Suspension Gallery! Show me your lowered MINI!
Old Feb 7, 2010 | 11:13 PM
  #801
KevinC's Avatar
KevinC
Originally Posted by J_'09s
I was so torn between the Yellows and the FSD's. They are both very reputable products but i didn't want to risk blowing out the FSD's with lowering springs. So i went with the Yellows. Was this a sound decision?
Now i'm waiting on the shocks and struts to get here but i'm now left with yet another quandary... what lowering springs to get? I've heard great things about the NM RSa's??? Any suggestions?
I looked into FSDs but backed off for the same reason - not for use with a lowering spring, except for a couple of applications Koni makes specifically designed for them.. and our cars are not one of those applications. I wound up going with the H&R Touring Cup Kit. The springs are H&R "OE Sport" springs, which claim 1.4" lowering on our cars. The shocks are Koni Yellows, painted metallic grey to match the springs, with an H&R sticker on them but the Koni stampings still in place. Even the adjustment **** for the fronts is the standard Koni **** complete with their nomenclature.
I have mixed feelings about the setup. It greatly improved ride quality, but the springs seem a tad soft. I started with the shocks at full soft (which is what you're supposed to do with Koni Yellows, adjustments are meant to take place as they wear), but have since cranked the fronts up a half turn. The rears would have be removed and disassembled to adjust, so they aren't going to be monkeyed with anytime soon. For a street setup, this is fine, and is infinitely better than the horrific stock setup. But it leaves me wanting a bit more control. But for $600 (on sale) for the entire kit, it's a screaming bargain. Priced separately, the cost would have been much higher.
Old Feb 8, 2010 | 04:53 AM
  #802
jimmyd1's Avatar
jimmyd1
nope I have my springs sway bar, strut tower bar and waining for my new rims to show up but I dont have heat in my garage and it has been way too cold here in NY to do it yet. I will post mine as soon as I possibly can though
Old Feb 10, 2010 | 09:32 AM
  #803
Gilboyto's Avatar
Gilboyto
My Konigs are still for sale with/without tires..but I figured I would throw up an update with my new wheels
Old Feb 10, 2010 | 09:54 AM
  #804
VicSkimmr's Avatar
VicSkimmr
O.M.F.G.
Are you rubbing in the rear with that setup? And by rubbing I mean on the metal under the arches.
Old Feb 10, 2010 | 09:55 AM
  #805
Blainestang's Avatar
Blainestang
One of the nicest MINIs, period. The new wheels/stance look great.
So, did you get your second seat, yet? :D
Old Feb 10, 2010 | 10:10 AM
  #806
Gilboyto's Avatar
Gilboyto
Vic. I rub in the rear currently but I am only running like -1.2 degrees of camber (or whatever stock is). I just went out to check my tire pressure and there was inner plastic fender rubbed off like CRAZY. Luckily its on the inside hehe. I dont think Im hitting the metal, but how can I tell??
And Blaine, thank you for the comment! Its much appreciated . I havent gotten my second seat tho LOL I hope my tax return will fund it though...
Old Feb 10, 2010 | 06:24 PM
  #807
VicSkimmr's Avatar
VicSkimmr
Oh you would know It's very loud.
Old Feb 10, 2010 | 06:27 PM
  #808
glnr13's Avatar
glnr13
also your tire tread will have a new tread line.
the metal will actually cut a new line into the tire. very bad, scary
you'll have to do some minor rolling of the metal.
  #809
tmo8462's Avatar
tmo8462
Gil deff one sexy mini.... mad props on it bro. Cant wait to get the wheels/tires in the mail and the coil overs on!!!!!!!!
Old Feb 10, 2010 | 07:41 PM
  #810
Blainestang
You're welcome... it's much deserved, too. Good luck with the second seat.
BTW, I kinda remember you saying you weren't going to be at MOTD (here or on MU). If you are, though, I'd like to try sitting in that seat to see if I could use one comfortably, if that's OK. Not sure if I could at 6'1" 23X lb.
Just don't take turns faster than 5mph or hit any bumps, and you should be A-OK!
Old Feb 11, 2010 | 08:35 AM
  #811
Gilboyto's Avatar
Gilboyto
^^ If I was going, I woul have no problem you trying out the seat. My friend here Jason actually sat in the seat and loved it, an hes maybe 5'10" and 240lbs.
