ECU re-flash. Damn!
Old Oct 5, 2006 | 11:54 PM
XAlfa's Avatar
XAlfa
ECU re-flash. Damn!
So I brought my car in to the dealer for a few things and the SA recommended I re-flash with whatever the latest software is at this point, which I think he said was 23.01(?). He said that they switched over to a completely new map at some point since my car was last flashed and it was much improved over the old 3.X series. I was reluctant to do it as it weren't broke, if you know what I mean, but he kept saying, "I strongly recommend it. I think you will be VERY happy." So I'm only a couple hundred miles into it, but damn! It really feels great. MUCH better throttle response, more power througout and it seems like my rev limit is higher. I swear I have another 10-15hp at the top end. Assuming it only gets better as it adapts to my leaden foot, the end result should be outstanding. My car is an 04 JCW with the 210 upgrade. One thing I'm not ruling out is that the dealer who did the upgrade did not reflash me properly at that time, and that now I finally have a map optimized for the bigger injectors and air box. But I'm not asking questions at this point, just driving the **** out of it.
Old Oct 6, 2006 | 12:19 AM
cmbtmini's Avatar
cmbtmini
I need to talk to my SA as well, it seems. Can you verify what software revision it is?? I have an early build 05 JCW. Thanks
Old Oct 6, 2006 | 06:11 AM
mdsbrain's Avatar
mdsbrain
Good to hear.
Old Oct 6, 2006 | 08:48 AM
turbo black's Avatar
turbo black
just had mine done a few months ago, it is version 42.2
Old Oct 6, 2006 | 09:26 AM
kenchan's Avatar
kenchan
wait a few weeks until the car adapts. then it's back to pretty much normal, probably.
Old Oct 6, 2006 | 09:27 AM
XAlfa's Avatar
XAlfa
Noooo!!
Old Oct 6, 2006 | 09:32 AM
forestcrump's Avatar
forestcrump
What would be the most recent version for an 06 MCS?
Old Oct 6, 2006 | 09:48 AM
kenchan's Avatar
kenchan
Originally Posted by XAlfa
Noooo!!
reset the ECU when you feel the need. im actually wiring up a
switch in series on my G35C to cut power to the ECU backup memory
so that it looses the adaptive memory during the weekdays my car
sleeps.
then each sat morning, i will have full power from the intake i put on...
so much power man... next up, phlenum spacer. hope to take
my car to the track (road course) next year.
Old Oct 6, 2006 | 10:40 AM
forestcrump
What is the best way to reset the ECU?
Old Oct 6, 2006 | 11:17 AM
XAlfa's Avatar
XAlfa
Smash it with a mallet.
Old Oct 6, 2006 | 11:21 AM
forestcrump
After all my searching here and on MINI2 it seems that the mallet is the best way to go.
thanks
Old Oct 6, 2006 | 11:52 AM
mdsbrain's Avatar
mdsbrain
Quick search on NAM resulted in a link to mini2's How-to section:
http://www.mini2.com/forum/faq.php?f..._obc_functions
Old Oct 6, 2006 | 12:25 PM
kenchan's Avatar
kenchan
http://www.mini2.com/forum/1940398-post5.html
1) With the key in the off position press and hold the speedo reset button, turn the key to position one and the screen will say test and a number.
2) Go through the list by pressing the reset button upto test 19 and then wait.
3) The display should then say"log i-off" then "log i-on" over and over again....when "log i- off" appears again press the reset button ....and now you are in the system software.
4) Scroll upto 21.0 Software reset. When reset appears press the button again and you will get a beep and you're speedo needle may vibrate a little (this is normal).
5) Turn ignition off then back on to position 2 for 10 secs then start your car and hey presto its done.
Old Oct 6, 2006 | 12:40 PM
fishbulb's Avatar
fishbulb
Is this update for an 06 MCS as well? Or JCW only? I am coming up on my 10K service, I will have to inquire.
thank you!
Old Oct 6, 2006 | 12:47 PM
XAlfa's Avatar
XAlfa
sleeps.
So I assumed that the "adaptation" was a good thing. No?
Old Oct 6, 2006 | 01:51 PM
kenchan's Avatar
kenchan
for drivability and fuel economy, sure.
Old Oct 6, 2006 | 02:01 PM
F15EWeapon's Avatar
F15EWeapon
I've been very hesitant to allow the dealer to reflash me whatsoever. I still have like version 32 or 33. I hate the DSC, so I hear the new set-up for that was much better, but that they also dumbed down the throttle response in response to yo-yo complaints, which I just wasn't willing to give up.
Any chance the JCW reflash would benefit me a little bit? Might be worth a shot I suppose, as long as the dealers willing to play ball with me.
Old Oct 6, 2006 | 04:29 PM
ProfessorDave's Avatar
ProfessorDave
sleeps.
Sooo clever. And yet so evil! Very cool idea (although I like the whole mallet reset, too).
Old Oct 9, 2006 | 09:43 AM
Jdewey's Avatar
Jdewey
I have no idea who is right, but .....
The instructions on the ECU reset have been "refuted" by a MINI Tech. He posted a note somewhere on here, saying that the instructions just get you a "dashboard" reset, and the ECU can only be reset by some specialized MINI servicing program.
J D
Old Oct 9, 2006 | 11:24 AM
XAlfa's Avatar
XAlfa
J D
So you can't just disconnect the battery for a while?
Old Oct 9, 2006 | 11:31 AM
Dr Obnxs's Avatar
Dr Obnxs
There are parts that are lost and parts that aren't...
the fuel trims will go, as will SOME but not all OBD codes. But some things won't go, and they require a DME reset that isn't done by the dash trick. I wish I had a list of everything that was covered by each method, but it doesn't exist.
I don't know if the reset button discussed will make that much difference. But what they hay, report back what you find!
Matt
Old Oct 11, 2006 | 07:35 PM
Grassroots Garage's Avatar
Grassroots Garage
J D
This is correct, your only resetting the instrument cluster electronics with the dash reset, not the DME. Only the dealers GT1 and a few expensive pro level scan tools can reset the engines adaptation values.
NOTE to CVT owners: do not let anyone reset your DME adaptations, it will f*** up your shift program and requires a really mean test drive to get it to shift again.
Old Oct 14, 2006 | 02:21 PM
herbie hind's Avatar
herbie hind
that's awsome .you musta been high fiveing yourself for days .
Old Oct 14, 2006 | 04:04 PM
Motor On's Avatar
Motor On
J D
Matt
Sadly these boys are right. Even a DME reset for other items or the same version will pretty much have the same efffect, it feels great while it lasts. I've heard of BMW techs explain that you're limited to 14 or so updates before haivng to replace the DME as well. Thats how it goes on the MINI, I wish we could do something like what ken has for his G35, but I think the closest option is aftermarket or finding out how to do custom map on your own, but hat takes moeny time and lots of knowledge and a preferably a personal dyno.
bahman
Feb 14, 2016 10:29 AM
mni928
Nov 9, 2015 07:38 PM
Huskyfan
GP Talk
Sep 28, 2015 06:08 PM
genik
Cooper (non S)
Sep 25, 2015 02:46 PM
Sep 25, 2015 12:32 PM
