Water leaking/Downshifting Noise
Old May 2, 2007 | 07:47 AM
bigcat4275's Avatar
bigcat4275
I have a little over 1200 miles on my Cooper S. I followed the dealer reccomended break of no faster than 100mph no revs above 4500. Recently noticed that when I down shift from 3rd to 2nd I get a noise. The best way to describe the noise is a metal on metal scrape. The other issue I have is water leaking into the car. It seems to be running down the inside of the door and then over the sill into the footwell area on the drivers side. Appt is for next tuesday so I will update once service is done. Also I scheduled an oil change since I just finished the break in.
Old May 8, 2007 | 03:29 AM
Krut's Avatar
Krut
good luck with that.. let us know how it goes.
Old May 8, 2007 | 06:09 PM
JohnnyF's Avatar
JohnnyF
If you haven't already, you may want to check out Krut's thread in this forum about groaing second gear.
Then again, you may not.
lweaver
Sep 17, 2024 08:22 AM
Supertractor3
Apr 7, 2017 11:16 AM
Hobine
Oct 7, 2015 04:52 PM
rob&JCW
Sep 10, 2015 12:06 PM
Camaro108
Sep 9, 2015 01:56 PM