I actually took a feel last night in the rear wheel well, and I am hitting the metal LOL. The felt wheel liner has a strip thats ripped off....AWESOME
I need to get some camber kicked into it today at an alignment shop,
Does anyone know the best way to roll the metal out some? I dont have a fender roller anymore :(
Old Feb 11, 2010 | 12:14 PM
  #812
jimmyd1's Avatar
jimmyd1
see thats what i am worried about is there any way around the tire rub?
Old Feb 11, 2010 | 02:34 PM
  #813
empire0007's Avatar
empire0007
still adding more. Almost finished with the GT28RS and tune next week.
Old Feb 11, 2010 | 02:53 PM
  #814
Rally@StanceDesign's Avatar
Rally@StanceDesign
run a conservative stance
Old Feb 11, 2010 | 04:50 PM
  #815
jimmyd1's Avatar
jimmyd1
I have the stage 1 mania sistension kit with the springs and 22 mm sway bar and 18x7 piaa mesh wheels that i intend to put on once it gets warm enough out. Will a conservative stance be automatic with what i bought?
Old Feb 11, 2010 | 05:49 PM
  #816
Rally@StanceDesign
Yes, you won't have any worries rubbing with 7" wide wheels and a spring ride height.
He's rubbing cause his wheels are 1.5" wider than yours and a low offset. He's also really low.
Old Feb 11, 2010 | 06:15 PM
  #817
jimmyd1's Avatar
jimmyd1
ok good . thanks for the info
Old Feb 11, 2010 | 07:25 PM
  #818
Blainestang
[quote=Gilboyto;2979863]^^ If I was going, I woul have no problem you trying out the seat. My friend here Jason actually sat in the seat and loved it, an hes maybe 5'10" and 240lbs.
Well... maybe next year.
Jason having tried it and liked it at a similar size is encouraging, though.
Good luck with that. I'm having and will have similar problems with my Foxbody Mustang. I'm running 1" wider control arms in the front and 17x9's w/ 275 width tires and a sitting quite a bit lower than stock due to the coilovers. The only reason mine doesn't rub is that the coilovers are stiff enough that there's not much movement in turns or over bumps :D.
Car looks really good, empire. Sounds like you've got the performance aspect taken care of, too.
Or take my simple suggestion of not taking turns or hitting any bumps. Easy.
BTW, Rally, can you drive at all with the Clubman's suspension at it's lowest setting?
Old Feb 12, 2010 | 05:24 AM
  #819
Gilboyto's Avatar
Gilboyto
Empire, your car looks GREAT! I always love the completely stealth look, but I could never achieve it properly like you did!
Rally, maybe you can shed some insight for me on how you arent rubbing in the wheel well at all with your stance, seeing as you tuck tire (although you are also running 16s....
Clean cut? I was hitting that metal BAD so I took a big EFFING hammer to bang out the lip a little bit...I think Im just going to cut it off today.
But What do you guys think about the "inner fender" if that makes sense. Above the lip that cut my fender liner, it bulges out a little bit...it that something that can roll towards the outside a little?
Old Feb 12, 2010 | 12:09 PM
  #820
Rally@StanceDesign
Yup. I wouldn't do it out on the street cause the oil pan is about an 1/8th inch off the ground, but I can still roll around without rubbing at that height.
Old Feb 12, 2010 | 01:11 PM
  #821
jimmyd1's Avatar
jimmyd1
thats crazy, I gotta drive my baby
Old Feb 12, 2010 | 01:12 PM
  #822
Rally@StanceDesign
I drive mine all the time. He was just asking if I drive it at the lowest setting. I don't, but it's possible without rubbing tires. I usually drive it at my preset ride height. Keep in mind that my ride height is infinitely adjustable from the driver's cabin.
This is the lowest setting. No rubbing though
Old Feb 12, 2010 | 01:14 PM
  #823
Oxybluecoop's Avatar
Oxybluecoop
Rally's a pan scraper at heart though
Old Feb 12, 2010 | 01:22 PM
  #824
tmo8462's Avatar
tmo8462
Low and slow right Rally? Cruise mod until you hit the curves.
Old Feb 12, 2010 | 01:24 PM
  #825
Rally@StanceDesign
haha indeed. I installed my skidplate in september and it's already torn up
Should be going lower in the spring once the snow melts and I can get to work on the subframe
yup
