Who is using a Fumoto Oil drain valve on your MINI ?
Old Feb 23, 2007 | 12:16 PM
  #51
LordOfTheFlies's Avatar
LordOfTheFlies
Originally Posted by KevinBaker
Oh, you work for/run Fumoto?!
I've just installing mine this morning, amazing little thing. Guy whos hoist I borrowed was VERY impressed!
[Edit: BTW was actually fixing an exhaust rattle when I installed it; I'm not *that* lazy to use a hoist just to change the valve over ]
Hey Kevin,
I was just mimicking a commercial where a guy is selling a hair loss secret potion.
Old Feb 26, 2007 | 01:54 PM
  #52
KevinBaker's Avatar
KevinBaker
Ah, we obviously don't get that commercial here .
Old Jul 23, 2007 | 06:29 AM
  #53
norm03s's Avatar
norm03s
Fumoto = easy as cake
Old Jul 23, 2007 | 07:04 AM
  #54
agranger's Avatar
agranger
I got to USE my Fumoto valve for the first time a few weeks ago. The install is a snap but this thing really makes changing your oil easier. No more fumbling with the bolt and getting oil down your arm. It really is very nice and well worth the $20 to me.
Old Jul 25, 2007 | 09:26 AM
  #55
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
I have the washer that came with the Fumoto installed and it's leaking oil. Next time I change my oil I'm going to have to take the valve off and put a new washer on there. Fortunately, I'll be able to drain the oil before removing the valve, so I'll still avoid the oil up my sleeve thing.
Old Jan 27, 2008 | 12:52 PM
  #56
norm03s's Avatar
norm03s
Just ordered two Fumoto F-106 N (Nipple) valves for a friend and I. One step closer to total laziness by eliminating the transfer of old oil from drain pan to waste oil jugs.
I hated that part the most, it would almost put me into Procrastination mode, the mess and cleanup, especially during Winter.
1. no funnel needed
2. no drain pan needed
3. eureka
Old Jan 31, 2008 | 07:44 PM
  #57
jdonaldlukas's Avatar
jdonaldlukas
I installed mine on the first change as a safety measure; since I had read that the threads of the original plug are easily stripped. No complaints whatsoever 12 months later.
Easy,
J
Old Feb 3, 2008 | 06:14 AM
  #58
Alerious's Avatar
Alerious
I've been tossing the idea of buying a Fumoto valve, but I'm curious if anyone with a dropped MINI is running this? I'm concerned the valve getting hit whenever I bottom out since it looks like the valve extends further downward relative to where the tranny sits.
GotMINI
Old Feb 3, 2008 | 06:48 AM
  #59
ridingfar's Avatar
ridingfar
GotMINI
I don't think this is the case. Install the Fumoto drain valve with the lever on top (up side of the oil pan drain hole) and the valve is not lower than the stock bolt and still above the bottome of the oil pan...
Old Feb 3, 2008 | 07:02 AM
  #60
Alerious's Avatar
Alerious
Great... that's the kinda info I'm looking for... thanks! Would that be the case for the valve with the nipple as well?
GotMINI
Old Feb 3, 2008 | 02:31 PM
  #61
ridingfar's Avatar
ridingfar
GotMINI
Yes; the nipple will be horizontal to the ground pointing to the rear of the car.
Old Feb 3, 2008 | 06:38 PM
  #62
OctaneGuy's Avatar
OctaneGuy
Plenty of clearance. If you're scraping the lower front airdam lip on speed bumps, you aren't going to hit the Fumoto valve yet, unless you've trimmed the lip away and are now dragging the tranny, lol.
I'm lowered, and right now on 15's while my 17's get painted, and I drag on everything--speed bumps, driveways, and I'm not dragging my Fumoto valve. =)
Richard
GotMINI
Old Feb 3, 2008 | 07:10 PM
  #63
ScottinBend's Avatar
ScottinBend
Just remember you can't use the Fumoto if you have the oem oil temp gauge installed. The sending unit is in the stock drain plug.
Old Feb 3, 2008 | 08:33 PM
  #64
Quesera's Avatar
Quesera
So, if you have the chrono pack does that mean no Fumoto?
Old Feb 3, 2008 | 08:37 PM
  #65
ScottinBend
Not sure. But you could take a look at the drain plug and see if it is plugged in............
Colt45Magnus
Jul 14, 2019 06:18 PM
WarEagle
R55 :: Clubman Talk (2008+)
May 3, 2019 03:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
eliseo1981
Aug 6, 2015 05:00 AM
