Suspension Megan Coilover Owner Update
Old Mar 1, 2008 | 02:09 PM
  #26
roofaS's Avatar
roofaS
^^If that is the case, I would love a step-by-step guide to installing coilovers
Old Mar 1, 2008 | 03:43 PM
  #27
AutoXCooper.com's Avatar
AutoXCooper.com
Originally Posted by S-Driver
Here's a dumb question.....
Coilovers already come with the springs in place, correct? So basically an install will be just a simple removal of the strut assembly/shock assembly and mounting of the coilovers...?
Kinda, some systems use parts from the stock towers so it's not just replacing parts. Here are two links to review. Many owners have done them at home without issue. I'm working with Megan to get a step by step for that system. Not all system have or need the rear damper adjustments.
Here's two links to review for install info.
http://www.txwerks.com/images/Instal...ST_Install.pdf
https://www.northamericanmotoring.co...24&postcount=1
Hope that helps, AXC
Old Mar 1, 2008 | 04:10 PM
  #28
S-Driver's Avatar
S-Driver
Yes, I've read the BC install thread....good info there. I'll read the txwerks one soon.
Another question: I see that the Megan set has top hats for the rear shocks, but the BC unit comes with a new one. Any reason why since they are basically the same units. $1000 for the BC ones, $900 for Megan....
I'm just trying to decide which set to go for and obviously $900 beats $1000.
Thanks...
Old Mar 1, 2008 | 04:12 PM
  #29
03Indigo's Avatar
03Indigo
User Title's are Silly
Old Mar 2, 2008 | 08:41 AM
  #30
Chase's Avatar
Chase
What stiffness is everyone running with the megan coilovers? Front and rear clicks?
Old Mar 2, 2008 | 09:10 AM
  #31
cliff@coasttocoastusa's Avatar
Former Sponsor
The difference between the BC and megans is not just the fact that the bc's come with rear top hats. The compression/rebound adjustments are different. There is about 3mm more suspension travel with the BC and they are an all around beefier coilover in comparison.
I am simply stating that the bc and megans are not the same and this should be noted when shopping for a coilover setup.
Old Mar 2, 2008 | 11:49 AM
  #32
astromini's Avatar
astromini
do you have any adjustable camber plates???
I dunno...never had it measured. Probably around -1.8 degrees when i was at my lowest ride height. I ran -2.5 up front.
This was my ride height...no idea how much lower it is than stock. I still have a few threads left. It's probably a little more than 2.5 inches lowered over all.
Old Mar 2, 2008 | 12:46 PM
  #33
Rally@StanceDesign's Avatar
Rally@StanceDesign
Yup....I've got megans which come with the adjustable camber plates.
Old Mar 2, 2008 | 01:13 PM
  #34
RedSkunk's Avatar
RedSkunk
Could you go into a little more detail about how the adjustments are different and how they're "beefier"? (They certainly look similar.) Is the compression/rebound ratio the same? Rebuild for the BC is $95 per, right?
Another person trying to decide between the two. TIA.
Old Mar 3, 2008 | 08:18 AM
  #35
Former Sponsor
The megans run a 44mm piston and 50mm overall shock housing. The BC Br series utilize a 46mm piston and overall 53mm shock housing. There are 2 less adjustments for damping 32 megans vs 30 on the BC's but the overall adjustment range is greater.
They are currently offering replacement dampers for $95 instead of rebuilding.
Here is a link to a youtube video with 2007 speed world challenge champion Randy Pobst lapping a mini at Daytona with the bc setup:
Randy Pobst on BC coilovers
Any other questions feel free to ask away.
Thanks,
-Cliff
Old Mar 3, 2008 | 08:24 AM
  #36
Rally@StanceDesign
Does BC offer r56 coilovers yet?
Old Mar 3, 2008 | 08:33 AM
  #37
Former Sponsor
Not quite. They are currently in development though.
Old Mar 3, 2008 | 03:52 PM
  #38
Chase's Avatar
Chase
For the people that are running megans on the track and street. How do you have yours set up?
