Suspension Choice: Strut Tower Brace or rear sway bar
Old Sep 10, 2007 | 02:21 PM
Sin MINI's Avatar
Sin MINI
It's my daily driver, I expect to do no more than one track day a year, probably less . So I don't need or want to go crazy here. Just looking to improve my ride. I do plan to lower it slightly (H-Sports?), but that's as much for looks as anything else.
That said, would I be better served with a strut tower brace (plan to get the SRPs anyway) or with a rear sway bar? If the latter, what size (19mm, 22mm, ??). Looking for best bang/buck here.
Thanks!
Old Sep 10, 2007 | 02:33 PM
rubyred3's Avatar
rubyred3
bang/buck, sway bar will have a far bigger affect
Old Sep 10, 2007 | 02:50 PM
ajakeski's Avatar
ajakeski
Big sway bar. If you are going to drive it every day and do limited track time, think twice about lowering. I left mine stock and replaced the run flats due to the crappy roads around here.
Old Sep 10, 2007 | 03:01 PM
Sin MINI's Avatar
Sin MINI
Where is "around here"?
Old Sep 10, 2007 | 03:09 PM
70spop's Avatar
70spop
United States
And +1 on the rear sway bar.
Old Sep 10, 2007 | 03:14 PM
agranger's Avatar
agranger
+1 again on the swaybar. The Strut tower brace is a 'nice to have eventually' type of mod... not a 'need right now' type of thing on our cars.
You will feel the impact of a beefier rear swaybar and will love the handling change.
Old Sep 10, 2007 | 03:15 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Thanks!
19mm adjustable (3 hole) rear sway bar (used is good- check around) and do the install yourself. Each of the three holes would be usable for street driving and occassional track use. Try softest setting for daily driving and middle for track use. It's all stiffer than stock.
22mm bar or H sport competition 25mm thin walled bars are also good but since they are even stiffer then you really are just using the softest setting all the time with little adjustment if you are using it for street use. You do save a little weight with the 25mm H sport bar. Install is the same.
Rear bar only helps you when cornering, not during straight line acceleration or braking and not during normal street driving unless you drive like you're at the track.
Old Sep 10, 2007 | 03:26 PM
Sin MINI's Avatar
Sin MINI
Copy all. Since my track driving will be minimal at best, I may wait...I have several aesthetic mods I would like to do.
if I do go with a sway bar, is the brand important? Areas like quality of the bushings, lubrication requirements (I'm a minimum maintenance kind of guy), etc...
Old Sep 10, 2007 | 05:36 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
I love my rear sway bar. It is H-Sport's 19mm and I have it to its stiffest setting. I drive a bit aggressive on the streets its just more fun, + our cars already get good mileage so why not use some of it up for fun. Alright, so back to the bars. I also have a 27mm H-Sport front bar and it is set it its stiffest as well and last a rear strut tower bar. This RST does very little for handling, but this was on my car first and I could notice some change, but nothing like what the front and rear sway bars accomplished. I think that in the future I will switch to a 22mm or even the 25mm, as I really like the tail of my car stiff. For you, I would start with the 19mm and go from there.
Old Sep 10, 2007 | 06:32 PM
Crashton's Avatar
Crashton
19mm H-Sport rear bar set at it's stiffest setting. I'm happy with mine.
Old Sep 10, 2007 | 06:36 PM
SayGoodbye's Avatar
SayGoodbye
Old Sep 10, 2007 | 06:41 PM
MINI Monkey's Avatar
MINI Monkey
+11 for a Sway bar
Old Sep 10, 2007 | 06:48 PM
cpayne's Avatar
cpayne
Webb Motor Sports Extreme Rear Sway Bar= Godly!
Old Sep 10, 2007 | 06:52 PM
Mr Skurvy's Avatar
Mr Skurvy
+75 Sway, No Question
Old Sep 10, 2007 | 06:59 PM
succubus's Avatar
succubus
The FSB will certainly make the front of the car feel more stable, and it will help you put more power down when the wheel is turned. I put my FSB on first, and took a test drive. Noticed a big difference, but the car still pushed into horrid understeer when pressed.
The RSB will allow you to tune the handling dynamics of the car and acheive a more neutral balance. I have the Hsport 19mm on stiffest setting, and love it.
I wouldn't soften it up for street driving at all, and in fact would even consider the 22mm bar as well. Keep in mind I have 18" wheels/tires and put down more rubber than those with smaller wheels/tires. I do not find that the 19mm on stiff adds oversteer to the point of danger or scariness, not in the least bit. I find the car to be perfectly balanced but would probably want stiffer still for autox days.
Possibly, however, an upgraded set of springs and shocks may change all of that. I'm on stock suspension other than the FSB, RSB, and USS.
Old Sep 10, 2007 | 07:06 PM
kenchan's Avatar
kenchan
stb on our mcs's on the front are useless, imho. especially on street.
Old Sep 10, 2007 | 07:26 PM
BigSky's Avatar
BigSky
But they give you one more thing you can Hydro!
Old Sep 10, 2007 | 07:28 PM
kenchan's Avatar
kenchan
but i dont drive around with my bonnet open...
man, that sounds weird....
Old Sep 10, 2007 | 08:27 PM
BigSky's Avatar
BigSky
but i don't drive around with my bonnet open...
It's called "inner satisfaction" which is why I do most things!
Old Sep 10, 2007 | 11:29 PM
Sin MINI's Avatar
Sin MINI
Only you Kenchan, only you...!
Old Sep 11, 2007 | 05:39 AM
kenchan's Avatar
kenchan
you guys are crazier than i am....
Old Sep 11, 2007 | 07:45 AM
jefeant's Avatar
jefeant
I would say, you need them both. They complement each other.
The adj 22mm rear sway bar will stiffen the rear and the strut brace the front.
I went step by step and after installing the strut brace - last - the whole cars' attitude, while turning hard, changed = NEUTRAL.
Both ++
Old Sep 11, 2007 | 09:07 AM
Sin MINI's Avatar
Sin MINI
As far as "too stiff". my concern is that this car is also driven on occasion by my wife. She's why they put understeer in cars to begin with. I want better but I want safe.
I've been told by a modder that the 19mm is not that different from stock on an "S" and recommends a 22mm or the H-Sport hollow 25mm (lighter).
Thoughts?
Old Sep 11, 2007 | 09:22 AM
kenchan's Avatar
kenchan
go with 22mm on stiff setting. that's what i use with my h-sport springs.
almost a perfect balance of turnability and safety margin. might want to do the
softer setting on stock springs.
Old Sep 11, 2007 | 09:34 AM
Sin MINI's Avatar
Sin MINI
How hard/easy is it to change settings?
