I've got it set so there is 1 finger width between the arch and the tire in front and 1.5 finger width's in back.
I'm not slammed by any means but it's functional. As far as ride comfort I went out looking for a few bumps that used to make me shudder with my hsport/oem damper setup. With the megans the car just glides over them and absorbs it. That's not hard to believe because before I tore the car down I put my hand in the hsport spring to check and found i had about 3/4" of travel between the start of the damper shaft and the totally destroyed hsport bump stop.
Overall I'm quite pleased with the setup, it's a touch bouncy but compared to a crappy progressive rate spring mated with a damper it wasn't designed for... it's a big improvement. I mean... 1.75" of travel isn't much at all.. but it sure is better then 3/4.
Old Jun 30, 2008 | 09:07 AM
  #188
MidniteCoop
Thanks man, I really appreciate the kind words
I must say that the switch to the megan's has made for a nice ride.
It's actually softer than I thought it would be.
I really like the ride height it allowed me to pull off with the new wider wheels. I may in a bit think of upgrading to some Eibach springs to make it a bit more firm and I will soon need to update the front endlinks, since they have more stress due to the added camber.
It very well might be toed out a bit, I'm taking it in tomorrow for an alignment, it's riding great although a bit shifty on the road. Will let you know how it goes once all is dialed in.
Old Jun 30, 2008 | 01:43 PM
  #189
checkmate2006's Avatar
checkmate2006
Where did you get your megans?
Old Jul 2, 2008 | 06:42 PM
  #190
03Indigo's Avatar
03Indigo
User Title's are Silly
Nice, I am running the 7kg Eibach's 150mm up front, 6kg Megan in the back. Dampers are set in the middle all the way around and I love the way the car feels. I have no gap in the front, and a slight overlap in the back, (lower in the back to remove the raked look I used to be fond of). The car does really well, and much more comfortable than the h-sport set up I used to have, and now I think I like them more than the KW Vogtland set up I used to have.
Congrats on the new set up, and getting it where you want it
Old Jul 2, 2008 | 07:24 PM
  #191
Rally@StanceDesign's Avatar
Rally@StanceDesign
Me
Old Jul 2, 2008 | 09:36 PM
  #192
checkmate2006
Me
I was wonder how the hell he is so LOW but that explains alot hahaha. I may move up to CROSS sometime in the future.
Old Jul 8, 2008 | 11:56 AM
  #193
thatatvguy's Avatar
thatatvguy
I was wondering who ended up with them. I'm glad the you like the spring rates also.
Old Jul 9, 2008 | 06:28 AM
  #194
MidniteCoop
Yup, Rally hooked me up with his set.
One of the big reasons I wanted them was since they were already settled.
Made it easier to do the one time install instead of having to return then and have the car lowered after it settled. I really like the ride so far, I find the car to be better balanced with them than the stock setup. Down the road I may upgrade to some eibach springs. All in all having made the change I couldn't be more pleased with them..
Old Jul 13, 2008 | 03:03 PM
  #195
minimyke's Avatar
minimyke
03Indigo
WHered you buy your eibach springs
and whatd you pay for them?
MyKE
Old Jul 13, 2008 | 03:57 PM
  #196
03Indigo's Avatar
03Indigo
I got them from another member, and I think I paid $60 for them. Do a search for Eibach's site, then they will show who their retail vendors are, you can contact those shops. You can expect to pay between $80-100 for a pair of front springs.
You can also CALL the guys at Texas Speed Works, a vendor here on NAM. If you call them, they will help you out and get you some springs, may be Swift springs, or something like that, but those are amazing springs. I was going to call them, but the Eibachs came up for sale, so that was that. But TXwerks was my first choice.
Old Jul 13, 2008 | 04:00 PM
  #197
minimyke's Avatar
minimyke
Is there a p/n for the springs, I was on the eibach site and it was pretty overwhelming considerig the fact that Im not quite sure of the inner diameter of the springs
Old Jul 13, 2008 | 04:06 PM
  #198
MSFITOY's Avatar
MSFITOY
I LOVE my Megans!!! Rides better than a lot of street cars...firm but controlled...rarely bottoms out even at my drop...will most definitely buy another set when these wear out!!!
Old Jul 15, 2008 | 07:36 AM
  #199
thatatvguy's Avatar
thatatvguy
Eibach info listed on their site. Based on you having a "standard" 2.5" ID coilover. I'm sure that this is not all that they have. I can provide other rate calcs, if you need.
Part number is as follows: Lenth (0600) ID (2.5" or 64mm) Rate (0450 = 450 lbs/in)
Rate in table is in newton/meters. Everything else is metric. (ie. mm)
Old Nov 21, 2010 | 02:36 PM
  #200
Professor's Avatar
Professor
Gonna bring this thread back from the dead to bring up some questions. Now keep in mind I dont own a track car but love curvy roads and spirited driving, it is not a DD and I am use to some stiffness in suspensions.
I am currently running the Megan V3 with the 160.008 fronts and 180.006 rears. I had a set of 7k springs in the front but they were to short at 5.5" and liked to bottom out. Today I put my original 160.008 spring on the the front with the perch all the way down, needless to say there is no preload on the springs in the front or rear. Is this a bad thing or will I not have issues? I made an attempt to preload and the damn front set about stock height! I have the threaded strut body's all the way down into the brakets as well.