Old Mar 4, 2008 | 09:42 AM
  #39
flyboy2160's Avatar
flyboy2160
Could you go into a little more detail about how .....they're "beefier"?..
the bc front dampers are all steel. the megans use aluminum damper holders/sway bar attachment fittings..
Old Mar 12, 2008 | 04:37 PM
  #40
ouzo's Avatar
ouzo
Originally Posted by 483FITTER
Has anyone used the Megans for autocross? Im seriously considering a set of these but want some non street experiences with them.
BUMB
..and also.. how much would a coilover install generally cost?
Old Mar 12, 2008 | 06:46 PM
  #41
RedSkunk's Avatar
RedSkunk
Coreyblimey has the BCs, similar coilover (despite differences ), autocrosses them regularly. I'm sure others do as well.
I am in the process of installing my BCs, and will be autocrossing on them as soon as the season starts back up. I'm very hopeful.
Old Mar 13, 2008 | 11:21 AM
  #42
projekt7's Avatar
projekt7
HELP!
I recently purchased a set of Megan's from Dustin at AutoXCooper (great seller by the way). I brought them to a local shop that I've been working with for a long time to get them installed. However, we hit some problems.
Just by looking at the camber plates and my strut tower, the guy said camber adjustment will pretty much impossible without trimming the strut towers. I suggested things such as using ball-end allen keys and moving 2 of the bolts to the middle holes, but he insisted that he wont be able to get enough torque on the bolts with a ball-end allen and low clamping force when the 4 bolts are really close together.
So the question I have is...how many of you have trimmed your strut towers? I've asked aroudn before, and Rally said he didnt trim his, but Meb said he DID have to trim a little.
Thanks!
Old Mar 13, 2008 | 02:56 PM
  #43
RedSkunk's Avatar
RedSkunk
Check the BC thread for some more cut / not cut:
https://www.northamericanmotoring.co...ad.php?t=93463
I have yet to install my fronts, but I bought some replacement bolts, hoping that I will be able to get a wrench underneath and adjust camber, w/o any trimming. Here's hoping at least.
Old Mar 13, 2008 | 06:07 PM
  #44
S-Driver's Avatar
S-Driver
Thanks!
Ya mean like this.....Yes I had to trim some if I wanted to get any camber adjustability. I can get 2.5 drgrees as it is now, which should be just fine...it ain't pretty but it will work.
Old Mar 14, 2008 | 11:05 AM
  #45
projekt7's Avatar
projekt7
Wow, that's a bit of trimming you did there. I really hope I don't need to trim as much.
What I still don't understand is...you and mct both have the BC racing coilovers. However, in the BC thread he showed that he was able to get 2.2 camber without any cutting, while you had to trim the towers to get any adjustibilty. Are built differences really that great between cars?
Old Mar 14, 2008 | 08:58 PM
  #46
S-Driver's Avatar
S-Driver
I actually should have said that if I wanted to get the allen wrench on it I had to cut the towers. There was just no way a wrench could be put onto those allen acrews. Even a ball end wrench would not have worked, and if it had I would have worried about not being able to get enough torque on the screws on such a steep angle.
Old Mar 15, 2008 | 11:21 AM
  #47
CynMini's Avatar
CynMini
Originally Posted by 03Indigo
Dude, just drive out to Colorado and I will install them for you and get you all set up . That is simple enough, haha.
How much do you charge for an install, cables in the rear and the whole deal for an '05 Cooper S? Does it include alignment? What else should I know? And, how many installs have you done?
Old Mar 15, 2008 | 01:22 PM
  #48
S-Driver's Avatar
S-Driver
Take it from someone who's never done this before......try doing it yourself. It wasn't that hard and all's you need is a set of tools. Yeah the shock tower doesn't look pretty, but that was a necessary evil....
Old Mar 15, 2008 | 03:24 PM
  #49
the platform's Avatar
the platform
Hey S Driver,
Nice suspension bits. Besides adjustability control,did you notice significant stability and increased "groundedness" from the upper and lower control arms?
I noticed your running you're running exclaims.Are you liking them?
thanks
Old Mar 15, 2008 | 03:50 PM
  #50
03Indigo's Avatar
03Indigo
