Suspension Sway Bar Link Detached on Driver's Front - PHOTOS
Old Oct 5, 2007 | 12:34 PM
FlyPenFly's Avatar
FlyPenFly
So I had a fellow NAM restore a MCS I'm driving to stock from Hsport springs. Unfortunately due to unforeseen circumstances he had to rush at the end and it seems the front sway bar link is detached.
Pics: http://www.jae-designs.com/MiniStuff2/
I didn't have a 16mm wrench on me at the time so I was unable to loosen the bolt. However, it really doesn't seem like to me that the sway bar link can even fit as it is pretty much stuck there in position without much play and there isn't enough room to attach it... thoughts?
Old Oct 5, 2007 | 01:33 PM
Partsman's Avatar
Partsman
Legion_of_Doom
First of all, that link can't be reused.
I have never seen that happen before, very odd that it pulled apart like that.
Get a set for both sides, just to be safe.
Old Oct 5, 2007 | 05:26 PM
Ryephile's Avatar
Ryephile
That one's busted! I have a set of stock droplinks you can have for cheap; PM me. Did something happen that would've caused that to break?
Old Oct 5, 2007 | 05:28 PM
FlyPenFly's Avatar
FlyPenFly
Not that I know of, I just drove home like normal... are the drop links standard across all MCS's?
The only diff I can think of is that the struts from the donor car was an automatic.
Old Oct 5, 2007 | 05:35 PM
03Indigo's Avatar
03Indigo
User Title's are Silly
there is no difference in the end links between all the MINIS, R50 or R53...auto or manual. The only difference was in strut design of the early make 2002 models. They had a different mounting point on the strut for the end link which was changed and has remained the same since.
Old Oct 5, 2007 | 05:38 PM
FlyPenFly's Avatar
FlyPenFly
ok cool I ask because like I said in the OP, I'm not sure how I can see even a new being placed because of the position of the strut bar and strut.
Old Oct 5, 2007 | 05:45 PM
Ryephile's Avatar
Ryephile
Based on the picture and the loading of the swaybar, I'd guess you only jacked up one side of the car; is this correct? As such, when you go to put the replacement drop-links on, you'll have to jackstand both sides of the front to unload the swaybar.
Old Oct 5, 2007 | 06:09 PM
03Indigo's Avatar
03Indigo
^^^^ he is correct, the best way to put on new links is to have the car even side to side, and the easiest way to do that is jack up the entire front end...like Ryephile stated.
If that does not work for you, you can also put the car up on ramps, so you have room to crawl under there and install them that way.
I have never had any trouble installing them with the front end up. Make sure to put a 17mm box end wrench on the arm side when tightening, you don't want that part to spin when tightening the nut.
Old Oct 5, 2007 | 06:16 PM
txwerks's Avatar
txwerks
Ah, the greatness of the OEM endlinks...
Old Oct 6, 2007 | 12:00 AM
FlyPenFly's Avatar
FlyPenFly
That totally makes sense guys, thanks.
Old Oct 6, 2007 | 07:09 PM
sprp85's Avatar
sprp85
that hppaned to me when i was installing coils..
just hammer that thing back in and see if you can fix it..
Old Oct 6, 2007 | 07:12 PM
defylogik's Avatar
defylogik
that happened to me once. You can pop it back i to place with a pair of channel locks. Hasnt come loose ahain
Toolman
Jan 20, 2016 06:50 AM
minipopkart
Aug 13, 2015 05:22 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
