broken 05 engine mount???
Old Sep 17, 2006 | 05:47 PM
meb's Avatar
meb
While in front of the car facing the engine, the mount on the left strut tower has fluid - new and old leaking from the seam. I suspected funny engine movements for a week now, but after giving my daughter manual transimission lessions tonight...and after a couple of third gear starts an unuasual heavy clicking, but not quite thunking noise appeared. I suspect this is the cause as the noise occurs upon initial acceleration or when the throttle is abruptly closed.
Has anyone experienced a mount failure like this?
Old Sep 17, 2006 | 07:17 PM
1nf3rn0's Avatar
1nf3rn0
I haven;t, but a friend has. If you want to contact Steve Tech at Custom MINI Shop, they can help you out... Other than that, you could go to a dealer and have them replace the mount. Mine is leaking too, so I imagine it is a fairly common problem.
Old Sep 17, 2006 | 07:21 PM
mdsbrain's Avatar
mdsbrain
Its becoming pretty common. There is serveral threads on this and once recent one is this one.
Old Sep 17, 2006 | 07:22 PM
dave's Avatar
dave
pug poo picker-upper
It's very common problem. I have seen this on several MCS's. Usually replaced under warranty if you are still in the warranty period.
Old Sep 17, 2006 | 07:43 PM
kenchan's Avatar
kenchan
megan...powerflex...ireland camber&toe links...TCE12.2bbk...180 thermo...17" team dynamics...RA1...M7 USS...M7 SB...webb extreme bar...tylenol
Old Sep 17, 2006 | 07:50 PM
ATCQL's Avatar
ATCQL
The same mount in my 2005 S was replaced under warranty at 8500 miles.Q
Old Sep 18, 2006 | 06:01 AM
meb's Avatar
meb
you missed one of my pics in my gallery - I had a cup of coffee and a bottle of some pain killer next to it...Excedrin I think. so I was covered!
Ok, thanks everyone!
Old Sep 20, 2006 | 05:44 AM
1FSTMINI's Avatar
1FSTMINI
Very common and ive done tons of them here at my dealer.
Old Sep 20, 2006 | 08:03 AM
SRTech's Avatar
SRTech
Once you lose enough oil, the engine bounces up and down, clunking (thunking) against the stops inside the mount. Mine leaked at 8k miles and I replaced it at 30k. It was definitely out of oil since it didn't leak anymore and I could push down on the engine and hear it clunk. The oil does a good job of staining the paint on the frame rail, too.
Steve
Old Sep 25, 2006 | 10:30 AM
droptopmini's Avatar
droptopmini
I was just searching NAM for this problem. I drove into my garage Thursday, got out, and noticed a trail of oil behind my car. Looked under my car and there was a puddle of oil building up on my garage floor. Opened the hood and noticed that the oil seemed to be coming from a aluminum can under the engine mount on the passenger side. Figured this may be some sort of damper. Called MINI service and they said not to drive the car. They had me contact roadside service to pick up my car. It is at the shop now. They have not contacted me yet but the car is still under warranty. It will be a year old this month and has 17K miles on it.
Old Sep 25, 2006 | 10:51 AM
Dinger28's Avatar
Dinger28
Yea it is the hydraulic motor mount. Mine went out about 5k after my pulley install. Not sure that was the reason, but it was replaced under warranty. No biggie
Dinger
Old Sep 25, 2006 | 08:08 PM
droptopmini
Dealer called and said it was a front engine seal. Parts won't be in until Wednesday. Bummer.
Old Sep 28, 2006 | 01:25 PM
Zarrik's Avatar
Zarrik
I brought my car in today to replace some of the clips for the trim and mentioned that I was getting a clunking sound from the engine. It turned out to be a bad motor mount which was fixed under waranty. 17k miles on the odometer (2005 MCS). Now the annoying engine rattle is gone
Old Oct 3, 2006 | 06:15 AM
mbcoops's Avatar
mbcoops
I posted about a clunk - turned out to be a broken motor mount, so chalk another one up there.
mb
Old Oct 5, 2006 | 02:50 PM
droptopmini
They endedn up replacing the front seal and the engine mount. They said both were failing.
Old Oct 6, 2006 | 04:02 AM
1FSTMINI's Avatar
1FSTMINI
Kinda odd....Never seen a front seal go, but ok.
09R56
Nov 16, 2022 10:49 AM
silence2-38554
Nov 12, 2015 09:39 AM
StuRat
Aug 24, 2015 06:24 PM
Aug 19, 2015 12:51 PM
