Suspension 18" rims with 225 tires
Old Dec 6, 2007 | 11:24 AM
succubus's Avatar
succubus
Hey guys. I posted a similar thread over in wheels/tires but I don't think it got the right kind of attention.
I probably didn't ask the right questions either.
Anyway, I am thinking of putting a set of 225/35 tires on some 18x8 rims I got for free.
The car is lowered on TSW springs. Does anyone have practical experience with this tire size and suspension setup?
I have the adjustable lower rear arms on order and was thinking I may be able to get everything to tuck if I get the adjustable upper arms as well and pull the whole assembly in a bit.
Just wondered if anyone had practical first-hand experience with this setup.
Old Dec 6, 2007 | 01:56 PM
Wake|MCS's Avatar
Wake|MCS
What is the offset on the wheels? The TSW springs offer a very mild drop, even more-so than the H-Sports. I had 215/35/18 on 18x7.5 SSR Comps (ET42) with H-Sports and only got rubbing on big dips in the road with a full car. By the way, same goes on my S-Lites with 215/40/17, no biggie.
Offset aside, because the drop is very mild, it'll work. So go for it.
Old Dec 6, 2007 | 02:41 PM
MarioKart's Avatar
MarioKart
Vendor
Should be fine as long as the offset is 40 to 45.
Old Dec 6, 2007 | 04:53 PM
succubus's Avatar
succubus
Offset is 40
Old Dec 8, 2007 | 08:22 PM
jefeant's Avatar
jefeant
225x45 work fine with 17 S lites.
Old Dec 8, 2007 | 10:58 PM
Longboard Mini's Avatar
Longboard Mini
I'm on 215 x 40 x 18 with Koni FSD's and and H-sports.
I'm thinking of switching to 225 x 35 x 18's and think they will work and fit great.
Longboard
Old Dec 9, 2007 | 08:39 AM
ca$per's Avatar
ca$per
the 225/35/18 fits an 8" wheel perfectly and much better than 215s
there are pictures of my car and wheels on the 8" wide or more wheel thread by Wake|MCS
Old Jan 25, 2008 | 07:12 AM
Elemental's Avatar
Elemental
what about 225/40/18? I have a friend thats selling this setup for dirt cheap. The rims are 42 offset.
Old Nov 18, 2010 | 07:58 PM
vc1492a's Avatar
vc1492a
I'd like to know as well... I recently bought rims/tires off a guy that are this size. I'm stock ride height.
PS: I know my speedo will read slow.
Old Nov 23, 2010 | 09:15 AM
kris kross's Avatar
kris kross
As of now I'm running 225/40/18 on my stock suspension. It does rub the fenderwells over bumps or with a load in the back. I want to lower with TSW springs and switch back to 225/35/18 tires.
I'd like to stop the rubbing. I've tried cutting the fender but it still rubs. Would lower control arms fix this? My wheels have a 42 offset. Thanks.
Old Nov 23, 2010 | 09:43 AM
AXO's Avatar
AXO
Pics please....
Old Nov 23, 2010 | 10:17 AM
vc1492a's Avatar
vc1492a
Some pics would be great.
My mechanic said I would be fine and wouldn't rub very often, but I'd still love to see a picture of your setup.
Also, how many miles do you have on the stock suspension?
Old Nov 23, 2010 | 10:27 AM
kris kross's Avatar
kris kross
My car is currently on jack stands since I am waiting on my axle to get shipped back to me. But I will post pics as soon as I can.
It does rub pretty bad since the tires do have good tread on them. It seems like its rubbing on the metal fender behind the plastic trim because its cutting the edge of the tires. I have 77k miles on my suspension.
Old Nov 23, 2010 | 10:31 AM
vc1492a's Avatar
vc1492a
Is it rubbing in the rear, front, or both? I'd like to know what areas will be a problem.
Old Nov 24, 2010 | 10:55 PM
kris kross's Avatar
kris kross
Both, but the rear is more noticeable. The fronts are just rubbing on the wheel arcs, as the rears are rubbing on the wheel arcs and the fender well. Since I can't get a picture of the car on the ground, a good reference is there are two finger-widths from the tire to all four wheel arcs.
This picture you can see where it's cutting into the tire. This tire has been on the rear, as I have recently rotated them.
Old Nov 25, 2010 | 12:10 PM
vc1492a's Avatar
vc1492a
Sorry but the pic won't load. Can you try again?
Old Nov 25, 2010 | 12:25 PM
kris kross's Avatar
kris kross
Sorry let me try again...
Old Nov 30, 2010 | 02:20 AM
howsoonisnow1985's Avatar
howsoonisnow1985
Both, but the rear is more noticeable. The fronts are just rubbing on the wheel arcs, as the rears are rubbing on the wheel arcs and the fender well. Since I can't get a picture of the car on the ground, a good reference is there are two finger-widths from the tire to all four wheel arcs. This picture you can see where it's cutting into the tire. This tire has been on the rear, as I have recently rotated them.
Please let us get some pics of what modifications to wheel wells you did. Also, of car once you get the wheels back. Thanks a million.
Old Dec 5, 2010 | 09:38 PM
kris kross's Avatar
kris kross
Here you can see where I cut the plastic wheel well trim and rolled the metal fender, although it still rubs on the fender. Hopefully some control arms can stop the rubbing for good!
Attached Thumbnails 18" rims with 225 tires-imag0122.jpg   18" rims with 225 tires-imag0123.jpg
Old Dec 11, 2010 | 09:29 AM
vc1492a's Avatar
vc1492a
Hey guys.
Got my rims on. They're ADR M Sports (43 offset), 18x7.5 inch rims.
I put 225/40/18 tires on them as well. Hankook Ventus Evo's, if that matters.
No rubbing issues as of yet, and the clearance seems pretty good. I'm running the stock MCS sport suspension.
I can see how it would rub at full compression, this is obvious. But I rarely have any cargo other than a few groceries and such + myself, so I don't see how rubbing is going to be anything close to a major issue.
In any case, I got some pics for you guys to see.
There's plenty of pics for you guys to digest. If you have any questions or any close up pic requests, just let me know.
Old Dec 12, 2010 | 01:01 PM
torrejuan's Avatar
torrejuan
I'm running 205x40x18 on my wheels with no rubbing. Bought used two months ago, so if it has been lowered, I'm not sure. But to my untrained eye, I'd say no.
Old May 5, 2011 | 08:54 PM
ATXZJ's Avatar
ATXZJ
Enkei 18x7.5, 42+ wheels with 225/40/18. NO issues and loving the looks of it
Old May 6, 2011 | 04:32 AM
N2MINI's Avatar
N2MINI
There's actually plenty of room to trim the metal part of the fender/wheel well and get the plastic trim back on, which of course covers all that up..
Rolling it is good but if need be there is probably an inch +- that could be trim completely off and then roll that..
A few of the cars above don't appear to be lowered any so of course they are not having an rubbing issues as they shouldn't be..
My car is on Megan Coliovers and sits pretty low. I used to run 215-35-18's and on 1 set of tires I did get alittle rubbing in the rear with passengers, currently running 215-45-17's with no rubbing yet..
As you'll notice some tires are taller/wider then others in the same size so while 1 tire may not rub another may...
freckles81
Sep 8, 2015 09:48 AM
Ntety
Sep 2, 2015 08:39 PM
