run flats, run flat
Old Apr 14, 2003 | 05:41 AM
koolmini's Avatar
koolmini
help.....
is there a warrantee on the Pirelli Run Flats?
if so, what kind of warrantee?
Old Apr 14, 2003 | 05:48 AM
koolmini's Avatar
koolmini
anybody, McFly ?????
Old Apr 14, 2003 | 05:50 AM
jsun's Avatar
jsun
Sounds like a good question for your dealer...why don't you just call?
Most tire warrantees only cover manufacturing defects, not tire damage. Therefore, in most cases, a tire warrantee isn't worth anything since 99% of early tire failures can be easily chalked up to your running over something versus the tire simply failing all by itself. But don't take my word for it...call your dealer.
Old Apr 14, 2003 | 05:59 AM
koolmini's Avatar
koolmini
looks like i'll be visiting my dealer today, to get the tire with the bubble/seperation from the rim replaced, i guess i'll find out then
i was just curious and wanted info before i go to the dealer today
_________________
Old Apr 14, 2003 | 06:04 AM
koolmini's Avatar
koolmini
also, NO flat tire monitor light came on
i think it's still holding air, of course i couldn't find any of my tire pressure gauges last night, but i will check the tire pressure before i go down to the dealer
_________________
Old Apr 14, 2003 | 06:06 AM
jsun's Avatar
jsun
Hit any curbs or potholes lately? Low profile, performance, tires IMO are notorious for this sort of bubble damage. On the other hand, I've seen tires do this from manufacturing problems too. Unless you also have a damaged (nicked or dented) rim -- which would give away the fact that you hit something -- it sounds like it'll be tough call on the warrantee. Good luck! :smile:
Old Apr 14, 2003 | 06:12 AM
koolmini's Avatar
koolmini
probably road damage (the roads in the N.E. are so fu*cked)
but i don't have any rim damage and i know it just happen over the weekend
i saw the tire damage as i was wiping down the car (not there in the morning, there in the evening)
Old Apr 14, 2003 | 06:21 AM
LaBoy_Mini's Avatar
LaBoy_Mini
I'm sorry to hear it but I do feel for you.
Hope the dealer can takes care of it.
Old Apr 14, 2003 | 07:17 AM
Pebble's Avatar
Pebble
I Belive (which means i don't know for sure) that the tyre is idependently warrentied by the manufacturer of the tyre.
mt $0.02.
:smile:
Old Apr 15, 2003 | 07:10 PM
ngi0811's Avatar
ngi0811
go to any pirelli authorized tire dealer and they will replace if there is a separation between the rubber plies (manufacturing defect). They will NOT replace the tire if the separation is due to a road hazard or curb damage. Try Goodyear's, they are the best. 17" NCT 5's
Old Apr 16, 2003 | 06:20 PM
Morales's Avatar
Morales
koolmini,
You put the mush on me! I got my car washed today and I have the exact same problem. Bubble on the front driver side wheel. No rim damage or curb marks. No flat tire light. Seems to be holding pressure.
This is odd as we have the same type of wheel (17" OZ F1). Keep me posted on your progress.
Old Apr 17, 2003 | 05:07 AM
koolmini's Avatar
koolmini
i purchased a new tire and the dealer is checking with Pirelli about the warranty
Old Apr 22, 2003 | 03:04 PM
Zappa's Avatar
Zappa
I just switched to Toyos with lighter rims. Has anyone found a fitting space saver tire? What does the coopers have?
khumpert
Nov 30, 2015 11:48 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
12
Sep 10, 2015 04:48 PM
ltjpunk7
Sep 6, 2015 07:32 AM
TJANK
Aug 24, 2015 06:11 PM
jziran
Aug 24, 2015 04:50 PM
